新唐MCU技术
直播中
陈飞
8年用户 1249经验值
私信 关注
[问答]
UART0想使用64 Bytes FIFO该如何设定?
官方TRM中提到NUC230/240的UART0有提供到64 Bytes的接收缓冲区,UART1及UART2只提供了16Bytes的接收缓冲区,但uart.h文件中RFITL设定仅供到14 Bytes
想问如果想使用64 Bytes FIFO该如何设定,谢谢
/* UART FIFO size constants definitions        */
#define UART0_FIFO_SIZE 64 /*!< UART0 supports separated receive/transmit 64/64 bytes entry FIFO */
#define UART1_FIFO_SIZE 16 /*!< UART1 supports separated receive/transmit 16/16 bytes entry FIFO */
#define UART2_FIFO_SIZE 16 /*!< UART2 supports separated receive/transmit 16/16 bytes entry FIFO */
/* UA_FCR constants definitions        */
#define UART_FCR_RFITL_1BYTE        (0x0 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 1 bit */
#define UART_FCR_RFITL_4BYTES       (0x1 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 4 bits */
#define UART_FCR_RFITL_8BYTES       (0x2 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 8 bits */
#define UART_FCR_RFITL_14BYTES      (0x3 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 14 bits */
#define UART_FCR_RTS_TRI_LEV_1BYTE        (0x0 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 1 bit */
#define UART_FCR_RTS_TRI_LEV_4BYTES       (0x1 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 4 bits */
#define UART_FCR_RTS_TRI_LEV_8BYTES       (0x2 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 8 bits */
#define UART_FCR_RTS_TRI_LEV_14BYTES      (0x3 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 14 bits */
回帖(1)
顾鸿兰
2023-8-21 10:28:26
uart.h里宏定义没定时64字节的,可以直接写数字修改寄存器的值,也可以自己先添加上宏定义再调用
举报
更多回帖
