单片机/MCU论坛
直播中
jf_1137202360
8年用户 1361经验值
擅长:嵌入式技术
私信 关注
[文章]
【HD-G2UL-EVM开发板体验】ADC测试-虚拟示波器实现
75a4cb24a56ec28cc200a093f8c386f1
前言
本板引出了两路12bits ADC 模拟采集通道,加上之前测的串口的通讯,可以将ADC才机制发送到上位机,通过上位机进行曲线显示,即实现了简单的虚拟示波器。
过程代码
两路的ADC对应设备如下,直接读对应的文件即可获取到ADC值
代码如下
引用: int adc_get(int ch)
    int channel;
    char cmd[128]={0};
    FILE *stream = NULL;
    char adc_v[1024] = {0};
    snprintf(cmd, sizeof(cmd),"cat /sys/bus/iio/devices/iio\:device0/in_voltage%d_raw",ch);
    stream = popen(cmd,"r");
    fread(adc_v,1,sizeof(adc_v),stream);
    pclose(stream);
    //printf("adc_channel%d: %s",channel,adc_v);
    return atoi(adc_v);
在上一篇测试串口的基础上完整代码如下
引用: #include       /* Standard input/output */
#include       /* File control definitions */
#include
#include
#include      /* POSIX terminal control definitions */
#include    /* Time structures for select() */
#include      /* POSIX Symbolic Constants */
#include
#include       /* Error definitions */
#include
#include
#include
#define  CMSPAR 010000000000
#define SERIAL_FLUSH_TX     1
#define SERIAL_FLUSH_RX     2
#define SERIAL_PARITY_NO        0
#define SERIAL_PARITY_ODD       1
#define SERIAL_PARITY_EVENT     2
#define SERIAL_PARITY_MARK      3
#define SERIAL_PARITY_SPACE     4
#define SERIAL_STOPBIT_ONE      1
#define SERIAL_STOPBIT_TWO      2
static int serial_fd  = -1;
struct termios old_tios;
int uart_read(uint8_t* buffer,uint32_t len,uint32_t timeout);
int uart_write(uint8_t* buffer,uint32_t len);
static void serial_print_buf(unsigned char *buf,int len) /* 打印输出 */
    int i;
    for(i=0;i
        printf("%02X ",buf);
    printf("n");
char *get_serial_dev_name(char *serial_name)   /* 获取串口名称 */
    if (strcasecmp(serial_name, "COM2") == 0)   /* 传入参函数是COM2(不区分大小写),则返回串口对应的设备节点/dev/ttymxc1 */
        return "/dev/ttymxc1";
    else if (strcasecmp(serial_name, "COM3") == 0)
        return "/dev/ttymxc2";
    else if (strcasecmp(serial_name, "COM4") == 0)
        return "/dev/ttymxc3";
    else if (strcasecmp(serial_name, "COM5") == 0)
        return "/dev/ttymxc4 ";
    else
        //return NULL;
        return serial_name;
static int termios_init(struct termios *tios,int baud,int parity,int data_bits,int stop_bits) //串口 传入波特率,校验位,数据位,停止位。
    speed_t baud_rate;
    if (tios == NULL)
        return -1;
    tios->c_line  = 0;
    tios->c_cc[VMIN ] = 0;
    tios->c_cc[VTIME] = 0;
    /* configure the input modes... */
    tios->c_iflag =  IGNBRK | IGNPAR | INPCK;
    /* configure the output modes... */
    tios->c_oflag = 0;     /* enable implementation-defined output processing */
    /* configure the control modes... */
    tios->c_cflag = CREAD | CLOCAL;
    if (data_bits == 5)      //对传入的数据位进行判断
        tios->c_cflag |= CS5;
    else if (data_bits == 6)
        tios->c_cflag |= CS6;
    else if (data_bits == 7)
        tios->c_cflag |= CS7;
    else if (data_bits == 8)
        tios->c_cflag |= CS8;
    else
        return -1;
    if (stop_bits == 1)     //对传入的停止位进行判断
        tios->c_cflag &=~ CSTOPB;
    else if (stop_bits == 2)
        tios->c_cflag |= CSTOPB;
    else
        return -1;
    if(parity == 0)         //校验位: 0:无校验 1:奇校验 2:偶校验 3:mark parity 4:space parity
    { /* none */
        tios->c_cflag &=~ PARENB;
        tios->c_cflag &=~ PARODD;
    else if(parity == 2)
    { /* even */
        tios->c_cflag |= PARENB;
    else if(parity == 1)
    { /* odd */
        tios->c_cflag |= PARODD;
    else if (parity == 3)/* 2008.12.17 add for support mark and space parity */
        /* mark */
        tios->c_cflag |= CMSPAR;
    else if (parity == 4)
        /* space */
    else
        return -1;
    /* configure the local modes... */
    tios->c_lflag = 0;    /* enable implementation-defined input processing   */
    /* Set the baud rate */
    switch(baud)            //对传入的波特率进行判断
        case 110:
            baud_rate = B110;
            break;
        case 300:
            baud_rate = B300;
            break;
        case 600:
            baud_rate = B600;
