环境搭建
首先进行换源和docker安装,深圳这边华为云比较快,其他地区可以用阿里云
sudo sed -i 's/archive.ubuntu.com/mirrors.aliyun.com/g' /etc/apt/sources.list
sudo sed -i 's/security.ubuntu.com/mirrors.aliyun.com/g' /etc/apt/sources.list
sudo sed -i 's/archive.ubuntu.com/repo.huaweicloud.com/g' /etc/apt/sources.list
sudo sed -i 's/security.ubuntu.com/repo.huaweicloud.com/g' /etc/apt/sources.list
sudo apt update
sudo apt upgrade
sudo curl -fsSL https://get.docker.com | bash -s docker --mirror Aliyun
sudo docker pull ubuntu:20.04
sudo docker run --name persim-m3 -itd ubuntu:20.04
sudo docker exec -it persim-m3 /bin/bash
在 docker 的 shell 中,执行以下命令
apt-get update
apt-get install sudo apt-utils vim net-tools inetutils-ping wget curl tree lbzip2 bzip2 git xz-utils python3 python2 python3-pip scons telnet
apt-get install -qq libncurses5-dev lib32z1 > /dev/null
apt-get install u-boot-tools zlib1g-dev dosfstools mtools
curl -s
ell/-/media/Files/downloads/gnu-rm/5_4-2016q3/gcc-arm-none-eabi-5_4-2016q3-20160926-linux,-d-,tar.bz2 | tar xjf - -C /opt
curl -s
oads/gnu-rm/10-2020q4/gcc-arm-none-eabi-10-2020-q4-major-x86_64-linux.tar.bz2 | tar xjf - -C /opt
vim /root/.bashrc
在 vim 中补充以下命令
alias get_persim_m3='
export RTT_ROOT=pwd/../rt-thread
export RTT_CC=gcc
export RTT_EXEC_PATH=/opt/gcc-arm-none-eabi-5_4-2016q3/bin
$RTT_EXEC_PATH/arm-none-eabi-gcc --version
vim /root/.bash_profile
在 vim 中补充以下命令
if test -f .bashrc ; then
source .bashrc
fi
以后只需在文件的 scons 路径下执行 get_persim_m3 命令,即可获取环境变量,随后便可实现编译
配合 DockerFile 食用更佳,构建命令: docker build -f ./dockerfile -t persim-m3:0.0 .
FROM ubuntu:20.04
RUN set -x
换源
RUN sed -i 's/archive.ubuntu.com/mirrors.aliyun.com/g' /etc/apt/sources.list
RUN sed -i 's/security.ubuntu.com/mirrors.aliyun.com/g' /etc/apt/sources.list
RUN sed -i 's/archive.ubuntu.com/repo.huaweicloud.com/g' /etc/apt/sources.list
RUN sed -i 's/security.ubuntu.com/repo.huaweicloud.com/g' /etc/apt/sources.list
RUN apt-get update
RUN apt-get upgrade -y
RUN apt-get install -y sudo apt-utils vim net-tools inetutils-ping wget curl tree lbzip2 bzip2 git xz-utils python3 python2 python3-pip scons telnet
RUN DEBIAN_FRONTEND="noninteractive" apt -y install tzdata
RUN TZ=Asia/Shanghai &&
ln -snf /usr/share/zoneinfo/$TZ /etc/localtime
RUN apt-get install -qq libncurses5-dev lib32z1 > /dev/null
RUN apt-get install -y u-boot-tools zlib1g-dev dosfstools mtools
RUN curl -s
RUN curl -s
RUN printf " alias get_persim_m3='\n" >> /root/.bashrc
RUN printf " export RTT_ROOT=pwd/../rt-thread\n" >> /root/.bashrc
RUN printf " export RTT_CC=gcc\n" >> /root/.bashrc
RUN printf " export RTT_EXEC_PATH=/opt/gcc-arm-none-eabi-5_4-2016q3/bin\n" >> /root/.bashrc
RUN printf " $RTT_EXEC_PATH/arm-none-eabi-gcc --version\n" >> /root/.bashrc
RUN printf "'\n" >> /root/.bashrc
RUN printf "if test -f .bashrc ; then\n" >> /root/.bash_profile
RUN printf " source .bashrc\n" >> /root/.bash_profile
RUN printf "fi\n" >> /root/.bash_profile
RUN apt clean
RUN rm -rf /var/lib/apt/lists/*
RUN mkdir /var/lib/apt/lists/partial
RUN cat /etc/issue
RUN python3 -V
RUN scons --version
VSCode配置文件
launch.json
"version": "0.2.0",
"configurations": [
"name": "arm-debug-bootloader",
"type": "cppdbg",
"request": "launch",
"miDebuggerPath": "/opt/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-gdb",
"program": "${workspaceRoot}/software/bootloader/rtthread.elf",
"setupCommands": [
"description": "为 gdb 启用整齐打印",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"text": "target remote localhost:3333"
"text": "restore ${workspaceRoot}/software/bootloader/rtthread.elf"
"text": "set $pc=0x81B00000"
"launchCompleteCommand": "None",
"cwd": "${workspaceFolder}"
"name": "arm-debug-app",
"type": "cppdbg",
"miDebuggerPath": "/opt/gcc-arm-none-eabi-5_4-2016q3/bin/arm-none-eabi-gdb",
"program": "${workspaceRoot}/software/firmware/rtthread.elf",
"setupCommands": [
"text": "restore ${workspaceRoot}/software/firmware/rtthread.elf"
"text": "set $pc=0x80000000"
tasks.json
// See
// for the documentation about the tasks.json format
"version": "2.0.0",
"tasks": [
"label": "build_bootloader",
"type": "shell",
"command": [
"export RTT_ROOT=pwd/software/rt-thread;",
"export RTT_CC=gcc;",
"export RTT_EXEC_PATH=/opt/gcc-arm-none-eabi-10-2020-q4-major/bin;",
"cd ${workspaceFolder}/software/bootloader;",
"scons -j8;"
"problemMatcher": []
"label": "clean_bootloader",
"type": "shell",
"command": [
"export RTT_EXEC_PATH=/gcc-arm-none-eabi-10-2020-q4-major/bin;",
"scons -c;"
"label": "build_app",
"type": "shell",
"command": [
"export RTT_EXEC_PATH=/opt/gcc-arm-none-eabi-5_4-2016q3/bin;",
"cd ${workspaceFolder}/software/firmware;",
"scons -j8;"
"label": "clean_app",
"type": "shell",
"command": [
"scons -c;"
使用 VSCode 一键编译
在SDK的根目录打开 VSCode,按下 F1,选择 Run Tasks,选择 build_app,即可编译。
原作者:小权一句两句
更多回帖
