STM32
直播中
王彬
8年用户 1100经验值
私信 关注
[问答]
STM32F412RET+DA7218耳机无输出是哪些原因造成的?
目前设计是这样,STM32F412RET送出19.2M I2S MCLK给DA7218的CLKIN,如下的MIC_P选择Single‐ended方式输入,我在MIC_P有量到波形输入,I2S的SCLK,LRCK,DATAOUT都有量到正常波形,但HPL,HPR都没有波形输出。初始化DA7218的代码和线路图如下,帮忙检查下为什么HPL,HPR没有波形输出,会是哪里的问题?
  • {0x09, 0x80}, //RESET
  • {0x00, 0x01}, //Enable ACtiVE mode
  • {0x01, 0x01}, //Enable repeat mode register access (register address and data is sent for each write)
  • {0xDC, 0x08}, //Enable Master BIAS and VMID (VMID and Bandgap enabled on BIAS_EN)
  • {0x0D, 0x01}, //Set ramp rate to nominal
  • {0x0C, 0x03}, //PC_COUNT
  • {0xFC, 0x11}, //MICBIAS_CTRL
  • {0xFD, 0x11}, //MICBIAS_EN
  • /*DA7218 DAI / PLL*/
  • {0xE0, 0x00}, //IO Level 2.5-3.6V
  • {0xE1, 0x80}, //Digital LDO Enabled, 1.05V
  • #if 1
  • {0x91, 0x13}, //PLL_MODE-disable , PLL_MCLK_SQR_EN-enable , PLL INDIV= 18-36MHz
  • #else
  • {0x91, 0x51}, //PLL_MODE-normal , PLL_MCLK_SQR_EN-enable , PLL INDIV= 2-5MHz
  • #endif
  • {0x92, 0x12}, //PLL FRAC TOP
  • {0x93, 0x6E}, //PLL FRAC BOT
  • {0x94, 0x18}, //PLL INTEGER
  • {0x98, 0xC0}, //PLL_REFOSC_CAL
  • {0x0B, 0xBB}, //48kHz sample rate for ADC and DAC
  • #if 1
  • {0x8C, 0xA8}, //DAI Enabled, DAI Channel 1L and 1R enabled,  24 bits per channel, I2S
  • #else
  • {0x8C, 0xA0}, //DAI Enabled, DAI Channel 1L and 1R enabled, 32bit, I2S
  • #endif
  • {0x90, 0x80}, //Master Mode DAI, 64xFS BCLK
  • #if 1
  • {0x8D, 0x40}, //DAI_TDM_CTRL,DAI in normal mode,DAI DATOUT pin is driven when required
  • #else
  • {0x8D, 0xCF}, //DAI_TDM_CTRL
  • #endif
  • {0x8E, 0x00}, //No Offset on DAI (lower)
  • {0x8F, 0x00}, //No Offset on DAI (upper)
  • // {0xAC, 0xF0}, //CP Enabled, Signal Magnitude tracking mode
  • // {0xAD, 0x35}, //CP Delay 64ms
  • // {0xAE, 0x36}, //CP Volume threshold = 0x36
  • /*DA7218 INPUTS*/
  • //Enable Record Path
  • {0xB4, 0x80}, //MIC1 Amp Enabled
  • {0xB8, 0x40}, //MIC2 Amp Disable
  • {0xB5, 0x07}, //MIC1 Gain
  • {0xB9, 0x07}, //MIC2 Gain
  • {0xB7, 0x01}, //MIC_1_P single-ended
  • {0xBB, 0x01}, //MIC2 select 1p
  • {0x2C, 0xA8}, //MIXIN_1 Enabled
  • {0x2E, 0xA8}, //MIXIN_2 Enabled
  • {0x2D, 0x0F}, //MIXIN_1_GAIN
  • {0x2F, 0x0F}, //MIXIN_2_GAIN
  • {0xBD, 0x00}, //Disable IN_2 HPF
