我自己根据网上的步骤在GD32F350G8裸机上移植RT_thread,程序可以跑进main函数,但是用rt_kprintf不能输出打印信息。平台Keil uVision5,我自己搞了一星期还是解决不了,请帮帮我,谢谢。附件是完整的工程文件。
* File : drv_usart.c
* This file is part of RT-Thread RTOS
* COPYRIGHT (C) 2009, RT-Thread Development Team
* The license and distribu
tion terms for this file may be
* found in the file LICENSE in this distribution or at
* Change Logs:
* Date Author Notes
* 2009-01-05 Bernard the first version
* 2018-04-19 misonyo Porting for gd32f30x
#include
#include
#include
#include "gd32f3x0.h"
#ifdef RT_USING_SERIAL
#define UART_ENABLE_IRQ(n) NVIC_EnableIRQ((n))
#define UART_DISABLE_IRQ(n) NVIC_DisableIRQ((n))
#if !defined(RT_USING_USART0) && !defined(RT_USING_USART1) && \
!defined(RT_USING_USART2) && !defined(RT_USING_UART3) && \
!defined(RT_USING_UART4)
#error "Please define at least one UARTx"
#endif
#include
/* GD32 uart driver */
// Todo: compress uart info
struct gd32_uart
uint32_t uart_periph;
IRQn_Type irqn;
rcu_periph_enum per_clk;
rcu_periph_enum tx_gpio_clk;
rcu_periph_enum rx_gpio_clk;
uint32_t tx_port;
uint16_t tx_pin;
uint32_t rx_port;
uint16_t rx_pin;
struct rt_serial_device * serial;
char *device_name;
static void uart_isr(struct rt_serial_device *serial);
#if defined(RT_USING_USART0)
struct rt_serial_device serial0;
void USART0_IRQHandler(void)
/* enter interrupt */
rt_interrupt_enter();
uart_isr(&serial0);
/* leave interrupt */
rt_interrupt_leave();
#endif /* RT_USING_USART0 */
#if defined(RT_USING_USART1)
struct rt_serial_device serial1;
void USART1_IRQHandler(void)
uart_isr(&serial1);
#endif /* RT_USING_UART1 */
#if defined(RT_USING_USART2)
struct rt_serial_device serial2;
void USART2_IRQHandler(void)
uart_isr(&serial2);
#endif /* RT_USING_UART2 */
#if defined(RT_USING_UART3)
struct rt_serial_device serial3;
void UART3_IRQHandler(void)
uart_isr(&serial3);
#endif /* RT_USING_UART3 */
#if defined(RT_USING_UART4)
struct rt_serial_device serial4;
void UART4_IRQHandler(void)
uart_isr(&serial4);
#endif /* RT_USING_UART4 */
static const struct gd32_uart uarts[] = {
#ifdef RT_USING_USART0
USART0, // uart peripheral index
USART0_IRQn, // uart iqrn
RCU_USART0, RCU_GPIOA, RCU_GPIOA, // periph clock, tx gpio clock, rt gpio clock
GPIOA, GPIO_PIN_9, // tx port, tx pin
GPIOA, GPIO_PIN_10, // rx port, rx pin
&serial0,
"uart0",
#endif
#ifdef RT_USING_USART1
USART1_IRQn, // uart iqrn
RCU_USART1, RCU_GPIOA, RCU_GPIOA, // periph clock, tx gpio clock, rt gpio clock
GPIOA, GPIO_PIN_2, // tx port, tx pin
GPIOA, GPIO_PIN_3, // rx port, rx pin
&serial1,
"uart1",
#endif
#ifdef RT_USING_USART2
USART2, // uart peripheral index
USART2_IRQn, // uart iqrn
RCU_USART2, RCU_GPIOB, RCU_GPIOB, // periph clock, tx gpio clock, rt gpio clock
GPIOB, GPIO_PIN_10, // tx port, tx alternate, tx pin
GPIOB, GPIO_PIN_11, // rx port, rx alternate, rx pin
&serial2,
"uart2",
#endif
#ifdef RT_USING_UART3
UART3, // uart peripheral index
UART3_IRQn, // uart iqrn
RCU_UART3, RCU_GPIOC, RCU_GPIOC, // periph clock, tx gpio clock, rt gpio clock
GPIOC, GPIO_PIN_10, // tx port, tx alternate, tx pin
GPIOC, GPIO_PIN_11, // rx port, rx alternate, rx pin
&serial3,
"uart3",
#endif
#ifdef RT_USING_UART4
UART4, // uart peripheral index
UART4_IRQn, // uart iqrn
RCU_UART4, RCU_GPIOC, RCU_GPIOD, // periph clock, tx gpio clock, rt gpio clock
GPIOC, GPIO_PIN_12, // tx port, tx alternate, tx pin
GPIOD, GPIO_PIN_2, // rx port, rx alternate, rx pin
&serial4,
"uart4",
#endif
* @brief UART MSP Initialization
* This function configures the hardware resources used in this example:
* - Peripheral's clock enable
* - Peripheral's GPIO Configuration
* - NVIC configuration for UART interrupt request enable
* @param uart: UART handle pointer
* @retval None
void gd32_uart_gpio_init(struct gd32_uart *uart)
/* enable USART clock */
