目前手上有个项目,用的是
STM32F205,在使用
tiM2+ADC+DMA模式的时候,发现采样率并不是很正确。
目的是检测待采信号的1K和2K的谐波,因此拟采用8KHz采样率采样512个点,做512的FFT,单点约耗时64ms,4096个点应该耗时在262S左右,但是在DEBUG的时候,发现48S左右就全部完成了;将TIM2的PERIOD改为9999999时,DEBUG可以看到ADC值为1S一次,有没有大神知道问题在哪?
代码如下:
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2022 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "arm_math.h" //添加头文件
#include "arm_const_structs.h"
#define CLK_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8, GPIO_PIN_SET);
#define CLK_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8, GPIO_PIN_RESET);
#define CS_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_SET);
#define CS_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_RESET);
#define UD_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_SET);
#define UD_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_RESET);
#define FFT_LENGTH 512 //FFT长度
#define SAMPLE_FREQ 250000 //采样频率
float fft_inputbuf[FFT_LENGTH*2] = {0}; //FFT输入输出数组,此数组为arm_cfft_radix4_f32的输入输出数组,前一个元素为实部,后一个为虚部,每两个元素代表一个点.
float fft_outputbuf[FFT_LENGTH] = {0}; //arm_cmplx_mag_f32()幅度输出数组
arm_cfft_radix4_instance_f32 scfft; //fft变换的初始化参数
__IO uint8_t AdcConvEnd = 0;
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
#define sine_avg 3
//uint16_t Sine12bit[72] = {
// 124, 135, 146, 156, 167, 177, 186, 195, 204, 212, 219, 226,
// 232, 237, 241, 244, 246, 248, 248, 248, 246, 244, 241, 237,
// 232, 226, 219, 212, 204, 195, 186, 177, 167, 156, 146, 135, 124,
// 113, 103, 92, 82, 72, 62, 53, 44, 36, 29, 22, 17,
// 12, 7, 4, 2, 0, 0, 0, 2, 4, 7, 12, 17,
// 22, 29, 36, 44, 53, 62, 72, 82, 92, 103, 113
//};//200mv ----72points
};//30mv ----72points
uint16_t Sinetosend[72] = {0};
uint16_t ADC_VALUE[512][2] = {0}; //ADC_VALUE[][0]-------PIN 8//ADC_VALUE[][1]-----------PIN10
uint16_t bias_vol, bias_num, bias_last;
uint16_t x, y, firstpoint, secondpoint;
float bias_back_firstwave[4096] = {0};
float bias_back_secondwave[4096] = {0};
float max, min, ratio;
float double_sum_first, double_sum_second;
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
DAC_HandleTypeDef hdac;
DMA_HandleTypeDef hdma_dac2;
TIM_HandleTypeDef htim2;
TIM_HandleTypeDef htim6;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_ADC1_Init(void);
static void MX_DAC_Init(void);
static void MX_TIM6_Init(void);
static void MX_TIM2_Init(void);
/* USER CODE BEGIN PFP */
void RES_DW(uint8_t dat);
void RES_UP(uint8_t dat);
void RES_STOR(void);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
CLK_H;
CS_H;
UD_H;
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC1_Init();
MX_DAC_Init();
MX_TIM6_Init();
MX_TIM2_Init();
/* USER CODE BEGIN 2 */
uint16_t m;
RES_DW(60);
for(m=0; m<72; m++)
Sinetosend[m] = Sine12bit[m] / sine_avg;
HAL_TIM_Base_Start( htim6);
HAL_DAC_Start_DMA( hdac,DAC_CHANNEL_2,(uint32_t *)Sinetosend,72,DAC_ALIGN_12B_R);
// RES_DW(3);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_8, GPIO_PIN_SET);
HAL_Delay(500);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_8, GPIO_PIN_RESET);
HAL_Delay(500);
for(bias_vol = 0; bias_vol < 4095; bias_vol++)
HAL_DAC_Start( hdac,DAC_CHANNEL_1);
HAL_DAC_SetValue( hdac, DAC_CHANNEL_1, DAC_ALIGN_12B_R, bias_vol);
HAL_TIM_Base_Start( htim2);
HAL_ADC_Start_DMA( hadc1, (uint32_t *)ADC_VALUE, 1024);
HAL_Delay(64);
while(!AdcConvEnd);
uint16_t i = 0;
for(i=0;i max)
max = bias_back_firstwave[x];
firstpoint = x;
for(y=0; y < 4095; y++)
if((bias_back_secondwave[y] < min) (bias_back_secondwave[y] > 0))
min = bias_back_secondwave[y];
secondpoint = y;
HAL_DAC_SetValue( hdac, DAC_CHANNEL_1, DAC_ALIGN_12B_R, secondpoint);
HAL_Delay(120000);
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 25;
RCC_OscInitStruct.PLL.PLLN = 240;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
if (HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
Error_Handler();
/** Enables the Clock Security System
HAL_RCC_EnableCSS();