            break;
        case 1200:
            baud_rate = B1200;
            break;
        case 2400:
            baud_rate = B2400;
            break;
        case 4800:
            baud_rate = B4800;
            break;
        case 9600:
            baud_rate = B9600;
            break;
        case 19200:
            baud_rate = B19200;
            break;
        case 38400:
            baud_rate = B38400;
            break;
        case 57600:
            baud_rate = B57600;
            break;
        case 115200:
            baud_rate = B115200;
            break;
        case 230400:
            baud_rate = B230400;
            break;
        case 460800:
            baud_rate = B460800;
            break;
        case 576000:
            baud_rate = B576000;
            break;
        case 921600:
            baud_rate = B921600;
            break;
        default:
            return -1;
    if ((cfsetispeed(tios, baud_rate) < 0) ||(cfsetospeed(tios, baud_rate) < 0))
        return -1;
    return 0;
//return serial fd, error return -1
int serial_open(char *serial_name, int baud,int parity,int data_bits,int stop_bits,int timeout)  //打开串口
    struct termios settings;
    int fd;
    char *serial_dev_name;
    if (serial_fd >= 0)
        return 0;
    if (termios_init(&settings, baud,parity,data_bits,stop_bits) < 0)
        return 0;
    serial_dev_name = get_serial_dev_name(serial_name);
    if (serial_dev_name == NULL)
        fprintf(stderr, "invalid serial name:%sn", serial_name);
        return 0;
    if((fd = open(serial_dev_name, O_RDWR | O_NOCTTY | O_NDELAY))< 0)
        return 0;
    if(tcgetattr(fd, &old_tios) < 0)
        close(fd);
        return 0;
    if(tcsetattr(fd, TCSANOW, &settings) < 0)
        close(fd);
        return 0;
    serial_fd = fd;
    return 1;
int serial_close()      //关闭串口
    if (serial_fd < 0)
        return 0;
    tcsetattr(serial_fd, TCSANOW, &(old_tios));
    close(serial_fd);
    serial_fd = -1;
    return 1;
int serial_flush(int flag)
    if (serial_fd < 0)
        return 0;
    if (flag == SERIAL_FLUSH_TX)
        tcflush(serial_fd,TCOFLUSH);
    else if (flag == SERIAL_FLUSH_RX)
        tcflush(serial_fd,TCIFLUSH);
    else if (flag == (SERIAL_FLUSH_RX|SERIAL_FLUSH_TX) )
        tcflush(serial_fd,TCIOFLUSH);
    return 1;
//return 1: poll ok, 0: timeout, -1: error
int serial_poll(int timeout)
    int fd = serial_fd;
    fd_set rfds;
    struct timeval tv;
    int sel_res;
    FD_ZERO(&rfds);
    FD_SET(fd, &rfds);
    tv.tv_sec = timeout/1000;
    tv.tv_usec = (timeout % 1000)*1000;
    return select(fd + 1, &rfds, NULL,NULL,&tv);
    while(serial_poll(timeout)>0)   //当另一端传入数据时会接收到数据
        return read(serial_fd,buffer,len);
    write(serial_fd,buffer,len);
int adc_get(int ch)
    int channel;
    char cmd[128]={0};
    pclose(stream);
    return atoi(adc_v);
int main(int argc, char *argv[])
    int fd;
    uint8_t recv_buffer[128];
    int i, ret;
    uint8_t send_buffer[128];
    if (argc != 3)    //需要传入串口对应的设备名
        fprintf(stderr, "usage:serialtest com_port baudn");
        return -1;
    ret = serial_open(argv[1], atoi(argv[2]), SERIAL_PARITY_NO, 8, SERIAL_STOPBIT_ONE, 1000); //调用上面封装好的打开串口函数 传入设备名,波特率,校验位,数据位,停止位以及超时时间
    if (ret == 0)   //打开失败
        fprintf(stderr, "open serial failedn");
        return -1;
    memset(recv_buffer,0x55,sizeof(recv_buffer));
    while(1)
        //int len = 0;
        //if((len = uart_read(recv_buffer,sizeof(recv_buffer),100)) > 0)
        //  uart_write(recv_buffer,sizeof(recv_buffer));
        int adc = adc_get(1);
        snprintf(send_buffer,sizeof(send_buffer),"/* %d */rn",adc);
        uart_write(send_buffer,strlen(send_buffer));
    serial_close();
    return 0;
上位机
https://serial-studio.github.io/下下载安装Serial Studio
点击JSON编辑器按如下设置
点击添加组别
添加数据集
按如下设置点击申请
连接串口
控制台可以看到打印的值
仪表盘可以看到曲线
测试
使用滑动变阻分压得到模拟电压,旋转旋钮可以看到电压变化曲线。
总结
以上测试了ADC的采集,由于没有精度较高的DAC源和电压测量设备,所以就不测试其精度了。通过上位机的曲线显示,实现了简单的虚拟示波器的功能。
更多回帖
