1.driver 中添加soft i2c
2. 指定I2C 管脚
由于RT env 还未添加 在头文件自己添加使能
pin定义对应pin number转换关系参考 drv_gpio的ra_pin_get,如'p408' 对应关系就是 4*16*16+0*10+8
这里定义了原理图中的两个IIC
hs3003 sensor 驱动编写
- #include
- #include
- #include "sensor_renesas_hs300x.h"
- #include
- #include
- #define DBG_TAG "sensor.renesas.hs300x"
- #define DBG_LVL DBG_INFO
- #include
- #define SENSOR_TEMP_RANGE_MAX (80)
- #define SENSOR_TEMP_RANGE_MIN (-10)
- #define SENSOR_HUMI_RANGE_MAX (100)
- #define SENSOR_HUMI_RANGE_MIN (0)
- /* Definitions of Mask Data for A/D data */
- #define RM_HS300X_MASK_HUMIDITY_UPPER_0X3F (0x3F)
- #define RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC (0xFC)
- #define RM_HS300X_MASK_STATUS_0XC0 (0xC0)
- /* Definitions for Status Bits of A/D Data */
- #define RM_HS300X_DATA_STATUS_VALID (0x00) // Status-bit: Valid data
- /* Definitions for Calculation */
- #define RM_HS300X_CALC_STATIC_VALUE (16383.0F)
- #define RM_HS300X_CALC_HUMD_VALUE_100 (100.0F)
- #define RM_HS300X_CALC_TEMP_C_VALUE_165 (165.0F)
- #define RM_HS300X_CALC_TEMP_C_VALUE_40 (40.0F)
- #define RM_HS300X_CALC_DECIMAL_VALUE_100 (100.0F)
- struct hs300x_device
- struct rt_i2c_bus_device *i2c;
- uint8_t addr;
- static struct hs300x_device temp_humi_dev;
- static rt_err_t _hs300x_init(struct rt_sensor_intf *intf)
- temp_humi_dev.i2c = rt_i2c_bus_device_find(intf->dev_name);
- //temp_humi_dev.addr = (uint8_t)intf->arg;
- temp_humi_dev.addr = HS300X_I2C_ADDR;
- if (temp_humi_dev.i2c == RT_NULL)
- return -RT_ERROR;
- return RT_EOK;
- int hs300x_read_data(struct hs300x_device* dev, float *humi_f, float *temp_f)
- uint8_t r_buf[4] = {0};
- uint16_t humi, temp;
- float tmp_f = 0.0;
- struct rt_i2c_msg msgs;
- msgs.addr = dev->addr;
- msgs.flags = RT_I2C_WR;
- msgs.buf = 0;
- msgs.len = 0;
- if (rt_i2c_transfer(dev->i2c, &msgs, 1) != 1)
- LOG_E("mr error!
- return -1;
- msgs.flags = RT_I2C_RD;
- msgs.buf = r_buf;
- msgs.len = 4;
- __retry:
- if (rt_i2c_transfer(dev->i2c, &msgs, 1) == 1)
- LOG_D("%x,%x,%x,%x
- ", r_buf[0], r_buf[1], r_buf[2], r_buf[3]);
- LOG_D("state:%x
- ", r_buf[0] & RM_HS300X_MASK_STATUS_0XC0);
- if ((r_buf[0] & RM_HS300X_MASK_STATUS_0XC0) != RM_HS300X_DATA_STATUS_VALID)
- rt_thread_mdelay(100);
- goto __retry;
- humi = (r_buf[0] & RM_HS300X_MASK_HUMIDITY_UPPER_0X3F) << 8 | r_buf[1];
- temp = (r_buf[2] << 8 | (r_buf[3] & RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC)) >> 2;
- tmp_f = (float)humi;
- tmp_f = (tmp_f * RM_HS300X_CALC_HUMD_VALUE_100) / RM_HS300X_CALC_STATIC_VALUE;
- if (humi_f)
- *humi_f = tmp_f;
- tmp_f = (float)temp;
- tmp_f = ((tmp_f * RM_HS300X_CALC_TEMP_C_VALUE_165) / RM_HS300X_CALC_STATIC_VALUE) - RM_HS300X_CALC_TEMP_C_VALUE_40;
- if (temp_f)
- *temp_f = tmp_f;
- return 0;
- else {
- LOG_E("read error!
