赛昉科技
直播中
颜立歆
9年用户 1033经验值
擅长:控制/MCU
私信 关注
[问答]
VF2更新flash spl和ubootQSPL启动sd卡失败怎么解决?
串口信息如下:
U-Boot SPL 2021.10 (Sep 26 2023 - 22:53:52 +0800)
LPDDR4: 4G version: g8ad50857.
Trying to boot from SPI
OpenBI v1.2
/ __                   / |  _ _   |
| |  | | __   ___ _ __ | (
| |  | | '_  / _  '_  ___ |  _ < | |
| || | |) |  __/ | | |) | |) || |
_
/| ./ _|| ||/|/___|
|_|
Platform Name             : StarFive VisionFive V2
Platform Features         : medeleg
Platform HART Count       : 5
Platform IPI Device       : aclint-mswi
Platform timer Device     : aclint-mtimer @ 4000000Hz
Platform Console Device   : uart8250
Platform HSM Device       : —
Platform PMU Device       : —
Platform Reboot Device    : pm-reset
Platform Shutdown Device  : pm-reset
Platform Suspend Device   : —
Firmware Base             : 0x40000000
Firmware Size             : 392 KB
Firmware RW Offset        : 0x40000
Runtime SBI Version       : 1.0
Domain0 Name              : root
Domain0 Boot HART         : 1
Domain0 HARTs             : 0*,1*,2*,3*,4*
Domain0 Region00          : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region01          : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region02          : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: ()
Domain0 Region03          : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X)
Domain0 Next Address      : 0x0000000040200000
Domain0 Next Arg1         : 0x0000000042200000
Domain0 Next Mode         : S-mode
Domain0 SysReset          : yes
Domain0 SysSuspend        : yes
Boot HART ID              : 1
Boot HART Domain          : root
Boot HART Priv Version    : v1.11
Boot HART Base ISA        : rv64imafdcbx
Boot HART ISA Extensions  : none
Boot HART PMP Count       : 8
Boot HART PMP Granularity : 4096
Boot HART PMP Address Bits: 34
Boot HART MHPM Count      : 2
Boot HART MIDELEG         : 0x0000000000000222
Boot HART MEDELEG         : 0x000000000000b109
U-Boot 2021.10 (Sep 26 2023 - 22:53:52 +0800), Build: jenkins-github_visionfive2-18
CPU:   rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM:  4 GiB
MMC:   sdio0@16010000: 0, sdio1@16020000: 1
Loading Environment from SPIFlash… SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
StarFive EEPROM format v2
--------EEPROM INFO--------
Vendor : StarFive Technology Co., Ltd.
Product full SN: VF7110B1-2310-D004E000-00001875
data version: 0x2
PCB revision: 0xb2
BOM revision: A
Ethernet MAC0 address: 6c:cf:39:00:53:14
Ethernet MAC1 address: 6c:cf:39:00:53:15
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@16030000, eth1: ethernet@16040000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Try booting from MMC1 …
Failed to load ‘vf2_uEnv.txt’
Warning: Input data exceeds 1048576 bytes - truncated
Info: input data size = 1048578 = 0x100002
Error: “boot2” not defined
Card did not respond to voltage select! : -110
starfive_pcie pcie@2B000000: Port link up.
starfive_pcie pcie@2B000000: Starfive PCIe bus probed.
PCI: Failed autoconfig bar 10
starfive_pcie pcie@2C000000: Port link down.
starfive_pcie pcie@2C000000: Starfive PCIe bus probed.
Device 0: unknown device
Tring booting distro …
Failed to load ‘/uEnv.txt’
Warning: defaulting to text format
Failed to load ‘/dtbs/starfive/jh7110-visionfive-v2.dtb’
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
fatwrite - write file into a dos filesystem
Usage:
fatwrite     [ []]
- write file ‘filename’ from the address ‘addr’ in RAM
to ‘dev’ on ‘interface’
Retrieving file: /extlinux/extlinux.conf
Failed to load ‘/extlinux/extlinux.conf’
Error reading config file
StarFive #
以下内容为评论
设备都装了什么?
我看提示信息, PCI-E 识别失败后,就去启动 MMC1 设备了。MMC1 上面没有找到需要的文件后就启动失败了。MMC1 应该是 emmc 模块吧? MMC1 的 #0 分区被当作存储文件的设备。
mmc1是TF卡,镜像是openwrt
看看数据位置,反正提示是 uEnv.txt 和 extlinux/extlinux.conf 都有问题。
这两个都是在同一个分区里面。提示是在 0 分区里面找的。
PS:好像 VF2 有 TF 卡的兼容问题。有些卡读取不了数据。
回帖(1)
万航渡路
2024-1-11 09:56:27
根据您提供的串口信息,可以看到 U-Boot SPL(Secondary Program Loader)正在尝试从 SPI 启动。请按照以下步骤解决启动失败的问题:
1. 检查 SD 卡
确保您的 SD 卡已插好并且可读写。可以尝试将 SD 卡插入另一个设备或计算机上,确保它可以正常工作。
2. 检查启动设置
确保您的启动设置正确。您可以使用命令 `printenv` 查看当前的 U-Boot 环境变量,并验证启动配置是否正确。
3. 检查 SPL 和 U-Boot 版本
确保您使用的 SPL 和 U-Boot 版本与您的硬件兼容。尝试将 SPL 和 U-Boot 更新为最新版本,可以从供应商或开发者的官方网站获取最新版本。
4. 检查设备树和启动脚本
确保您使用的设备树和启动脚本与您的硬件和操作系统匹配。确保设备树文件(.dtb)和启动脚本(.boot.scr 或 .ext3.scr)正确且位于正确的路径。
5. 检查启动设备顺序
如果 SPI 启动失败,可以尝试更改启动设备顺序。可以通过 `sf probe 0` 命令将 SPI 设备注册为 U-Boot 的启动设备,然后尝试从 SD 卡启动。
6. 检查启动日志
如果您还能获取更多的启动日志信息,可以查看它们以获取更多的线索和错误消息。尝试使用其他调试工具或方法获取更详细的启动日志。
以上步骤可能需要一定的技术知识和操作。如果您不确定如何进行操作,建议联系设备供应商或开发者进行进一步的支持和指导。
举报
更多回帖
