各位好!我用ADXL345出现问题,一筹莫展,查不出问题所在。
mcu用stc15w102,IIC读写。
主函数中如果没有“devid = ADXL_ReadOneByte(0x00);”语句,串口发送“COMM_SendOneByte(0xA5);”发送到电脑上串口助手的数据正常;如果加上“devid = ADXL_ReadOneByte(0x00);”语句,串口发送“COMM_SendOneByte(0xA5);”发送到电脑上串口助手的数据就不正常。说明是ADXL_ReadOneByte(xxx);程序有问题。但反反复复检查就是查不出来问题所在。请大家帮助,不胜感谢!下面是相关程序:
// Use mcu STC15W102
void Dly5us(void) //@11.0592MHz
uchr i;
nop_();
//i = 11;
i = 8;
while (--i);
void ADXL_StrtTrans(void)
SDA_TXD = 1;
SCL = 1;
Dly5us();
SDA_TXD = 0;
Dly5us();
SCL = 0;
//Dly5us(); // tem
void ADXL_StopTrans(void)
SDA_TXD = 0;
SCL = 1;
Dly5us();
SDA_TXD = 1;
Dly5us();
//SCL = 0; // tem
void ADXL_WritAck(bit ack)
SDA_TXD = ack;
SCL = 1;
Dly5us();
SCL = 0;
Dly5us();
//SDA_TXD = !SDA_TXD; // tem
bit ADXL_ReadAck(void)
//SDA_TXD = 1; // tem
SCL = 1;
Dly5us();
CY = SDA_TXD;
SCL = 0;
Dly5us();
return CY;
void ADXL_WritEightBit(uchr dat)
uchr i;
for (i=0; i<8; i++)
dat <<= 1;
SDA_TXD = CY;
//Dly5us(); // tem
SCL = 1;
Dly5us();
SCL = 0;
Dly5us(); //
ADXL_ReadAck(); //
uchr ADXL_ReadEightBit(void)
uchr i;
uchr dat = 0;
SDA_TXD = 1;
for (i=0; i<8; i++)
dat <<= 1; //
SCL = 1;
Dly5us();
dat |= SDA_TXD;
//dat <<= 1; // tem
SCL = 0;
Dly5us();
return dat;
void ADXL_WriteOneByte(uchr AdxlRegAddr,uchr EightBitData)
ADXL_StrtTrans(); // ADXL345 start transmission
ADXL_WritEightBit(ADXL_SLV_ADDR); // write the IIC slave address of device into ADXL345
//ADXL_ReadAck(); // tem
ADXL_WritEightBit(AdxlRegAddr); // write the register address into ADXL345
ADXL_WritEightBit(EightBitData); // write the data into register of ADXL345
ADXL_StopTrans(); // ADXL345 stop transmission
uchr ADXL_ReadOneByte(uchr AdxlRegAddr)
uchr AdxlReadDatBuf;
ADXL_WritEightBit(ADXL_SLV_ADDR+1); // write the IIC slave address of device into ADXL345
AdxlReadDatBuf = ADXL_ReadEightBit(); // register data in ADXL345 is readed out
ADXL_WritAck(1); // Send ACK to ADXL345
return AdxlReadDatBuf;
void ADXL_Init(void)
ADXL_WriteOneByte(ADXL_DATA_FORMAT, 0x0B); //Set DATA_FORMAT:mesurement scope,+ or - 16 gram,13 bit mode.
ADXL_WriteOneByte(ADXL_BW_RATE, 0x08); //Set BW_RATE:Rate = 25Hz.
ADXL_WriteOneByte(ADXL_POWER_CTL, 0x08); //Set POWER_CTL:mesurement mode is started.
ADXL_WriteOneByte(ADXL_INT_ENABLE, 0x80); //Set INT_ENABLE:DATA_READY interrupt is inhibit.
ADXL_WriteOneByte(ADXL_OFFSETX, 0x00); //Set ADXL_OFFSETX.
ADXL_WriteOneByte(ADXL_OFFSETY, 0x00); //Set ADXL_OFFSETY.
ADXL_WriteOneByte(ADXL_OFFSETZ, 0x05); //Set ADXL_OFFSETZ.
void main(void)
ADXL_Init();
while(1)
