乐鑫技术交流
直播中
zhongnian
8年用户 1387经验值
擅长:MEMS/传感技术
私信 关注
[问答]
esp32-Lyrat_mini_v1.2编译ASR语音识别唤醒不了怎么解决?
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:7376
ho 0 tail 12 room 4
load:0x40078000,len:14904
ho 0 tail 12 room 4
load:0x40080400,len:4988
entry 0x40080708
I (70) boot: Chip Revision: 1
I (75) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (43) boot: ESP-IDF v4.0.2 2nd stage bootloader
I (43) boot: compile time 09:59:16
I (43) boot: Enabling RNG early entropy source...
I (48) qio_mode: Enabling default flash chip QIO
I (53) boot: SPI Speed      : 80MHz
I (57) boot: SPI Mode       : QIO
I (61) boot: SPI Flash Size : 4MB
I (65) boot: Partition Table:
I (69) boot: ## Label            Usage          Type ST Offset   Length
I (76) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (83) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (91) boot:  2 factory          factory app      00 00 00010000 00300000
I (98) boot: End of partition table
I (103) boot_comm: chip revision: 1, min. application chip revision: 0
I (110) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1ff4f8 (2        094328) map
I (687) esp_image: segment 1: paddr=0x0020f520 vaddr=0x3ffb0000 size=0x00af0 (        2800) load
I (688) esp_image: segment 2: paddr=0x00210018 vaddr=0x400d0018 size=0x42820 (27        2416) map
I (768) esp_image: segment 3: paddr=0x00252840 vaddr=0x3ffb0af0 size=0x016cc (        5836) load
I (770) esp_image: segment 4: paddr=0x00253f14 vaddr=0x40080000 size=0x00400 (        1024) load
I (775) esp_image: segment 5: paddr=0x0025431c vaddr=0x40080400 size=0x0d224 ( 5        3796) load
I (809) boot: Loaded app from partition at offset 0x10000
I (810) boot: Disabling RNG early entropy source...
I (810) cpu_start: Pro cpu up.
I (814) cpu_start: Application information:
I (818) cpu_start: Project name:     speech_recognition_example
I (825) cpu_start: App version:      v2.2-107-ge5438f4
I (831) cpu_start: Compile time:     Apr 22 2021 11:29:57
I (837) cpu_start: ELF file SHA256:  e9b9cab89463b466...
I (843) cpu_start: ESP-IDF:          v4.0.2
I (848) cpu_start: Starting app cpu, entry point is 0x40081320
I (0) cpu_start: App cpu up.
I (858) heap_init: Initializing. RAM available for dynamic allocation:
I (865) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (871) heap_init: At 3FFB3350 len 0002CCB0 (179 KiB): DRAM
I (877) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (884) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (890) heap_init: At 4008D624 len 000129DC (74 KiB): IRAM
I (896) cpu_start: Pro cpu start user code
I (913) spi_flash: detected chip: gd
I (914) spi_flash: flash io: qio
W (914) spi_flash: Detected size(8192k) larger than the size in the binary image        header(4096k). Using the size in the binary image header.
I (925) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (940) example_asr_keywords: Initialize SR wn handle
Quantized wakeNet5: wakeNet5X3_v2_nihaoxiaozhi_6_0.955_0.90, mode:0 (Oct 14 2020        16:26:17)
I (953) example_asr_keywords: keywords: nihaoxiaozhi (index = 1)
Fail: index is out of range, the min index is 1, the max index is 1I (960) examp        le_asr_keywords: keywords_num = 1, threshold = 0.000000, sample_rate = 16000, ch        unksize = 480, sizeof_uint16 = 2
CONTINUOUS_RECOGNITION: 2_0 MN1_4; core: 0; (May 15 2020 14:50:28)
SHIFT: 8, 12, 17, 17, 19, 17, 6, 16, 15, 14,
I (997) example_asr_keywords: keywords_num = 200 , sample_rate = 16000, chunksiz        e = 480, sizeof_uint16 = 2
I (998) example_asr_keywords: [ 1 ] Start codec chip
I (1505) example_asr_keywords: [ 2.0 ] Create audio pipeline for recording
I (1505) example_asr_keywords: [ 2.1 ] Create i2s stream to read audio data from        codec chip
I (1512) example_asr_keywords: [ 2.3 ] Create raw to receive data
I (1517) example_asr_keywords: [ 3 ] Register all elements to audio pipeline
I (1525) example_asr_keywords: [ 4 ] Link elements together [codec_chip]-->i2s_s        tream-->raw-->[SR]
W (1595) I2C_BUS: i2c_bus_create:57: I2C bus has been already created, [port:0]
----------------------------- ESP Audio Platform -----------------------------
|                 ESP_AUDIO-v1.6.6-10-gf944a6b-aca0d7f-2d83f7a               |
|                     Compile date: Mar 15 2021-11:14:21                     |
I (1635) example_asr_keywords: esp_audio instance is:0x3ffd24dc
I (1635) example_asr_keywords: [ 5 ] Start audio_pipeline
更多回帖
