预计调用esp_wifi_start后内置的jtag会掉线吗?
在我的软件中,调试工作正常,直到那时。我也可以进入 esp_wifi_start,但是在没有断点的情况下检查它会断开 USB jtag 连接。停在 esp_wifi_start 似乎打破了函数的时间。
这是在 esp_wifi_start 上设置断点时:
代码:
全选
(gdb) target extended-remote :3333
Remote debugging using :3333
0x420081c6 in app_main () at ../main/startup.cpp:389
389 while (WaitStartup == 0);
(gdb) break esp_wifi_start
Breakpoint 1 at 0x42096480: file ../main/startup.cpp, line 555.
(gdb) set WaitStartup =1
(gdb) c
Con
tinuing.
Note: automatically using hardware breakpoints for read-only addresses.
[esp32s3.cpu0] Target halted, PC=0x42096480, debug_reason=00000001
Set GDB target to 'esp32s3.cpu0'
[esp32s3.cpu1] Target halted, PC=0x40043A40, debug_reason=00000000
[New Thread 1070544848]
[New Thread 1070524092]
[New Thread 1070551216]
[New Thread 1070559892]
[New Thread 1070555096]
[New Thread 1070519636]
[New Thread 1070547256]
[New Thread 1070538432]
[Switching to Thread 1070542952]
Thread 1 "main" hit Breakpoint 1, 0x42096480 in esp_wifi_start ()
at ../main/startup.cpp:555
555 event_trigger(event_id("init`done"));
(gdb) where
#0 0x42096480 in esp_wifi_start () at ../main/startup.cpp:555
#1 0x42019dea in wifi_start_station (ssid=
pass=) at ../main/wifi.cpp:499
#2 0x42034cb2 in cfg_activate () at ../components/streams/estring.h:71
#3 0x4200827a in app_main () at ../main/startup.cpp:477
#4 0x420e6a16 in main_task (args=0x0)
at ../idf/idf-esp32/components/freertos/port/port_common.c:141
#5 0x40381948 in vPortTaskWrapper (pxCode=0x420e69c4 ,
pvParameters=0x0)
at ../idf/idf-esp32/components/freertos/port/xtensa/port.c:131
(gdb) n
xTaskGetCurrentTaskHandle ()
at ../idf/idf-esp32/components/freertos/tasks.c:4650
4650 {
(gdb) n
4654 state = portSET_INTERRUPT_MASK_FROM_ISR();
(gdb) where
#0 xTaskGetCurrentTaskHandle ()
at ../idf/idf-esp32/components/freertos/tasks.c:4654
#1 0x4209ca5a in current_task_is_wifi_task () at ../main/settings.cpp:595
#2 0x42095d07 in wifi_api_lock () at ../main/settings.cpp:595
#3 0x42095d66 in wifi_init_completed () at ../main/settings.cpp:595
#4 0x42096486 in esp_wifi_start () at ../main/settings.cpp:595
#5 0x42019dea in wifi_start_station (ssid=,
#6 0x42034cb2 in cfg_activate () at ../components/streams/estring.h:71
#7 0x4200827a in app_main () at ../main/startup.cpp:477
#8 0x420e6a16 in main_task (args=0x0)
#9 0x40381948 in vPortTaskWrapper (pxCode=0x420e69c4 ,
pvParameters=0x0)
(gdb)
