ST意法半导体
直播中
刘伟
7年用户 1643经验值
私信 关注
[问答]
如何在Nucleo64 STM32L476板上的PA8引脚上输出LSE时钟?
你好!
我正在尝试在我的 Nucleo64 STM32L476 板上的 PA8 引脚上输出 LSE 时钟。
我写的代码如下:
  • #include
  • #define RCC_BASE_ADDR              0x40021000UL
  • #define RCC_CFGR_REG_OFFSET        0x08UL
  • #define RCC_CFGR_REG_ADDR          (RCC_BASE_ADDR + RCC_CFGR_REG_OFFSET )
  • #define GPIOA_BASE_ADDR            0x48000000UL
  • int main(void)
  •         uint32_t *pRccCfgrReg =  (uint32_t*) RCC_CFGR_REG_ADDR;
  •         //1. Configure the RCC_CFGR MCOSEL bit fields to select LSE as clock source: 0111: LSE clock selected
  •         *pRccCfgrReg &=~(0U << 27);
  •         *pRccCfgrReg |= (1U << 26);
  •         *pRccCfgrReg |= (1U << 25);
  •         *pRccCfgrReg |= (1U << 24);
  •         //2. Configure PA8 to AF0 mode to behave as MCO signal
  •         //a ) Enable the peripheral clock for GPIOA peripheral
  •         // RCC_AHB2ENR
  •          uint32_t *pRCCAhb2Enr = (uint32_t*)(RCC_BASE_ADDR + 0x4C);
  •         *pRCCAhb2Enr |= (1U << 0); //Enable GPIOA peripheral clock
  •         //b ) Configure the mode of GPIOA pin 8 as alternate function mode
  • // GPIOx_MODER
  •         uint32_t *pGPIOAModeReg = (uint32_t*)(GPIOA_BASE_ADDR + 0x00UL);
  •         *pGPIOAModeReg &=~(1U << 16);         // clear bit 16
  •         *pGPIOAModeReg |= (1U << 17);  // set bit 17
  •         //c ) Configure the alternation function register to set the mode 0 for PA8
  •         // GPIOx_AFRH
  •         uint32_t *pGPIOAAltFunHighReg = (uint32_t*)(GPIOA_BASE_ADDR + 0x24);
  •         *pGPIOAAltFunHighReg &=~(1U << 0);
  •         *pGPIOAAltFunHighReg &=~(1U << 1);
  •         *pGPIOAAltFunHighReg &=~(1U << 2);
  •         *pGPIOAAltFunHighReg &=~(1U << 3);
  •         uint32_t *pRCC_BDCR = (uint32_t*)(RCC_BASE_ADDR + 0x90);
  •         // Turn on LSE clock (LSEON)
  •         *pRCC_BDCR |= (1U << 0);
  •         for (;;);
任何人都可以看到一个明显的错误吗?我忘记了什么吗?我读到 LSE 时钟可能需要一些时间才能启动,我该如何改进我的代码来解决这个问题?
我观察到 LSERDY 位从未设置为 1,我怀疑这是问题所在。是什么导致这个位一直为0?
回帖(1)
衡辉
2022-12-26 13:57:34
在更改 RCC->BDCR 之前不需要解锁低功耗域吗?
举报
更多回帖
