乐鑫技术交流
直播中
周臻庸
8年用户 910经验值
私信 关注
[问答]
IDF V4.4无法适配Micropython吗?
git上下载  idf v4.4 ,  Micropython 的v1.18 或最新版,
编译后烧录到eps32或 编译 esp32c3的版本,烧录后,板子反复重启。
TX0串口输出日志:
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:4344
load:0x40078000,len:13816
load:0x40080400,len:3340
entry 0x40080618
[15:54:32.908]收←◆Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x40147256  PS      : 0x00060733  A0      : 0x800d6fe8  A1      : 0x3ffceeb0
A2      : 0x00000000  A3      : 0x00000000  A4      : 0x3ffb78c8  A5      : 0x0000040e
A6      : 0x3ffceee0  A7      : 0x3ffbf244  A8      : 0x00000000  A9      : 0x3ffcee80
A10     : 0x00000000  A11     : 0x0000040e  A12     : 0x40083340  A13     : 0x00000000
A14     : 0x3ffceee0  A15     : 0x00000000  SAR     : 0x0000001d  EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000008  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
Backtrace:0x40147253:0x3ffceeb00x400d6fe5:0x3ffceee0 0x400d6e59:0x3ffcef10
ELF file SHA256: dc92aa87847c477c
定位 Backtrace 定位到 串口初始化函数中了。
Code: Select all
0x40147253: uart_isr_register at /home/mpy/esp-idf-v4.4/components/driver/uart.c:594
0x400d6fe5: uart_init at /home/mpy/mpy-v1.18/ports/esp32/build-GENERIC/../uart.c:41
0x400d6e59: mp_task at /home/mpy/mpy-v1.18/ports/esp32/build-GENERIC/../main.c:96
更多回帖
