STM32
直播中
xymbmcu
13年用户 1124经验值
擅长:可编程逻辑
私信 关注
[问答]
STM32F05串口通信收发不一致的原因?
下面是我的配置代码:
static void GPIO_USART1_Configuration(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        GPIO_PinAFConfig(GPIOUSART1, GPIO_PinSource9,  GPIO_AF_1);
        GPIO_PinAFConfig(GPIOUSART1, GPIO_PinSource10, GPIO_AF_1);
        /* GPIO_PIN9 - gt; USART1-TX  GPIO_PIN10 - gt; USART1-RX */
       GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9 |  GPIO_Pin_10 ;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOUSART1,  amp;GPIO_InitStructure);
void USART1_Configuration(void)
        USART_InitTypeDef USART_InitStructure;
        GPIO_USART1_Configuration();
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        USART_InitStructure.USART_BaudRate                      = 9600;
        USART_InitStructure.USART_WordLength                  = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits                         = USART_StopBits_1;
        USART_InitStructure.USART_Parity                               = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode                               = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART1,  amp;USART_InitStructure);
        USART_Cmd(USART1, ENABLE);//ʹÄÜ´®¿Ú1
void UART1_send_byte(uint8_t byte)
        while(!((USART1- gt;ISR) amp;(1ISR) amp;(1ISR  amp; (1CR |= (uint32_t)0x00000001;
  /* Reset SW[1:0], HPRE[3:0], PPRE[2:0], ADCPRE and MCOSEL[2:0] bits */
  RCC- gt;CFGR  amp;= (uint32_t)0xF8FFB80C;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC- gt;CR  amp;= (uint32_t)0xFEF6FFFF;
  /* Reset HSEBYP bit */
  RCC- gt;CR  amp;= (uint32_t)0xFFFBFFFF;
  /* Reset PLLSRC, PLLXTPRE and PLLMUL[3:0] bits */
  RCC- gt;CFGR  amp;= (uint32_t)0xFFC0FFFF;
  /* Reset PREDIV1[3:0] bits */
  RCC- gt;CFGR2  amp;= (uint32_t)0xFFFFFFF0;
  /* Reset USARTSW[1:0], I2CSW, CECSW and ADCSW bits */
  RCC- gt;CFGR3  amp;= (uint32_t)0xFFFFFEAC;
  /* Reset HSI14 bit */
  RCC- gt;CR2  amp;= (uint32_t)0xFFFFFFFE;
  /* Disable all interrupts */
  RCC- gt;CIR = 0x00000000;
/* Configure the System clock frequency, AHB/APBx prescalers and Flash settings */
  SetSysClock();
static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
  /* Enable HSE */
  RCC- gt;CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC- gt;CR  amp; RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0)  amp; amp; (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC- gt;CR  amp; RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH- gt;ACR |= FLASH_ACR_PRFTBE;
    FLASH- gt;ACR |= (uint32_t)FLASH_ACR_LATENCY;
    /* HCLK = SYSCLK */
    RCC- gt;CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK = HCLK */
    RCC- gt;CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
    /*  PLL configuration:  = HSE *  4 = 40 MHz */
    RCC- gt;CFGR  amp;= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC- gt;CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL4);
    /* Enable PLL */
    RCC- gt;CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC- gt;CR  amp; RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC- gt;CFGR  amp;= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC- gt;CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC- gt;CFGR  amp; (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
调了两天了,一直找不到问题,
回帖(1)
莫联雪
2024-5-17 18:06:46
STM32F05串口通信收发不一致的原因可能有以下几点:
1. 波特率不匹配:确保发送端和接收端的波特率设置相同。波特率设置错误可能导致数据传输错误或丢失。
2. 串口模式设置不正确:检查USART_InitTypeDef结构体中的USART_Mode参数,确保发送和接收模式都已启用(USART_Mode_Tx | USART_Mode_Rx)。
3. 时钟配置错误:检查RCC_APB2PeriphClockCmd函数中的参数,确保正确配置了串口时钟。
4. GPIO配置错误:检查GPIO_PinAFConfig函数中的参数,确保正确配置了TX和RX引脚的复用功能。
5. 串口初始化未完成:确保在调用USART_Init和USART_Cmd函数之前,已经正确初始化了GPIO和串口。
6. 缓冲区溢出:确保发送和接收缓冲区足够大,以避免数据丢失。
7. 硬件问题:检查硬件连接是否正确,包括TX和RX引脚的连接,以及地线和电源线的连接。
8. 软件逻辑错误:检查代码中是否有逻辑错误,例如错误的数据发送或接收顺序。
针对您提供的代码,我无法看到完整的配置代码,但请确保以下几点:
1. 检查USART_InitTypeDef结构体中的参数设置,特别是波特率、字长、停止位和奇偶校验位。
2. 确保已经调用USART_Init和USART_Cmd函数来初始化和启用串口。
3. 检查GPIO_PinAFConfig函数中的参数,确保TX和RX引脚的复用功能已正确配置。
4. 如果可能,请提供完整的代码,以便更详细地分析问题。
举报
更多回帖
