乐鑫技术交流
直播中
jsqueh
8年用户 1138经验值
私信 关注
[问答]
esp-camera报错cam_hal: FB-SIZE: 115200 != 129600怎么解决?
我在适配一个新的CIS,这颗输出的格式是raw,大小为480*270,所以dma node size 为2880,图片fb_size为129600,程序将它计算为9次拷贝,一次的大小为14400,我在esp32-camera的基础上修改了很多内容,目前的问题是出在cam_hal中的cam_task,程序期待的是有9次IN_SUC_EOF中断,但是每次只收到8次,也就是在came_task中只拷贝了8次,所以得到的大小为115200(离正确的129600差14400),测量过sensor的波形,其pclk为6.4MHZ,一共有270个行同步信号,每个行同步信号内有480个pclk信号.
我使用的是esp32s3-eye,主程序如下:
`extern "C" void app_main()
#if CONFIG_CAMERA_MODULE_ESP_EYE || CONFIG_CAMERA_MODULE_ESP32_CAM_BOARD
    /* IO13, IO14 is designed for JTAG by default,
     * to use it as generalized input,
     * firstly declair it as pullup input */
    gpio_config_t conf;
    conf.mode = GPIO_MODE_INPUT;
    conf.pull_up_en = GPIO_PULLUP_ENABLE;
    conf.pull_down_en = GPIO_PULLDOWN_DISABLE;
    conf.intr_type = GPIO_INTR_DISABLE;
    conf.pin_bit_mask = 1LL << 13;
    gpio_config(&conf);
    conf.pin_bit_mask = 1LL << 14;
    gpio_config(&conf);
#endif
    camera_config_t config;
    config.ledc_channel = LEDC_CHANNEL_0;
    config.ledc_timer = LEDC_TIMER_0;
    config.pin_d0 = CAMERA_PIN_D0;
    config.pin_d1 = CAMERA_PIN_D1;
    config.pin_d2 = CAMERA_PIN_D2;
    config.pin_d3 = CAMERA_PIN_D3;
    config.pin_d4 = CAMERA_PIN_D4;
    config.pin_d5 = CAMERA_PIN_D5;
    config.pin_d6 = CAMERA_PIN_D6;
    config.pin_d7 = CAMERA_PIN_D7;
    config.pin_xclk = CAMERA_PIN_XCLK;
    config.pin_pclk = CAMERA_PIN_PCLK;
    config.pin_vsync = CAMERA_PIN_VSYNC;
    config.pin_href = CAMERA_PIN_HREF;
    config.pin_sscb_sda = CAMERA_PIN_SIOD;
    config.pin_sscb_scl = CAMERA_PIN_SIOC;
    config.pin_pwdn = CAMERA_PIN_PWDN;
    config.pin_reset = CAMERA_PIN_RESET;
    config.xclk_freq_hz = 24000000;
    config.pixel_format = PIXFORMAT_GRAYSCALE;
    config.frame_size = FRAMESIZE_480X270;
    config.jpeg_quality = 12;
    config.fb_count = 2;
    config.fb_location = CAMERA_FB_IN_PSRAM;
    config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
    // camera init
    esp_err_t err = esp_camera_init(&config);
    if (err != ESP_OK)
        ESP_LOGE(TAG, "Camera init failed with error 0x%x", err);
        return;
    vTaskDelay(2000 / portTICK_RATE_MS);
    while (1)
        ESP_LOGW(TAG, "Taking picture...");
        camera_fb_t *pic = esp_camera_fb_get();
        ESP_LOGW(TAG, "pic addr: %p ", pic->buf);
        // use pic->buf to access the image
        ESP_LOGW(TAG, "Picture taken! Its size was: %zu bytes", pic->len);
        esp_camera_fb_return(pic);
        // vTaskDelay(5000 / portTICK_RATE_MS);
为了进一步调试,我修改了cam_hal中的buf_size检查,将尺寸不合规的frame的en也置为0,得到了如下输出:
I (00:00:09.711) cam_hal: FB-SIZE: 115200 != 129600
W (00:00:09.712) example:take_picture: pic addr: 0x3d8009c8
W (00:00:09.712) example:take_picture: Picture taken! Its size was: 115200 bytes
W (00:00:09.712) example:take_picture: Taking picture...
I (00:00:09.741) cam_hal: FB-SIZE: 115200 != 129600
W (00:00:09.741) example:take_picture: pic addr: 0x3d82040c
W (00:00:09.741) example:take_picture: Picture taken! Its size was: 115200 bytes
W (00:00:09.742) example:take_picture: Taking picture...
I (00:00:09.770) cam_hal: FB-SIZE: 115200 != 129600
W (00:00:09.770) example:take_picture: pic addr: 0x3d8009c8
W (00:00:09.771) example:take_picture: Picture taken! Its size was: 115200 bytes
W (00:00:09.771) example:take_picture: Taking picture...
I (00:00:09.799) cam_hal: FB-SIZE: 115200 != 129600
看起来像最后一个包的时候,程序还没来得及读到14400个字节,v信号就来了。实在想不出来问题出在哪。
当程序运行到这一行时的cam_obj:
` frame_buffer_event->len += ll_cam_memcpy(cam_obj,
                            &frame_buffer_event->buf[frame_buffer_event->len],
                            &cam_obj->dma_buffer[(cnt % cam_obj->dma_half_buffer_cnt) * cam_obj->dma_half_buffer_size],
                            cam_obj->dma_half_buffer_size);`
更多回帖
