乐鑫技术交流
直播中
李春梅
7年用户 1771经验值
私信 关注
[问答]
ESP32s3 I2c0 SCL一直高电平,没有时钟输出的原因?
ESP32s3 I2c0 SCL一直高电平,没有时钟输出,SDA也是一直高电平
日志显示初始化成功
I (4197) driver-codec: i2s driver init success
I (9197) driver-codec: I2C_MASTER_NUM=0,mode=1,speed=100000
I (9197) driver-codec: I2C initialized successfully
I (9207) driver-codec: i2c_read cnt = 0, error = -1
代码如下:
#define I2C0_MASTER_SCL_IO 18        /*!< GPIO number used for I2C master clock */
#define I2C0_MASTER_SDA_IO 17        /*!< GPIO number used for I2C master data  */
static esp_err_t i2c_master_init(void)
    int i2c_master_port = I2C_MASTER_NUM;
    i2c_config_t conf = {
        .mode = I2C_MODE_MASTER,
        .sda_io_num = I2C0_MASTER_SDA_IO,
        .scl_io_num = I2C0_MASTER_SCL_IO,
        .sda_pullup_en = GPIO_PULLUP_ENABLE,
        .scl_pullup_en = GPIO_PULLUP_ENABLE,
        .master.clk_speed = I2C_MASTER_FREQ_HZ,
        .clk_flags = 0,
    esp_err_t err = i2c_param_config(i2c_master_port, &conf);
    if (err != ESP_OK) {
        return err;
    ESP_LOGI(TAG, "I2C_MASTER_NUM=%d,mode=%d,speed=%d",i2c_master_port,conf.mode,conf.master.clk_speed);
    return i2c_driver_install(i2c_master_port, conf.mode, I2C_MASTER_RX_BUF_DISABLE, I2C_MASTER_TX_BUF_DISABLE, 0);
uint16_t AW88266A_i2c_read(unsigned char reg_addr)
    int ret;
    uint8_t cnt = 0;
    uint8_t data_buff[2] = {0};
    uint16_t data = 0;
    while (cnt < I2C_RETRY_TIMES)
         ret = i2c_master_write_read_device(I2C_MASTER_NUM, AW88266A_CODEC_ADDR, ®_addr, 1, data_buff, 2, I2C_MASTER_TIMEOUT_MS / portTICK_PERIOD_MS);
        if (ret != 0)
            ESP_LOGI(TAG, "i2c_read cnt = %d, error = %dn", cnt, ret);
        else
            break;
        cnt++;
     data = (((data_buff[0] << 8) & 0xff00) | (data_buff[1] & 0x00ff));
    ESP_LOGI(TAG, "i2c_read data = %dn", data);
    return data;
更多回帖
