CH32V208搭载V4C内核,片上集成2Mbps低功耗蓝牙BLE 通讯模块。
平台:
MounRiver Studio
硬件
CH32V208开发板
带蓝牙的手机
电脑
软件
串口助手
BLE Scanner
示例
EVT\EXAM\BLE\Periphera
核心代码:
初始:
Peripheral_TaskID = TMOS_ProcessEventRegister(Peripheral_ProcessEvent);
// Setup the GAP Peripheral Role Profile
uint8_t initial_advertising_enable = TRUE;
uint16_t desired_min_interval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
uint16_t desired_max_interval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
// Set the GAP Role Parameters
GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t), &initial_advertising_enable);
GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData), scanRspData);
GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t), &desired_min_interval);
GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t), &desired_max_interval);
// Set the GAP Characteristics
GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
// Set advertising interval
GAP_SetParamValue(TGAP_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_DISC_ADV_INT_MAX, advInt);
// Enable scan req notify
GAP_SetParamValue(TGAP_ADV_SCAN_REQ_NOTIFY, ENABLE);
// Setup the GAP Bond Manager
uint32_t passkey = 0; // passkey "000000"
uint8_t pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
uint8_t mitm = TRUE;
uint8_t bonding = TRUE;
uint8_t ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
GAPBondMgr_SetParameter(GAPBOND_PERI_DEFAULT_PASSCODE, sizeof(uint32_t), &passkey);
GAPBondMgr_SetParameter(GAPBOND_PERI_PAIRING_MODE, sizeof(uint8_t), &pairMode);
GAPBondMgr_SetParameter(GAPBOND_PERI_MITM_PROTECTION, sizeof(uint8_t), &mitm);
GAPBondMgr_SetParameter(GAPBOND_PERI_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
GAPBondMgr_SetParameter(GAPBOND_PERI_BONDING_ENABLED, sizeof(uint8_t), &bonding);
// Initialize GATT attributes
GGS_AddService(GATT_ALL_SERVICES); // GAP
GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
DevInfo_AddService(); // Device Information Service
SimpleProfile_AddService(GATT_ALL_SERVICES); // Simple GATT Profile
// Setup the SimpleProfile Characteristic Values
uint8_t charValue1[SIMPLEPROFILE_CHAR1_LEN] = {1};
uint8_t charValue2[SIMPLEPROFILE_CHAR2_LEN] = {2};
uint8_t charValue3[SIMPLEPROFILE_CHAR3_LEN] = {3};
uint8_t charValue4[SIMPLEPROFILE_CHAR4_LEN] = {4};
uint8_t charValue5[SIMPLEPROFILE_CHAR5_LEN] = {1, 2, 3, 4, 5};
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1, SIMPLEPROFILE_CHAR1_LEN, charValue1);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR2, SIMPLEPROFILE_CHAR2_LEN, charValue2);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR3, SIMPLEPROFILE_CHAR3_LEN, charValue3);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR4, SIMPLEPROFILE_CHAR4_LEN, charValue4);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN, charValue5);
// Init Connection Item
peripheralInitConnItem(&peripheralConnList);
// Register callback with SimpleGATTprofile
SimpleProfile_RegisterAppCBs(&Peripheral_SimpleProfileCBs);
// Register receive scan request callback
GAPRole_BroadcasterSetCB(&Broadcaster_BroadcasterCBs);
// Setup a delayed profile startup
tmos_set_event(Peripheral_TaskID, SBP_START_DEVICE_EVT);
switch(paramID)
case SIMPLEPROFILE_CHAR1:
uint8_t newValue[SIMPLEPROFILE_CHAR1_LEN];
tmos_memcpy(newValue, pValue, len);
PRINT("profile ChangeCB CHAR1.. %s\\r\\n",pValue);
if (pValue[0] == 48) {
PRINT("OPEN LED.. \\n");
GPIO_WriteBit(GPIOA, GPIO_Pin_8,Bit_SET);
else {
PRINT("CLOSE LED.. \\n");
GPIO_WriteBit(GPIOA, GPIO_Pin_8,Bit_RESET);
break;
case SIMPLEPROFILE_CHAR3:
uint8_t newValue[SIMPLEPROFILE_CHAR3_LEN];
PRINT("profile ChangeCB CHAR3..\\n");
break;
default:
// should not reach here!
break;
连接图片:
串口输出结果:
后续继续摸索BLE.
更多回帖
