STM8L151 ADC 采用DMA 8通道连续采集,通过ST_LINK
仿真发现:通道数据滚动问题,比如第一通道的数据本应该在数组0通道,一会儿整组偏移到数组3通道,一会又偏移到4通道,而且是所有数据同时偏移。网上搜了一下,有很多人遇到过,但是都不说解决方法。折腾了一天无解,只能在这里求救了。ADC初始化程序如下:
void ADC_DMA_Config(void) //ADC初始化,ADC连续转换模式
// Enable ADC clock
CLK_PeripheralClockConfig(CLK_Peripheral_ADC1, ENABLE); //开启ADC时钟
CLK_PeripheralClockConfig(CLK_Peripheral_DMA1, ENABLE); //DMA时钟
DMA_DeInit(DMA1_Channel0); //初始化DMA为默认值
ADC_DeInit(ADC1); //初始化ADC为默认值
ADC_Init(ADC1, ADC_ConversionMode_Con
tinuous,ADC_Resolution_12Bit, ADC_Prescaler_1);//初始化ADC1为,连续转换模式,12位AD转换,ADC时钟预分频为1
ADC_SamplingTimeConfig(ADC1, ADC_Group_SlowChannels,ADC_SamplingTime_192Cycles);//配置ADC为慢速通道,采样时间周期为192
//ADC_SamplingTimeConfig(ADC1, ADC_Group_FastChannels,ADC_SamplingTime_24Cycles);//配置ADC为,快速通道,采样时间周期为9
ADC_Cmd(ADC1, ENABLE); //启用ADC
//ADC_ChannelCmd(ADC1, ADC_Channel_Vrefint, ENABLE); //内部参考电压
ADC_ChannelCmd(ADC1, ADC_Channel_15, ENABLE); //ADC通道15使能 Vbat 总电池电压
ADC_ChannelCmd(ADC1, ADC_Channel_16, ENABLE); //ADC通道16使能 TS5 MOS温度检测
ADC_ChannelCmd(ADC1, ADC_Channel_17, ENABLE); //ADC通道17使能 TS4 电池温度检测4
ADC_ChannelCmd(ADC1, ADC_Channel_18, ENABLE); //ADC通道18使能 TS3 电池温度检测3
ADC_ChannelCmd(ADC1, ADC_Channel_19, ENABLE); //ADC通道19使能 TS2 电池温度检测2
ADC_ChannelCmd(ADC1, ADC_Channel_20, ENABLE); //ADC通道20使能 TS1 电池温度检测1
ADC_ChannelCmd(ADC1, ADC_Channel_21, ENABLE); //ADC通道21使能 Ic 充电电流检测
ADC_ChannelCmd(ADC1, ADC_Channel_22, ENABLE); //ADC通道22使能 Id 放电电流检测
SYSCFG_REMAPDMAChannelConfig(REMAP_DMA1Channel_ADC1ToChannel0); //重新映射DMA通道的具体外围(ADC或TIM4)
DMA_Init(DMA1_Channel0, //通道0
(uint32_t) ADC_Value, //缓冲区地址
(uint16_t)ADC1_DR_Address, //ADC数据寄存器地址
DMA_BUF_SIZE, //缓冲区大小
DMA_DIR_PeripheralToMemory, //外设到内存
DMA_Mode_Circular, //循环转换
DMA_MemoryIncMode_Inc, //内存地址自增
DMA_Priority_High, //优先级为高
DMA_MemoryDataSize_HalfWord); //内存数据是半字位宽 16位
// DMA_SetCurrDataCounter(DMA1_Channel0,DMA_BUF_SIZE);//
// Enable DMA1 channel0
DMA_Cmd(DMA1_Channel0, ENABLE); //启用DMA使能通道0
DMA_ITConfig(DMA1_Channel0,DMA_ITx_TC, ENABLE);//使能传输完成中断
//DMA_ITConfig(DMA1_Channel0,DMA_ITx_TC, DISABLE); //是否开启DMA中断
// DMA_ITConfig(DMA1_Channel0,DMA_ITx_HT, DISABLE);
DMA_GlobalCmd(ENABLE); //启用或禁用全部DMA
ADC_DMACmd(ADC1,ENABLE); //启用ADC DMA请求
// a short time of delay is required after enable ADC
//delay_10us(3); //延时
ADC_ITConfig(ADC1, ADC_IT_EOC,DISABLE); //开启ADC中断
// ADC_ClearFlag(ADC1, ADC_FLAG_EOC); //清除EOC标志,即:清除转换完成标志
ADC_SoftwareStartConv(ADC1); //开始ADC转换