  • {0xBC, 0x00}, //Disable IN_1 HPF
  • {0x18, 0xA0}, //INFILT_1_L Enabled
  • {0x1A, 0xA0}, //INFILT_1_L Enabled
  • {0x5C, 0x01}, //INFILT_1_L to DAI_1_L
  • {0x64, 0x04}, //INFILT_2_L to DAI_1_R
  • {0xC0, 0x04}, //ADC_1_CTR
  • {0xC1, 0x04}, //ADC_2_CTRL
  • {0xDC, 0x08}, //References
  • /*MIXERS*/
  • {0x6C, 0x20}, //OUTFILT_1L_SOURCE = DAI INPUT L
  • {0x74, 0x40}, //OUTFILT_1R_SOURCE = DAI INPUT R
  • /*DA7218 OUTPUTS*/
  • {0x72, 0x1C}, //DAI INPUT L GAIN = 0dB
  • {0x7B, 0x1C}, //DAI INPUT L GAIN = 0dB
  • {0xF8, 0x6F}, //OUT_1L_DIGITAL_GAIN GAIN = 0dB
  • {0xF9, 0x6F}, //OUT_1R_DIGITAL_GAIN GAIN = 0dB
  • {0xCC, 0x80}, //MIXOUT_L Enable
  • {0xCE, 0x80}, //MIXOUT_R Enable
  • {0xCD, 0x03}, //MIXOUT_L GAIN = 0dB
  • {0xCF, 0x03}, //MIXOUT_R GAIN = 0dB
  • {0x20, 0x80}, //Enable OUT_1L_FILTER (also enables DACREF)
  • {0x21, 0x80}, //Enable OUT_1R_FILTER
  • {0xD0, 0xFC}, //HP_L Enable, Muted, Ramped
  • {0xD2, 0xFC}, //HP_R Enable, Muted, Ramped
  • {0x5A, 0x00}, //DGS SIGNAL and ANTICLIP level to 0dB
  • {0x54, 0x27}, //Enable DGS
  • #if 1
  • {0xAC, 0xE0}, //Charge pump is enabled
  • {0xD5, 0x00}, //Single-ended output
  • {0xD8, 0x80}, //Accessory detect jack detection enable
  • #endif
  • {0x24, 0x08}, //HP_L Enable, Muted, Ramped
  • //{0xD2, 0xE8}, //HP_R Enable, Muted, Ramped
  • //DELAY 50
  • {0xD0, 0xA8}, //HP_L Enable, Un-muted, Ramped
  • {0xD2, 0xA8}, //HP_R Enable, Un-muted, Ramped
  • {0xE8, 0x07}, //HP_R Enable, Un-muted, Ramped
  • {0xE9, 0x07}, //HP_R Enable, Un-muted, Ramped
回帖(3)
凌云志
2024-4-8 16:10:52
DA7218寄存器设置问题
举报
杨静
2024-4-8 17:25:32
有几种可能的原因导致STM32F412RET+DA7218耳机无输出:
1. DA7218配置错误:请检查DA7218的初始化配置是否正确。确保正确地设置了音频输入和输出通道,并选择了正确的工作模式。
2. 连接问题:请检查连接DA7218的线路是否正确。确保CLKIN、MIC_P、SCLK、LRCK、DATAOUT以及HPL和HPR的连接正确无误。
3. 时钟设置错误:请检查STM32F412RET的时钟设置是否正确。确保正确设置了I2S时钟和时钟源,并且时钟频率与DA7218的配置相匹配。
4. 路径选择问题:请检查电路图中的路径选择,确保信号的路径是正确的,并且没有被其他信号或元件所阻断。
5. 功放配置错误:请检查DA7218的功放配置是否正确。确保使用正确的增益设置,并选择了适当的输出功能和模式。
6. 硬件故障:最后,如果以上所有的检查都正确无误,那么可能是硬件故障导致HPL和HPR没有波形输出。在这种情况下,你可能需要进一步检查硬件电路或更换设备。
希望以上信息能帮助你找到问题所在并解决耳机无输出的问题。如果问题仍然存在,请咨询专业的硬件工程师以获取更详细和准确的诊断和解决方案。
举报
陳嘉詠
2024-8-16 09:47:36
DAI是I2S那些的
你用mic input , headphone output 就不是走DAI吧
举报
更多回帖