* @brief ADC1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = ENABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T2_TRGO;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 2;
hadc1.Init.DMAContinuousRequests = ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
if (HAL_ADC_Init( hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_12;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_15CYCLES;
if (HAL_ADC_ConfigChannel( hadc1, sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = 2;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
* @brief DAC Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN DAC_Init 0 */
/* USER CODE END DAC_Init 0 */
DAC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN DAC_Init 1 */
/* USER CODE END DAC_Init 1 */
/** DAC Initialization
hdac.Instance = DAC;
if (HAL_DAC_Init( hdac) != HAL_OK)
Error_Handler();
/** DAC channel OUT1 config
sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
if (HAL_DAC_ConfigChannel( hdac, sConfig, DAC_CHANNEL_1) != HAL_OK)
Error_Handler();
/** DAC channel OUT2 config
sConfig.DAC_Trigger = DAC_TRIGGER_T6_TRGO;
sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_DISABLE;
if (HAL_DAC_ConfigChannel( hdac, sConfig, DAC_CHANNEL_2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN DAC_Init 2 */
/* USER CODE END DAC_Init 2 */
* @brief TIM2 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM2_Init 0 */
/* USER CODE END TIM2_Init 0 */
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
/* USER CODE BEGIN TIM2_Init 1 */
/* USER CODE END TIM2_Init 1 */
htim2.Instance = TIM2;
htim2.Init.Prescaler = 5;
htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
htim2.Init.Period = 1249;
htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init( htim2) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource( htim2, sClockSourceConfig) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization( htim2, sMasterConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM2_Init 2 */
/* USER CODE END TIM2_Init 2 */
* @brief TIM6 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM6_Init 0 */
/* USER CODE END TIM6_Init 0 */
/* USER CODE BEGIN TIM6_Init 1 */
/* USER CODE END TIM6_Init 1 */
htim6.Instance = TIM6;
htim6.Init.Prescaler = 0;
htim6.Init.CounterMode = TIM_COUNTERMODE_UP;
htim6.Init.Period = 833;
htim6.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init( htim6) != HAL_OK)
Error_Handler();
if (HAL_TIMEx_MasterConfigSynchronization( htim6, sMasterConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM6_Init 2 */
/* USER CODE END TIM6_Init 2 */
* Enable DMA controller clock
/* DMA controller clock enable */
__HAL_RCC_DMA2_CLK_ENABLE();
__HAL_RCC_DMA1_CLK_ENABLE();
/* DMA interrupt init */
/* DMA1_Stream6_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Stream6_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA1_Stream6_IRQn);
/* DMA2_Stream0_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
* @brief GPIO Initialization Function
* @param None
* @retval None
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_9, GPIO_PIN_RESET);
/*Configure GPIO pins : PA6 PA8 */
GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_8;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(GPIOA, GPIO_InitStruct);
/*Configure GPIO pin : PA7 */
GPIO_InitStruct.Pin = GPIO_PIN_7;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
/*Configure GPIO pins : PB8 PB9 */
GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;
HAL_GPIO_Init(GPIOB, GPIO_InitStruct);
/* USER CODE BEGIN 4 */
uint8_t S0;
UD_H;
HAL_Delay(5);
CS_L;
HAL_Delay(5);
for(S0=dat;S0>0;S0--)
CLK_L;
HAL_Delay(5);
CLK_H;
HAL_Delay(5);
CS_H;
uint8_t S1;
UD_L;
HAL_Delay(5);
CS_L;
HAL_Delay(5);
for(S1=dat;S1>0;S1--)
CLK_L;
HAL_Delay(5);
CLK_H;
HAL_Delay(5);
CS_H;
void RES_STOR(void)
CS_L;
HAL_Delay(5);
CLK_H;
UD_L;
HAL_Delay(5);
UD_H;
HAL_Delay(5);
UD_L;
HAL_Delay(5);
CS_H;
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
