FLASH为64MB(S25FS512S),连接如下:
我设法将代码下载到闪存中:
代码:
全选
julien@Fozzy:~/Projets/hello_world$ /home/julien/.espressif/python_env/idf5.0_py3.10_env/bin/python ../../esp/esp-idf/components/esptool_py/esptool/esptool.py -p /dev/ttyACM0 -b 460800 --before default_reset --after hard_reset --chip esp32s3 --no-stub write_flash --flash_mode dio --flash_size 64MB --flash_freq 20m 0x0 build/bootloader/bootloader.bin 0x8000 build/par
tition_table/partition-table.bin 0x10000 build/hello_world.bin
esptool.py v4.4
Serial port /dev/ttyACM0
Connecting...
Chip is ESP32-S3 (revision v0.1)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 7c:df:a1:e0:ed:ec
Changing baud rate to 460800
Changed.
Enabling default SPI flash mode...
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x00010000 to 0x00041fff...
Erasing flash...
Took 1.77s to erase flash block
Wrote 21504 bytes at 0x00000000 in 0.5 seconds (331.5 kbit/s)...
Hash of data verified.
Erasing flash...
Took 0.24s to erase flash block
Wrote 3072 bytes at 0x00008000 in 0.1 seconds (453.0 kbit/s)...
Erasing flash...
Took 1.99s to erase flash block
Wrote 201728 bytes at 0x00010000 in 4.8 seconds (335.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
但它永远不会启动。这是我在监视器中得到的:
代码:
全选
Executing action: monitor
Running idf_monitor in directory /home/julien/Projets/hello_world
Executing "/home/julien/.espressif/python_env/idf5.0_py3.10_env/bin/python /home/julien/esp/esp-idf/tools/idf_monitor.py -p /dev/ttyACM0 -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 /home/julien/Projets/hello_world/build/hello_world.elf -m '/home/julien/.espressif/python_env/idf5.0_py3.10_env/bin/python' '/home/julien/esp/esp-idf/tools/idf.py' '-p' '/dev/ttyACM0'"...
--- idf_monitor on /dev/ttyACM0 115200 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x1a (SPI_FAST_FLASH_BOOT)
Saved PC:0x400454d5
SPIWP:0xee
mode:DIO, clock div:4
load:0x3fce3810,len:0x167c
ets_loader.c 78
device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Waiting for the device to reconnect
Build:Mar 27 2021
Saved PC:0x400454d5
SPIWP:0xee
ets_loader.c 78
Build:Mar 27 2021
rst:0x7 (TG0WDT_SYS_RST),boot:0x1a (SPI_FAST_FLASH_BOOT)
Saved PC:0x400454d5
SPIWP:0xee
ets_loader.c 78
Build:Mar 27 2021
Saved PC:0x400454d5
SPIWP:0xee
ets_loader.c 78
Build:Mar 27 2021
Saved PC:0x400454d5
SPIWP:0xee
ets_loader.c 78
这永远持续下去。看起来看门狗出现故障,但甚至没有到达入口点。
这是 sdkconfig 的摘录:
代码:
全选
# Serial flasher config
CONFIG_ESPTOOLPY_NO_STUB=y
# CONFIG_ESPTOOLPY_OCT_FLASH is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR=y
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_120M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_80M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_40M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_20M=y
CONFIG_ESPTOOLPY_FLASHFREQ="20m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_32MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_64MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_128MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="64MB"
# CONFIG_ESPTOOLPY_HEADER_FLASHSIZE_UPDATE is not set
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
知道我错过了什么吗?
与 ESP32-S3 和 FLASH 的
通信似乎没问题……
