所以我在 ESP32 和 AVR 芯片之间使用 UART
通信。TX响应率有问题。
AVR 发送 5 个字节,前两个是命令字节,后 3 个是数据字节:
代码:
全选
//command
Serial2.write(0x01);
Serial2.write(0x62);
//data
Serial2.write(0x69); //high byte
Serial2.write(0x70); //low byte
Serial2.write(0x71); //data
delayMicroseconds(150);
在 ESP 端,它使用 RX 中断获取数据并将其存储到另一个缓冲区,并使用 xTaskResumeFromISR 对接收到的数据执行某些操作:
代码:
全选
sta
tic void IRAM_ATTR uart_intr_handle(void *arg)
uint16_t i = 0;
uint16_t rx_fifo_len = 0;
rx_fifo_len = UART1.status.rxfifo_cnt; // read number of bytes in UART buffer
while(rx_fifo_len){
rxbuf[i++] = UART1.fifo.rw_byte; // read all bytes
if(rxbuf
== 0x01 && rxbuf[i+1] == 0x62){
dataBuff[0] = rxbuf[i + 2];
dataBuff[1] = rxbuf[i + 3];
dataBuff[2] = rxbuf[i + 4];
xTaskResumeFromISR(xHandle);
if(rxbuf == 0x02 && rxbuf[i+1] == 0x63){
// xTaskResumeFromISR(xHandle2);
rx_fifo_len--;
uart_clear_intr_status(EX_UART_NUM, UART_RXFIFO_FULL_INT_CLR|UART_RXFIFO_TOUT_INT_CLR);
这是处理数据的函数:
代码:全选
void task(void *arg){
while(1){
char writeAddress[6];
uint16_t tempAddress = dataBuff[1] | (dataBuff[0]<<8);
uint8_t writeData = dataBuff[2];
sprintf(writeAddress, "%d", tempAddress);
ESP_LOGE("uart", "Address: %s, %x", writeAddress, writeData);
//not implemented yet, but here is where data will be stored into esp nvs
//and send 0x01 back to AVR so it knows that datas has been stored succesfully
uart_write_bytes(EX_UART_NUM, &txDataBuff[1], 1);
vTaskSuspend(NULL);
我得到的数据是正确的,这里是 ESP_LOGE 的一瞥:
代码:全选
E (2290198) uart: Address: 26992, 71
E (2290208) uart: Address: 26992, 71
E (2290218) uart: Address: 26992, 71
所以我的问题是 uart_write_bytes() 大约需要 5 毫秒(所以这也意味着函数需要 5 毫秒才能完成?
:只需发送每 ~30 个数据包。
我假设它与恢复任务需要多长时间有关,或者另一个任务正在中断此任务?
我怎样才能增加响应时间?
您的回复将不胜感激
