英飞凌
直播中
邹俩珍
7年用户 1014经验值
私信 关注
开发CYUSB3065+AR0521,主机应用程序无法流式传输图像怎么解决?
我们正在开发 CYUSB3065+AR0521,主机应用程序无法流式传输图像。 请给予我们支持,谢谢。
GPIO 配置
RAW8,mipi 4lanes, 2600x1952,8bit 60fps
(2 ) MIPI 接收机配置
(3) UART 日志
Prod = 104 Cons = 104 Prtl_Sz = 11264 Frm_Sz = 2540944 B
Prod = 104 Cons = 104 Prtl_Sz = 19744 Frm_Sz = 2549424 B
Prod = 104 Cons = 103 Prtl_Sz = 10528 Frm_Sz = 2540208 B Prod = 104 Cons = 104 Prtl_Sz = 10528 Frm_Sz = 2540208 B Prod = 104 Cons = 104 Prtl_Sz = 11264 Frm_Sz = 2540944 B2540208 B
Prod = 104 Cons = 104 Prtl_Sz = 10800 Frm_Sz = 2540480 B
Prod = 104 Cons = 104 Prtl_Sz = 11296 Frm_Sz= 2540976 B
Prod = 104 Cons = 104 Prtl_Sz = 11020 Frm_Sz = 2540700 B
Prod = 104 Cons = 105 Prtl_Sz = 14128Frm_Sz = 2543808 B
Prod = 104 Cons = 103 Prtl_Sz = 10532 Frm_Sz = 2540212 B
Prod = 104 Cons = 104 Prtl_Sz = 10532 Frm_Sz = 2540212 B
Prod = 104 Cons = 105 Prtl_Sz = 14892Frm_Sz = 2544572 B
Prod = 104 Cons = 104 Prtl_Sz = 12332 Frm_Sz = 2542012 B
Prod = 104 Cons = 105 Prtl_Sz = 12332 Frm_Sz = 2542012 B Prod = 104 Cons = 105 Prtl_Sz = 14920 Frm_Sz = 2540212 B14920 Frm_Sz = 2544600 B
Prod = 104 Cons = 104 Prtl_Sz= 10976 Frm_Sz = 2540656 B
Prod = 104 Cons = 105 Prtl_Sz = 14584 Frm_Sz = 2544264 B
Prod = 104 Cons = 104 Prtl_Sz = 14016 Frm_Sz = 2543696 B
Prod = 104 Cons = 103Prtl_Sz = 13876 Frm_Sz = 2543556 B
Prod = 103 Cons = 104 Prtl_Sz = 14880 Frm_Sz = 2520000 B
Prod = 104 Cons = 104 Prtl_Sz = 11016 Frm_Sz = 2540696 B
Prod = 104 Cons = 104 Prtl_Sz = 14588 Frm_Sz = 2544268 B
Prod = 103 Cons = 103 Prtl_Sz = 19084 Frm_Sz = 2524204 B
Prod = 104 Cons = 104 Prtl_Sz = 14936 Frm_Sz = 2544616 B
Prod = 104 Cons = 104 Prtl_Sz = 14928 Frm_Sz = 2544608 B
Prod = 104Cons = 103 Prtl_Sz = 10600 Frm_Sz = 2540280 B
Prod = 104 Cons = 105 Prtl_Sz = 14880 Frm_Sz = 2544560 B
Prod = 103 Cons = 102 Prtl_Sz = 1120 Frm_Sz = 2506240 B
Prod = 104 Cons = 104 Prtl_Sz = 14428 Frm_Sz = 2544108 B
(4) PCLK、HSYNC、VSYNC 信号、hsync 信号看起来有问题。
回帖(1)
张亮
2024-5-20 15:41:27
要解决CYUSB3065+AR0521主机应用程序无法流式传输图像的问题,请按照以下步骤操作:
1. 检查硬件连接:确保CYUSB3065和AR0521之间的硬件连接正确无误。检查电源、数据线和控制线是否连接正确。
2. 检查固件配置:确保CYUSB3065和AR0521的固件配置正确。根据您的描述,GPIO配置为RAW8,MIPI为4lanes,分辨率为2600x1952,8bit,60fps。请检查这些配置是否正确,并确保它们与您的硬件和需求相匹配。
3. 检查主机应用程序:确保主机应用程序正确配置以接收图像数据。检查应用程序是否使用了正确的接口和协议与CYUSB3065通信。
4. 检查数据传输速率:根据您提供的UART日志,生产者和消费者的数量以及帧大小似乎没有问题。但是,请确保主机应用程序能够处理这些数据传输速率,以避免数据丢失或延迟。
5. 更新驱动程序和固件:确保您的主机计算机上安装了最新的CYUSB3065驱动程序和AR0521固件。这可以解决与兼容性和性能相关的问题。
6. 检查错误日志:检查CYUSB3065和AR0521的错误日志,以确定是否存在任何错误或警告。这可以帮助您找到问题的根源并采取相应的解决措施。
7. 联系技术支持:如果以上步骤都无法解决问题,请联系Cypress Semiconductor的技术支持团队。他们可以为您提供专业的技术支持和解决方案。
通过遵循这些步骤,您应该能够解决CYUSB3065+AR0521主机应用程序无法流式传输图像的问题。
举报
更多回帖