- return -1;
- float hs300x_read_temperature(struct hs300x_device* dev)
- float temp;
- if (hs300x_read_data(dev, NULL, &temp) == 0)
- return temp;
- return 0;
- float hs300x_read_humidity(struct hs300x_device* dev)
- float humi;
- if (hs300x_read_data(dev, &humi, NULL) == 0)
- return humi;
- return 0;
- static rt_size_t _hs300x_polling_get_data(rt_sensor_t sensor, struct rt_sensor_data *data)
- float temperature_x10, humidity_x10;
- if (sensor->info.type == RT_SENSOR_TYPE_TEMP)
- temperature_x10 = 10 * hs300x_read_temperature(&temp_humi_dev);
- data->data.temp = (rt_int32_t)temperature_x10;
- data->timestamp = rt_sensor_get_ts();
- else if (sensor->info.type == RT_SENSOR_TYPE_HUMI)
- humidity_x10 = 10 * hs300x_read_humidity(&temp_humi_dev);
- data->data.humi = (rt_int32_t)humidity_x10;
- return 1;
- //rt_ssize_t (*fetch_data)(rt_sensor_t sensor, rt_sensor_data_t buf, rt_size_t len);
- static rt_ssize_t hs300x_fetch_data(struct rt_sensor_device *sensor, struct rt_sensor_data * buf, rt_size_t len)
- RT_ASSERT(buf);
- if(sensor->config.irq_pin.mode==RT_SENSOR_MODE_FETCH_POLLING)
- //if (sensor->config.mode == RT_SENSOR_MODE_FETCH_POLLING)
- return _hs300x_polling_get_data(sensor, buf);
- else
- return 0;
- static rt_err_t hs300x_control(struct rt_sensor_device *sensor, int cmd, void *args)
- rt_err_t result = RT_EOK;
- return result;
- static struct rt_sensor_ops sensor_ops =
- hs300x_fetch_data,
- hs300x_control
- int rt_hw_hs300x_init(const char *name, struct rt_sensor_config *cfg)
- rt_int8_t result;
- rt_sensor_t sensor_temp = RT_NULL, sensor_humi = RT_NULL;
- /* temperature sensor register */
- sensor_temp = rt_calloc(1, sizeof(struct rt_sensor_device));
- if (sensor_temp == RT_NULL)
- return -1;
- sensor_temp->info.type = RT_SENSOR_TYPE_TEMP;
- sensor_temp->info.vendor = RT_SENSOR_VENDOR_UNKNOWN;
- sensor_temp->info.name = "hs300x";
- sensor_temp->info.unit = RT_SENSOR_UNIT_CELSIUS;
- sensor_temp->info.intf_type = RT_SENSOR_INTF_I2C;
- sensor_temp->info.scale.range_max = SENSOR_TEMP_RANGE_MAX;
- sensor_temp->info.scale.range_min = SENSOR_TEMP_RANGE_MIN;
- sensor_temp->info.acquire_min = 5;
- rt_memcpy(&sensor_temp->config, cfg, sizeof(struct rt_sensor_config));
- sensor_temp->ops = &sensor_ops;
- result = rt_hw_sensor_register(sensor_temp, name, RT_DEVICE_FLAG_RDONLY, RT_NULL);
- if (result != RT_EOK)
- LOG_E("device register err code: %d", result);
- goto __exit;
- /* humidity sensor register */
- sensor_humi = rt_calloc(1, sizeof(struct rt_sensor_device));
- if (sensor_humi == RT_NULL)
- return -1;
- sensor_humi->info.type = RT_SENSOR_TYPE_HUMI;
- sensor_humi->info.vendor = RT_SENSOR_VENDOR_UNKNOWN;
- sensor_humi->info.name = "hs300x";
- sensor_humi->info.unit = RT_SENSOR_UNIT_PERMILLAGE;
- sensor_humi->info.intf_type = RT_SENSOR_INTF_I2C;
- sensor_humi->info.scale.range_max = SENSOR_HUMI_RANGE_MAX;
- sensor_humi->info.scale.range_min = SENSOR_HUMI_RANGE_MIN;
- sensor_humi->info.acquire_min = 5;
- rt_memcpy(&sensor_humi->config, cfg, sizeof(struct rt_sensor_config));
- sensor_humi->ops = &sensor_ops;
- result = rt_hw_sensor_register(sensor_humi, name, RT_DEVICE_FLAG_RDONLY, RT_NULL);
- goto __exit;
- _hs300x_init(&cfg->intf);
- return RT_EOK;
- __exit:
- if (sensor_temp)
- rt_free(sensor_temp);
- if (sensor_humi)
- rt_free(sensor_humi);
- return -RT_ERROR;
port端口注册
- static int rt_hw_hs300x_port(void)
- struct rt_sensor_config cfg;
- cfg.intf.dev_name = "i2c1";
- cfg.irq_pin.mode = RT_SENSOR_MODE_FETCH_POLLING;
- rt_hw_hs300x_init("hs3003",&cfg);
- return RT_EOK;
- INIT_COMPONENT_EXPORT(rt_hw_hs300x_port);
可通过shell 或者编写线程读取数据,刚上电可看到sensor 注册成功
串口打印结果