rcu_periph_clock_enable(uart->tx_gpio_clk);
rcu_periph_clock_enable(uart->rx_gpio_clk);
rcu_periph_clock_enable(uart->per_clk);
/* connect port to USARTx_Tx */
//gpio_init(uart->tx_port, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, uart->tx_pin);
gpio_mode_set(uart->tx_port, GPIO_MODE_AF, GPIO_PUPD_PULLUP, uart->tx_pin);
gpio_output_options_set(uart->tx_port, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, uart->tx_pin);
/* connect port to USARTx_Rx */
//gpio_init(uart->rx_port, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, uart->rx_pin);
gpio_mode_set(uart->rx_port, GPIO_MODE_AF, GPIO_PUPD_PULLUP, uart->rx_pin);
gpio_output_options_set(uart->rx_port, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, uart->rx_pin);
NVIC_SetPriority(uart->irqn, 0);
NVIC_EnableIRQ(uart->irqn);
static rt_err_t gd32_configure(struct rt_serial_device *serial, struct serial_configure *cfg)
struct gd32_uart *uart;
RT_ASSERT(serial != RT_NULL);
RT_ASSERT(cfg != RT_NULL);
uart = (struct gd32_uart *)serial->parent.user_data;
gd32_uart_gpio_init(uart);
usart_baudrate_set(uart->uart_periph, cfg->baud_rate);
switch (cfg->data_bits)
case DATA_BITS_9:
usart_word_length_set(uart->uart_periph, USART_WL_9BIT);
break;
default:
usart_word_length_set(uart->uart_periph, USART_WL_8BIT);
break;
switch (cfg->stop_bits)
case STOP_BITS_2:
usart_stop_bit_set(uart->uart_periph, USART_STB_2BIT);
break;
default:
usart_stop_bit_set(uart->uart_periph, USART_STB_1BIT);
break;
switch (cfg->parity)
case PARITY_ODD:
usart_parity_config(uart->uart_periph, USART_PM_ODD);
break;
case PARITY_EVEN:
usart_parity_config(uart->uart_periph, USART_PM_EVEN);
break;
default:
usart_parity_config(uart->uart_periph, USART_PM_NONE);
break;
usart_receive_config(uart->uart_periph, USART_RECEIVE_ENABLE);
usart_transmit_config(uart->uart_periph, USART_TRANSMIT_ENABLE);
usart_enable(uart->uart_periph);
return RT_EOK;
static rt_err_t gd32_control(struct rt_serial_device *serial, int cmd, void *arg)
switch (cmd)
case RT_DEVICE_CTRL_CLR_INT:
/* disable rx irq */
NVIC_DisableIRQ(uart->irqn);
/* disable interrupt */
usart_interrupt_disable(uart->uart_periph, USART_INT_RBNE);
break;
case RT_DEVICE_CTRL_SET_INT:
/* enable rx irq */
/* enable interrupt */
usart_interrupt_enable(uart->uart_periph, USART_INT_RBNE);
break;
return RT_EOK;
static int gd32_putc(struct rt_serial_device *serial, char ch)
usart_data_transmit(uart->uart_periph, ch);
while((usart_flag_get(uart->uart_periph, USART_FLAG_TC) == RESET));
return 1;
static int gd32_getc(struct rt_serial_device *serial)
int ch;
ch = -1;
if (usart_flag_get(uart->uart_periph, USART_FLAG_RBNE) != RESET)
ch = usart_data_receive(uart->uart_periph);
return ch;
* Uart common interrupt process. This need add to uart ISR.
* @param serial serial device
struct gd32_uart *uart = (struct gd32_uart *) serial->parent.user_data;
RT_ASSERT(uart != RT_NULL);
/* UART in mode Receiver */
if ((usart_interrupt_flag_get(uart->uart_periph, USART_INT_FLAG_RBNE) != RESET) &&
(usart_flag_get(uart->uart_periph, USART_FLAG_RBNE) != RESET))
rt_hw_serial_isr(serial, RT_SERIAL_EVENT_RX_IND);
/* Clear RXNE interrupt flag */
usart_flag_clear(uart->uart_periph, USART_FLAG_RBNE);
static const struct rt_uart_ops gd32_uart_ops =
gd32_configure,
gd32_control,
gd32_putc,
gd32_getc
int gd32_hw_usart_init(void)
struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT;
int i;
for (i = 0; i < sizeof(uarts) / sizeof(uarts[0]); i++)
uarts
.serial->ops = &gd32_uart_ops;
uarts.serial->config = config;
/* register UART device */
rt_hw_serial_register(uarts.serial,
uarts.device_name,
RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX,
(void *)&uarts);
return 0;
INIT_BOARD_EXPORT(gd32_hw_usart_init);
#endif
