ARM技术论坛
直播中
张国厚
7年用户 1400经验值
私信 关注
[经验]
用GD32F427开发板做一个会唱歌跳舞的机器
用GD32F427开发板做一个会唱歌跳舞的机器,分步来做,先做开始部分。
接1号舵机(GPIOC, GPIO_PIN_7);
接MP3模块(GPIOC, GPIO_PIN_10);
接2号舵机(GPIOC, GPIO_PIN_11);
接3号舵机(GPIOC, GPIO_PIN_1);
接4号舵机(GPIOC, GPIO_PIN_3);
#include "gd32f4xx.h"
#include "gd32f427v_start.h"
#include "systick.h"
#include <stdio.h>
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
void tiaowu()  //开始跳舞
                          for(int i=0;i<30;i++)
                     gpio_bit_set(GPIOC, GPIO_PIN_7);//1开始跳舞
                     delay_1ms(1);
                     gpio_bit_reset(GPIOC, GPIO_PIN_7);
                     delay_1ms(19);
                                    //     delay_1ms(200);
                                   gpio_bit_set(GPIOC, GPIO_PIN_11);//2开始跳舞
                     delay_1ms(2);
                     gpio_bit_reset(GPIOC, GPIO_PIN_11);
                     delay_1ms(18);
                              //        delay_1ms(200);
                     gpio_bit_set(GPIOC, GPIO_PIN_3);//3开始跳舞
                     delay_1ms(1);
                     gpio_bit_reset(GPIOC, GPIO_PIN_3);
                     delay_1ms(19);
                   //   delay_1ms(200);
                                   gpio_bit_set(GPIOC, GPIO_PIN_1);//4开始跳舞
                     delay_1ms(2);
                     gpio_bit_reset(GPIOC, GPIO_PIN_1);
                     delay_1ms(18);
               //        delay_1ms(200);
                     gpio_bit_set(GPIOC, GPIO_PIN_7);//1开始跳舞第二组动作
                     delay_1ms(2);
                     delay_1ms(18);
                                //         delay_1ms(200);
                                   gpio_bit_set(GPIOC, GPIO_PIN_11);//2开始跳舞第二组动作
                     delay_1ms(1);
                     delay_1ms(19);
                                  //    delay_1ms(200);
                     gpio_bit_set(GPIOC, GPIO_PIN_3);//3开始跳舞第二组动作
                     delay_1ms(2);
                     delay_1ms(18);
                  //    delay_1ms(200);
                                   gpio_bit_set(GPIOC, GPIO_PIN_1);//4开始跳舞第二组动作
                     delay_1ms(1);
                     delay_1ms(19);
                //       delay_1ms(200);
int main(void)
    /* configure systick */
    systick_config();
    /* enable the  GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOC);
    /* configure GPIO port */
     rcu_periph_clock_enable(RCU_GPIOA);
    /* configure key pin as input */
    gpio_mode_set(GPIOA, GPIO_MODE_INPUT, GPIO_PUPD_NONE, GPIO_PIN_0);
    gpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_ALL);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_ALL);
       /* reset GPIO pin */
      gpio_bit_set(GPIOC, GPIO_PIN_10);
    while(1) {
              /* check whether the key is pressed */
        if(RESET == gpio_input_bit_get(GPIOA, GPIO_PIN_0))
            delay_1ms(100);
                             gpio_bit_reset(GPIOC, GPIO_PIN_10); //音乐播放
                            for(int i=0;i<30;i++)tiaowu();//开始跳30组舞蹈
原作者:兆易创新GD32 MCU 还没吃饭
更多回帖
