STM32
直播中
张超
8年用户 1355经验值
私信 关注
[问答]
如何使用HAL库实现不定长UART数据包的DMA接收?
uint8_t txbuf[1000]="helloworldrn";
uint8_t rxbuf[1000]="";
ART_HandleTypeDef huart1;
HAL_UART_Receive_DMA( huart1,rxbuf,sizeof(rxbuf));
函数原型如下:
  * @brief  Receives an amount of data in non blocking mode.
  * @param  huart: pointer to a UART_HandleTypeDef structure that contains
  *                the configuration information for the specified UART module.
  * @param  pData: Pointer to data buffer
  * @param  Size: Amount of data to be received
  * @note   When the UART parity is enabled (PCE = 1) the data received contain the parity bit.
  * @retval HAL status
HAL_StatusTypeDef HAL_UART_Receive_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
  uint32_t *tmp;
  uint32_t tmp1 = 0;
  tmp1 = huart->State;
  if((tmp1 == HAL_UART_STATE_READY) || (tmp1 == HAL_UART_STATE_BUSY_TX))
    if((pData == NULL ) || (Size == 0))
      return HAL_ERROR;
    /* Process Locked */
    __HAL_LOCK(huart);
    huart->pRxBuffPtr = pData;
    huart->RxXferSize = Size;
    huart->ErrorCode = HAL_UART_ERROR_NONE;
    /* Check if a transmit process is ongoing or not */
    if(huart->State == HAL_UART_STATE_BUSY_TX)
      huart->State = HAL_UART_STATE_BUSY_TX_RX;
    else
      huart->State = HAL_UART_STATE_BUSY_RX;
    /* Set the UART DMA transfer complete callback */
    huart->hdmarx->XferCpltCallback = UART_DMAReceiveCplt;
    /* Set the UART DMA Half transfer complete callback */
    huart->hdmarx->XferHalfCpltCallback = UART_DMARxHalfCplt;
    /* Set the DMA error callback */
    huart->hdmarx->XferErrorCallback = UART_DMAError;
    /* Enable the DMA Stream */
    tmp = (uint32_t*) pData;
    HAL_DMA_Start_IT(huart->hdmarx, (uint32_t) huart->Instance->DR, *(uint32_t*)tmp, Size);
    /* Enable the DMA transfer for the receiver request by setting the DMAR bit
    in the UART CR3 register */
    huart->Instance->CR3 |= USART_CR3_DMAR;
    /* Process Unlocked */
    __HAL_UNLOCK(huart);
    return HAL_OK;
  else
    return HAL_BUSY;
回帖(1)
李洁
2024-4-30 16:07:20
如果串口接收频率不高,不是可以使用串口自带的空中断,如果连续接收的,那就DMA收定长的数据,然后做好协议,拼接。
举报
更多回帖
