以下是一个使用Ctimer计数器捕获输入脉冲的示例程序:
```c
#include "board.h"
#define CTIMER_CLK_FREQ (20971520UL)
void ctimer_init(void)
/* Enable the clock for CTIMER0 */
clock_enable_clock(LPC_CTIMER0);
/* Set the prescaler to generate 1 MHz clock */
CTIMER0->PR = (CTIMER_CLK_FREQ / 1000000UL) - 1;
/* Set the match register 0 to generate a match every second */
CTIMER0->MR0 = 1000000 - 1;
/* Reset the timer counter and the prescaler */
CTIMER0->TCR |= CTIMER_TCR_CR;
/* Enable the interrupt for match register 0 */
CTIMER0->MCR |= (1 << CTIMER_MCR_MR0I);
/* Start the timer */
CTIMER0->TCR |= CTIMER_TCR_CE;
void ctimer_capture_init(void)
/* Enable the clock for CTIMER3 */
clock_enable_clock(LPC_CTIMER3);
/* Set P1.11 as CTIMER3_CAP3 */
PinSetMode(PIN_1_11, PIN_CAP3);
/* Set the prescaler for CTIMER3 to generate 1 MHz clock */
CTIMER3->PR = (CTIMER_CLK_FREQ / 1000000UL) - 1;
/* Set CTIMER3 to count on rising edges on CAP3 */
CTIMER3->CCR |= (1 << CTIMER_CCR_CAP3RE);
/* Enable the interrupt for CTIMER3 */
NVIC_EnableIRQ(CTIMER3_IRQn);
CTIMER3->TCR |= CTIMER_TCR_CE;
uint32_t ctimer_get_capture(void)
return CTIMER3->CR3;
void ctimer_reset_capture(void)
CTIMER3->CCR |= (1 << CTIMER_CCR_CAP3R);
void CTIMER3_IRQHandler(void)
/* If a capture occurred, reset the capture register */
if (CTIMER3->IR & (1 << CTIMER_IR_CR3INT))
CTIMER3->IR |= (1 << CTIMER_IR_CR3INT);
ctimer_reset_capture();
int main(void)
ctimer_init();
ctimer_capture_init();
while (1)
/* Wait for a capture event */
while (!(CTIMER3->IR & (1 << CTIMER_IR_CR3INT)));
/* Get the captured value and do something with it */
uint32_t capture_val = ctimer_get_capture();
// Do something with capture_val
该程序使用CTIMER0定时器来生成匹配事件,从而触发CTIMER3计数器进行捕获。CTIMER3计数器通过设置CCR寄存器,使它在每个上升沿上捕获输入脉冲。捕获发生后,将在CTIMER3中断处理程序中重置捕获寄存器,并在主循环中使用捕获值进行操作。
```c
#include "board.h"
int main(void)
ctimer_init();
while (1)
举报
