STM32
直播中
小峰
13年用户 972经验值
私信 关注
[问答]
STM32F401使用USART6时不正常,发送HELLO WORLD为乱码怎么解决?
各位大神:
我用STM32F401 进行串口通信,UASRT1跟UASRT2使用正常,使用USART6时不正常,发送HELLO WORLD为乱码怎么破?
代码如下:
main
        SystemInit();
       /*定义一个GPIO_InitTypeDef类型的结构体*/
        GPIO_InitTypeDef                                 GPIO_InitStructure;
        USART_InitTypeDef                         USART_InitStructure;
        USART_ClockInitTypeDef         USART_ClockInitStruct;
        GPIO_Structinit( GPIO_InitStructure);
        //USART_DeInit(USART6);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);  //开启GPIOC时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART6, ENABLE); //开启USART6时钟
        /*USART6管脚复用配置*/
        GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_USART6);//配置复用的引脚,
        GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_USART6);//
        /*配置USART6管脚及相关参数*/
        /*配置GPIOC_Pin6为USART6_TX:输出*/
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;      //设置为复用,必须为AF
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;         //没有上拉和下拉
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;           //输出推免
        GPIO_Init(GPIOC, GPIO_InitStructure);
        /*配置GPIOC_Pin7为USART6_RX:输入*/
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;      //这也必须为复用,与M3不同!
        /*配置USART6*/
        USART_StructInit( USART_InitStructure);       //这个要屏蔽是不行的??
        USART_InitStructure.USART_BaudRate   = 115200;//345600;//115200;//
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits   = USART_StopBits_1;
        USART_InitStructure.USART_Parity     = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode       = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART6,  USART_InitStructure);
        /*使能USART6*/
        USART_ClockStructInit( USART_ClockInitStruct);    //填充外设时钟默认值
        USART_ClockInit(USART6,  USART_ClockInitStruct);  //初始化外设时钟
        USART_ITConfig(USART6, USART_IT_RXNE, ENABLE);    //使能 USART1中断
        USART_Cmd(USART6, ENABLE);
        /*串口6中断配置*/
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);//使能GPIOC时钟
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);           //嵌套优先级分组为 1
        NVIC_InitStructure.NVIC_IRQChannel = USART6_IRQn;         //嵌套通道为USART6_IRQn
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //抢占优先级为 0
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;    //响应优先级为 0
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;       //通道中断使能
        NVIC_Init( NVIC_InitStructure);
        USART_ITConfig(USART6, USART_IT_RXNE, ENABLE);//开启中断
      while
          USART6_TX("Hello world!n");
           delay(0xFFFFF);
VOID USART6_TX(INT8 *usStr)
        while (*usStr)
                USART_SendData(USART6, *usStr++);
                /* 循环发送知道结束*/
                while (USART_GetFlagStatus(USART6, USART_FLAG_TXE) == RESET); //当TXE被置起时,一帧数据传输完成
VOID delay(UINT32 uDelayVal)
        UINT32 uTemp = 0 ;
        for(uTemp=0;uTemp
回帖(2)
李红霞
2024-3-22 11:42:19
这么说吧,对于STM32F401来讲,USART1和USART6特性参数是一样的,如果USART1可以,相同的参数应用到USART6肯定可以的。你不妨检查下管脚以及连接方面,尤其看看有没有搞错管脚了,有时低级错误照样酿成大问题。尽可能使用CubeMx做配置。
举报
丁冬芹
2024-3-22 14:19:42
一种可能的原因是USART6的引脚配置不正确。请确保引脚配置正确,并按照以下步骤进行检查和修复:
1.打开STM32的参考手册,在其GPIO部分找到USART6的引脚配置。
2.确保将这些引脚正确地配置为USART模式,并在初始化GPIO时将它们设置为相应的输出模式、速度和推挽/开漏设置。
3.确保将USART6正确地初始化为所需的波特率、数据位、停止位和校验位。这些设置应与你的通信设备(如电脑)一致。
4.确保你在发送数据之前等待USART6的发送缓冲区为空,以确保数据不会丢失。
另外,还可以尝试使用示波器检查USART6的发送引脚,以确保它们在发送数据时正常工作。如果USART6的引脚配置和初始化都正确,那么很可能是通信设备(如电脑)的接收设置有问题,导致接收到的数据是乱码。在这种情况下,你可能需要检查通信设备的接收设置并进行修复。
举报
更多回帖
