STM32
直播中
李丽
8年用户 1507经验值
私信 关注
[问答]
使用STM32F103C8T6对MKI194V1(LSM6DSR)进行设置,,无法正常读取值的原因?
你好,目前我使用STM32F103C8T6对MKI194V1(LSM6DSR)进行设置,但目前拿到的WhoamI_ID都是0x4A,可否帮忙确认一下是否有我设置错误的地方
SPI Initial
void MX_SPI2_Init(void)
/* USER CODE BEGIN SPI2_Init 0 */
/* USER CODE END SPI2_Init 0 */
/* USER CODE BEGIN SPI2_Init 1 */
/* USER CODE END SPI2_Init 1 */
hspi2.Instance = SPI2;
hspi2.Init.Mode = SPI_MODE_MASTER;
hspi2.Init.Direction = SPI_DIRECTION_2LINES;
hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
hspi2.Init.CLKPolarity = SPI_POLARITY_HIGH;
hspi2.Init.CLKPhase = SPI_PHASE_2EDGE;
hspi2.Init.NSS = SPI_NSS_SOFT;
hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16;
hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi2.Init.CRCPolynomial = 10;
if (HAL_SPI_Init( hspi2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SPI2_Init 2 */
/* USER CODE END SPI2_Init 2 */
// 寫入Register
void LSM6DSR_Core_Write_Reg(TYPE_U08 U08_Reg, TYPE_U08 U08_Val)
TYPE_U08 AxU08_TxBuf[2];
SPI_MKI194_CS_LOW();
AxU08_TxBuf[0] = U08_Reg;
AxU08_TxBuf[1] = U08_Val;
HAL_SPI_Transmit( hspi2, AxU08_TxBuf, 2,1000);
SPI_MKI194_CS_HIGH();
// 讀出Register
TYPE_U08 LSM6DSR_Core_Read_Reg(TYPE_U08 U08_Reg)
TYPE_U08 AxU08_Ret;
U08_Reg |= 0x80;
HAL_SPI_Transmit( hspi2,  U08_Reg, 1,1000);
HAL_SPI_Receive( hspi2,  AxU08_Ret, 1,1000);
return AxU08_Ret;
// 讀出全部Register
void LSM6DSR_Core_Read_All(void)
TYPE_U08 AxU08_i;
for(AxU08_i = 1 ; AxU08_i < 0x7E ; AxU08_i++)
        U08_Reg[AxU08_i] = 0x00;
        U08_Reg[AxU08_i] = LSM6DSR_Core_Read_Reg(AxU08_i);
回帖(1)
江根磊
2024-3-12 13:47:06
不确定是不是你的这一句的问题:
SPI_MKI194_CS_LOW();HAL_SPI_Transmit( hspi2,  U08_Reg, 1,1000);HAL_SPI_Receive( hspi2,  AxU08_Ret, 1,1000);SPI_MKI194_CS_HIGH();
你可以试试它的另一个函数HAL_SPI_TransmitReceive.
举报
更多回帖
