STM32
直播中
哈哈哈
11年用户 863经验值
擅长:可编程逻辑
私信 关注
[经验]
求助,关于STM32U5的HIGH SPEED USB时钟源的问题求解
如题,STM32U595,USB要使用HIGH SPEED,也就是480M总线速度,手册上说的HS必须要用HSE做时钟源,但是现在试了下,用HSI做时钟源,也是可以的,这是个例还是确实可以用HSI做时钟源?如果批量出产品,用HSI做USB HS时钟源,会不会经常故障,良品率不高?
USB on-the-go high-speed (OTG_HS)The devices embed an USB OTG high-speed device/host/OTG peripheral with integratedtransceivers. The OTG_HS peripheral is compliant with the USB 2.0 specification and withthe OTG 2.0 specification. It has software-configurable endpoint setting and supportssuspend/resume.This interface requires a precise 60 MHz clock that is generated from the internalUSB PHY PLL (the clock source must use a HSE crystal oscillator).
更多回帖
