求助各路大虾,我在STM8S的评估板上准备实现PWM控制LED的亮暗,LED是接在PD7管脚上,采用
tiM1 channel 4 输出PWM,可是怎么也出不来效果。请教是哪里出了问题,下面是我的设置。还有一个,在STVD编译环境下跟踪寄存器,发现TIM1_CCR寄存器竟然是“intrusive read”, 单步执行写CCR,根本就写不进去,青椒大虾们为什么CCR寄存器会标注"intrusive read"?多谢大虾们。
//use TIM1 PWM to control LED
//set system clock
CLK->PCKENR1 = 0x80;
CLK->CMSR = 0xE1; //choose CLK HSI = 16Mhz as fMASTER.
CLK->CKDIVR = 0x00; //set fHSI= fHSI RC output/8 = 16Mhz/1 = 16MHz
//Becasue CPUDIV no any devide, so fMASTER = fHSI = 16Mhz
//init TIM1 base unit
TIM1->PSCRH = 0x00;
TIM1->PSCRL = 0x00; //fCONT = fHSI = 16Mhz
//set PWM freq
TIM1->ARRH = 0x00;
TIM1->ARRL = 0x7f; //PWM freq= 16Mhz/(0x7f+1)=16Mhz/128=15625Hz
TIM1->CR1 = 0x00;
TIM1->RCR = 0x00; //no repeat count;
//set TIM1_CH4
TIM1->CCER2 = 0x10; //CC4E(bit4)=1: OC4 output enable
//CC4P(bit5)=0: high level is active;
TIM1->CCMR4 = 0x60; //set channel 4 as PWM mode1, preload is disable
TIM1->OISR = TIM1->OISR | 0xbf; //bit6(OIS4)=0, Output idle state is 0;
//initialize PWM duty circle
TIM1->CCR4H = 0x00;
TIM1->CCR4L = 0x00; //PWM duty circle = CCR4/(ARR+1)*100%
TIM1->IER = 0x00; //disable interrupt;
TIM1->CR2 = 0x00;
TIM1->CR1 = TIM1->CR1 |0x01; //start count.
TIM1->BKR = 0x80; //enable;
