瑞芯微Rockchip开发者社区
直播中
jf_63320655
1年用户 4经验值
擅长:可编程逻辑 嵌入式技术
私信 关注
[问答]
firefly rk3399网络配置后无法通信怎么办?
我网络都配置好了,网线也插到别的板子试过了可以通信,网口也在闪烁,就是ping不通,ping 自己的地址是通的
下面是我的截图:
windows的网络配置:
以太网适配器 以太网:
   连接特定的 DNS 后缀 . . . . . . . :
   本地链接 IPv6 地址. . . . . . . . : fe80::4de2:c306:c102:a3b4%14
   IPv4 地址 . . . . . . . . . . . . : 192.168.1.241
   子网掩码  . . . . . . . . . . . . : 255.255.255.0
   IPv4 地址 . . . . . . . . . . . . : 192.168.52.11
   IPv4 地址 . . . . . . . . . . . . : 192.168.100.241
   IPv4 地址 . . . . . . . . . . . . : 192.168.100.243
   默认网关. . . . . . . . . . . . . : 192.168.100.254
firefly开发板的网络配置:
root@firefly:/# cat etc/netplan/config.yaml
# Let NetworkManager manage all devices on this system
network:
  version: 2
  renderer: NetworkManager
  ethernets:
    eth0:
      addresses:
        - 192.168.100.58/24
      nameservers:
        addresses: [8.8.8.8]
      routes:
        - to: 0.0.0.0/0
          via: 192.168.100.254
root@firefly:/# netplan  apply
ifconfig的详情:
root@firefly:/# ifconfig
eth0: flags=4163  mtu 1500
        inet 192.168.100.58  netmask 255.255.255.0  broadcast 192.168.100.255
        inet6 fe80::d861:17ff:feda:15ad  prefixlen 64  scopeid 0x20
        ether da:61:17:da:15:ad  txqueuelen 1000  (Ethernet)
        RX packets 951  bytes 57355 (57.3 KB)
        RX errors 462  dropped 50  overruns 0  frame 462
        TX packets 113  bytes 16984 (16.9 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 24
lo: flags=73  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10
        loop  txqueuelen 1  (Local Loopback)
        RX packets 730  bytes 54856 (54.8 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 730  bytes 54856 (54.8 KB)
wlan0: flags=4099  mtu 1500
        ether c0:84:7d:95:d6:c6  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
路由表信息:
root@firefly:/# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.100.254 0.0.0.0         UG    100    0        0 eth0
192.168.100.0   0.0.0.0         255.255.255.0   U     100    0        0 eth0
防火墙信息:
root@firefly:/# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
ping 不同IP的结果
root@firefly:/# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
From 192.168.100.58 icmp_seq=6 Destination Host Unreachable
From 192.168.100.58 icmp_seq=7 Destination Host Unreachable
From 192.168.100.58 icmp_seq=8 Destination Host Unreachable
From 192.168.100.58 icmp_seq=9 Destination Host Unreachable
^C
--- 8.8.8.8 ping statistics ---
11 packets transmitted, 0 received, +4 errors, 100% packet loss, time 10001ms
pipe 4
root@firefly:/# ping baidu.com
ping: baidu.com: Temporary failure in name resolution
ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.077 ms
64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.128 ms
64 bytes from 127.0.0.1: icmp_seq=3 ttl=64 time=0.130 ms
希望大佬能帮一下,不甚感激
回帖(1)
郝埃连
2023-9-21 16:11:47
如果您的Firefly RK3399网络配置好了,但无法通信,可以尝试以下措施:
1. 检查防火墙设置:确保防火墙没有阻止通信,禁用防火墙或设置允许通信的规则。
2. 检查网卡设置:确保网卡配置正确,包括IP地址、子网掩码、网关等。
3. 检查网络连接:确保网络连接正常,可以尝试重启路由器或交换机等设备。
4. 检查网络协议:确保使用正确的网络协议,例如TCP/IP,可以尝试更换协议或检查配置是否正确。
5. 检查网络硬件:如果以上方法都无效,可能是硬件问题,可以尝试更换网卡或联系供应商解决。
举报
更多回帖
