单片机/MCU论坛
直播中
李玉兰
8年用户 1562经验值
私信 关注
[问答]
使用ADuC7060的PWM1端口输出PWM脉冲,断电后再上电导致PWM输出异常,怎么解决?
我打算使用ADuC7060的PWM1端口输出PWM脉冲,单端输出,占空比是50%,周期是100μS,在用Keil调试时能正常输出我所需要的PWM脉冲,后来断电后再上电却发现PWM输出异常,主要是占空比异常,周期还是正常的。后来我将官方的PWM程序烧写进去后再将我的PWM测试程序烧写到芯片中后又正常了,但是一断电再上电就出现异常了。
请问大虾这是什么造成的。解决方式是什么?
下面附上我的PWM测试程序:
int main(void)
      POWKEY1 = 0x1;
      POWCON0 = 0x78;     // Set core to max CPU speed of 10.24Mhz
      POWKEY2 = 0xF4;
  // Initialize the GPIO pins for PWM mode
      GP0CON0 = BIT16;    // Select PWM1 output
     PWMCON = BIT0;  // PWM Standard mode, UCLK/2
      PWM0COM2 = 0x80;  // Configure PWM1 output low trigger time
     PWM0LEN = 0xFF;  // Configure PWM1 output high trigger time
  while (1)
官方的PWM程序:
unsigned char bTripDetected = 0;
int main(void)
  POWKEY1 = 0x1;
POWKEY2 = 0xF4;
// GP1CON  = BIT8 + BIT12  // Select PWMSYNC and PWMTRIP functions
//   + BIT16 + BIT20  // Select PWM2, PWM3 output
//   + BIT24;   // Select PWM4 output
// GP2CON  = BIT0 + BIT4;  // Select PWM0 and PWM5 output
PWMCON = BIT0 + BIT10;  // PWM Standard mode, UCLK/2, PWM Trip interrupt enabled
ConfigurePWM();   // Call function to configure PWM
bTripDetected = 0;
IRQEN = BIT17;   // Enable PWM Trip interrupt source
while (1)
    if (bTripDetected == 1)
      bTripDetected = 0;
      ConfigurePWM();
void IRQ_Handler(void) __irq  // Unused in this application
   unsigned long IRQSTATUS = 0;
  IRQSTATUS = IRQSTA;    // Read off IRQSTA register
  if ((IRQSTATUS   BIT17) == BIT17) //If PWM trip interrupt source
   bTripDetected = 1;  // Set flag to re configure the PWM block
   PWMCLRI = 0xFF;  // Clear the PWM trip interrupt source
void ConfigurePWM(void)
   //Configure PWM0 for 20khz duty cycle
   // P0.4
PWM0COM0 = 0x80;  // Configure PWM0 output high trigger time
PWM0COM1 = 0xFF;  // Configure PWM0 output Low trigger time
// PWM0COM2 = 0x80;  // Configure PWM1 output low trigger time
/* //Configure PWM2 for 10khz duty cycle
// P1.5
PWM1COM0 = 0xFF;  // Configure PWM2 output high trigger time
PWM1COM1 = 0x1FF;  // Configure PWM2 output Low trigger time
PWM1COM2 = 0xFF;  // Configure PWM3 output low trigger time
PWM1LEN = 0x1FF;  // Configure PWM3 output high trigger time
  //Configure PWM4 for 40khz duty cycle
// P2.1
PWM2COM0 = 0x40;  // Configure PWM4 output high trigger time
PWM2COM1 = 0x80;  // Configure PWM4 output Low trigger time
PWM2COM2 = 0x40;  // Configure PWM5 output low trigger time
PWM2LEN = 0x80;  // Configure PWM6 output high trigger time
回帖(1)
郑成枝
2024-1-15 13:49:20
出现PWM输出异常的原因可能是芯片在断电后重新上电时,部分寄存器的值没有恢复到默认状态。解决这个问题的方式是在初始化PWM前,先对相关寄存器进行恢复操作。
你可以尝试在程序的开头添加如下代码,将相关寄存器恢复到默认状态,然后再配置PWM输出:
void reset_registers(void)
    // 将相关寄存器恢复到默认状态
    PWMCON0 = 0;
    PWMCON1 = 0;
    PWMCON2 = 0;
    PWMTH0 = 0;
    PWMTH1 = 0;
    PWMTH2 = 0;
    PWMADR0 = 0;
    PWMADR1 = 0;
    PWMADR2 = 0;
int main(void)
    // 调用恢复寄存器函数
    reset_registers();
    // 后续的代码继续配置和输出PWM信号
通过执行上述代码,在重新上电后可以将相关寄存器恢复到默认状态,避免出现PWM输出异常的情况。
举报
更多回帖
