各位大大安安,我想请问在官方SPI FIFO Mode范例里,Tx 和 Rx都使用FIFO传输,其中enable "SPI_FIFO_TX_INT_MASK"这项中断功能主要是什么意思
在IRQHandler动作是什么,谢谢!
/* Set TX FIFO threshold, enable TX FIFO threshold interrupt and RX FIFO
time-out interrupt */
SPI_EnableFIFO(SPI0, 4, 4);
SPI_EnableInt(SPI0, SPI_FIFO_TX_INT_MASK | SPI_FIFO_TIMEOUT_INT_MASK);
void SPI0_IRQHandler(void)
/* Check RX EMPTY flag */
while(SPI_GET_RX_FIFO_EMPTY_FLAG(SPI0) == 0)
/* Read RX FIFO */
g_au32DestinationData[g_u32RxDataCount++] = SPI_READ_RX0(SPI0);
/* Check TX FULL flag and TX data count */
while((SPI_GET_TX_FIFO_FULL_FLAG(SPI0) == 0) (g_u32TxDataCount < TEST_COUNT))
/* Write to TX FIFO */
SPI_WRITE_TX0(SPI0, g_au32SourceData[g_u32TxDataCount++]);
if(g_u32TxDataCount >= TEST_COUNT)
SPI_DisableInt(SPI0, SPI_FIFO_TX_INT_MASK); /* Disable TX FIFO threshold interrupt */
/* Check the RX FIFO time-out interrupt flag */
if(SPI_GetIntFlag(SPI0, SPI_FIFO_TIMEOUT_INT_MASK))
/* If RX FIFO is not empty, read RX FIFO. */
while((SPI0->STATUS SPI_STATUS_RX_EMPTY_Msk) == 0)
