瑞萨单片机论坛
直播中
h1654155849.0830
10年用户 23经验值
擅长:嵌入式技术
私信 关注
[经验]
【RA4M2设计挑战赛】ISL29035模块硬件IIC驱动
先试下功能,所以先找了别人代码试用一下,暂未调通,待调通再封装下模块代码。
首先用RASC配置IIC,跟驱动HS3003一样,配置成IIC_Master。
参考了下数据手册,大致初始化接口如下
int32_t DigitalLightISL29035_init(void)
    uint8_t reg = 0;
    reg=   DigitalLightISL29035_readRegister( 0x0F);//CHIP_ID->0x0f
    //Serial.println(reg, HEX);
    uint8_t chip_id = (reg >> 3) & 0x7;
    if (chip_id != 0x5) {
        return -1;
    //清除BOUT位
    DigitalLightISL29035_writeRegister(0x0F, reg & 0x7f);//CHIP_ID->0x0f
    //确保芯片处于停止模式
    DigitalLightISL29035_writeRegister( 0x00, 0);//COMMAND_I->0x00
    //设置分辨率
    DigitalLightISL29035_writeRegister(0x01, full_scale_lux_range | (integration_time << 2) );//COMMAND_2->0x01
    //设置为单次模式
    DigitalLightISL29035_writeRegister( 0x00, 0x40);//COMMAND_I->0x00
    return 0;
写接口如下
void DigitalLightISL29035_writeRegister( int reg_address, uint8_t val)
    uint8_t ii[2]={0x00,0x00};
    ii[0] = reg_address;
    ii[1] = val;
    R_SCI_I2C_Write(&HS3003_I2C3, ii, 0x02, false);
    /* Since there is nothing else to do, block until Callback triggers*/
    //while ((I2C_MASTER_EVENT_TX_COMPLETE != i2c_event) && timeout_ms)
    while ((I2C_MASTER_EVENT_TX_COMPLETE != i2c_event1) && timeout_ms1>0)
       R_BSP_SoftwareDelay(1U, BSP_DELAY_UNITS_MICROSECONDS);
       timeout_ms1--;
    if (I2C_MASTER_EVENT_ABORTED == i2c_event1)
       __BKPT(0);
    /* Read data back from the I2C slave */
    i2c_event1 = I2C_MASTER_EVENT_ABORTED;
    timeout_ms1           = 100000;
读接口如下
uint8_t DigitalLightISL29035_readRegister(uint8_t reg_address)
    uint8_t value;
    R_SCI_I2C_Write(&HS3003_I2C3, &reg_address, 0x01, false);
        timeout_ms1--;
        __BKPT(0);
    /* Read data from I2C slave */
    R_SCI_I2C_Read(&HS3003_I2C3, &value, 0x01, false);
    while ((I2C_MASTER_EVENT_RX_COMPLETE != i2c_event1) && timeout_ms1)
        R_BSP_SoftwareDelay(1U, BSP_DELAY_UNITS_MILLISECONDS);
        timeout_ms1--;
        __BKPT(0);
    return value;
获取数据代码如下:
uint32_t DigitalLightISL29035_readIRLux(void) {
    uint16_t data = 0;
    uint8_t l, h;
    //设置为单次模式
    //等待时间
    if(integration_time==0)
        R_BSP_SoftwareDelay(105, BSP_DELAY_UNITS_MILLISECONDS);
    else if(integration_time==1 || integration_time==2)
        R_BSP_SoftwareDelay(7, BSP_DELAY_UNITS_MILLISECONDS);
    else if(integration_time==3)
        R_BSP_SoftwareDelay(1, BSP_DELAY_UNITS_MILLISECONDS);
    l=DigitalLightISL29035_readRegister(0x02);//DATA_L->0x02
    h=DigitalLightISL29035_readRegister(0x03);//DATA_H->0x03
    data=(h << 8) | l;
    uint32_t ranges=0;
    if(full_scale_lux_range==0)
        ranges=1000;
    else if(full_scale_lux_range==1)
        ranges=4000;
    else if(full_scale_lux_range==2)
        ranges=16000;
    else if(full_scale_lux_range==3)
        ranges=64000;
    uint32_t adc_count_max=0;
        adc_count_max=65536;
    else if(integration_time==1)
        adc_count_max=4096;
    else if(integration_time==2)
        adc_count_max=256;
        adc_count_max=16;
    return ranges * (uint32_t)data /adc_count_max;
应用代码(因为地址都是0x44,我这边用的都是同一个口,所以线程名称先用HS3003的顶一下)
void HS3003_Task_entry(void * pvParameters)
                    FSP_PARAMETER_NOT_USED(pvParameters);
                    DigitalLightISL29035_init();
                    /* TODO: add your own code here */
                    while(1)
                        ISL29035Data = DigitalLightISL29035_readIRLux();
                        vTaskDelay(200);
更多回帖
