视频高清双目视觉成像,显示文字毫无压力。
V853
开发板没有散热片,USB接口的
电源就可以驱动开发板和大屏。得益于低功耗设计和系统层级的优化,实现了每百Gflops算力仅需20mW的优秀功耗表现,3KAI视觉典型解决方案整体能耗小于500mW。结合全志科技全新一代μA级保活待机WiFi芯片XR806,在2500mAh的可视门铃上可做到半年以上免充电;在应用于低功耗摄像机方案时,搭配太阳能面板可实现无感运维,满足用户对低功耗AI产品长时间续航的体验需求。
开机过程:
开发需要再在Windows下安装adb工具
环境:Windows 10
1、下载和解压缩
下载地址:
https://developer.android.google.cn/studio/releases/platform-tools
2、配置环境变量
我的电脑,右键选择属性-->高级系统设置-->设置path=adb的路径
3 验证:cmd验证是否安装成功
adb version
测试开发板信息:
1 查看CPU处理器架构 :cat /proc/cpuinfo
2 查看内存cat /proc/meminfo
3 开发板信息网卡信息:
4 系统文件:
附件详细开箱过程:
- [50]HELLO! BOOT0 is starting!
- [53]BOOT0 commit :
- [55]set pll start
- [57]periph0 has been enabled
- [59]set pll end
- [62]PMU: AXP21
- [65]board init ok
- [67]DRAM use external ZQ!!
- [69]chip id check OK
- [72]DRAM_VCC set to 1500 mv
- [74]DRAM BOOT DRIVE INFO: V0.16
- [77]DRAM CLK = 936 MHz
- [79]DRAM Type = 3 (2:DDR2,3:DDR3)
- [83]DRAMC ZQ value: 0x7b7bfb
- [85]DRAM ODT value: 0x42.
- [89]DRAM SIZE =512 M
- [91]dram_tpr4:0x0
- [98]DRAM simple test OK.
- [100]rtc standby flag is 0x0, super standby flag is 0x0
- [106]dram size =512
- [108]audio:avcc calibration
- [111]card no is 2
- [113]sdcard 2 line count 8
- [115][mmc]: mmc driver ver 2021-12-27 10:07
- [125][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
- [130][mmc]: ***Try MMC card 2***
- [145][mmc]: RMCA OK!
- [147][mmc]: bias 100
- [149][mmc]: mmc 2 bias 100
- [153][mmc]: MMC 5.1
- [154][mmc]: HSSDR52/SDR25 8 bit
- [157][mmc]: 50000000 Hz
- [160][mmc]: 7400 MB
- [161][mmc]: ***SD/MMC 2 init OK!!!***
- [214]Loading boot-pkg Succeed(index=0).
- [218]Entry_name = optee
- [221]Entry_name = u-boot
- [228]Entry_name = dtb
- [231]tunning data addr:0x430003e8
- [234]Jump to second Boot.
- M/TC: OP-TEE version: 15ee1539b (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 ARM
- U-Boot 2018.05 (Jun 13 2022 - 17:38:36 +0800) Allwinner Technology
- [00.405]CPU: Allwinner Family
- [00.408]Model: sun8iw21
- I2C: ready
- [00.433]DRAM: 512 MiB
- [00.436]Relocation Offset is: 1ced0000
- [00.461]secure enable bit: 0
- E/TC:0 fdt_getprop_u32:343 prop trace_level not found
- [00.476]PMU: AXP21
- [00.477]BMU: AXP21
- FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
- bias_name:pc_bias bias_vol:1800
- bias_name:pi_bias bias_vol:1800
- [00.501]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=300Mhz
- [00.507]gic: sec monitor mode
- sunxi flash map init
- [00.513]flash init start
- [00.515]workmode = 0,storage type = 2
- [00.518][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
- [00.523][mmc]: get sdc_type fail and use default host:tm4.
- [00.530][mmc]: SUNXI SDMMC Controller Version:0x50400
- [00.558][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
- [00.564]sunxi flash init ok
- [00.567]line:724 init_clocks
- [00.570]drv_disp_init
- request pwm success, pwm9:pwm9:0x2000c00.
- [00.584]drv_disp_init finish
- [00.588]Loading Environment from SUNXI_FLASH... OK
- [00.600]boot_gui_init:start
- [00.602]set disp.dev2_output_type fail. using defval=0
- [00.607][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.612][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.617][ICN6202 TO LVDS] LINE:0167-->lcd_power_on:
- [00.634]boot_gui_init:finish
- partno erro : can't find partition bootloader
- 54 bytes read in 1 ms (52.7 KiB/s)
- [00.645]bmp_name=bootlogo.bmp size 3[00.648][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.652][ICN6202 TO LVDS] LINE:0575-->lcd_panel_init:
- [00.818][ICN6202 TO LVDS] LINE:0620-->lcd_panel_init:initialization:icn6202 init reg from mipi
- 8454
- 38454 bytes read in 1 ms (36.7 MiB/s)
- [00.848]Item0 (Map) magic is bad
- [00.851]the secure storage item0 copy0 magic is bad
- [00.855]Item0 (Map) magic is bad
- [00.858]the secure storage item0 copy1 magic is bad
- [00.863]Item0 (Map) magic is bad
- [00.866]out of usb burn from boot: not need burn key
- root_partition is rootfs
- set root to /dev/mmcblk0p4
- [00.875]update part info
- [00.878]update bootcmd
- [00.880]change working_fdt 0x5de8fe70 to 0x5de6fe70
- [00.887][mmc]: delete mmc-hs400-1_8v from dtb
- [00.891][mmc]: delete mmc-hs200-1_8v from dtb
- [00.895][mmc]: get max-frequency ok 50000000 Hz
- disable nand error: FDT_ERR_BADPATH
- [00.908]The storage not support sample function
- [00.915]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
- [00.924]update dts
- Hit any key to stop autoboot: 1 [00.947][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.956][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.961][ICN6202 TO LVDS] LINE:0203-->lcd_bl_open:
- [00.968][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.972][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
- [00.977]LCD open finish
- 0
- [02.002]no vendor_boot partition is found
- Android's image name: v853-vision
- [02.051]Starting kernel ...
- [02.053][mmc]: mmc exit start
- [02.072][mmc]: mmc 2 exit ok
- [ 0.000000] Booting Linux on physical CPU 0x0
- [ 0.000000] Linux version 4.9.191 (zhangyuanjings@AwExdroid96) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #13 PREEMPT Mon Jun 13 10:27:33 UTC 2022
- [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
- [ 0.000000] CPU: div instructions available: patching division code
- [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- [ 0.000000] OF: fdt:Machine model: sun8iw21
- [ 0.000000] ion_mem_reserve: err format for ion reserve list!
- [ 0.000000] disp reserve base 0x5df1a000 ,size 0x3e8000
- [ 0.000000] Reserved memory: created DMA memory pool at 0x47000000, size 0 MiB
- [ 0.000000] OF: reserved mem: initialized node vdev0buffer@47000000, compatible id shared-dma-pool
- [ 0.000000] Memory policy: Data cache writeback
- [ 0.000000] On node 0 totalpages: 129920
- [ 0.000000] free_area_init_node: node 0, pgdat c0b5d334, node_mem_map dfbf8000
- [ 0.000000] Normal zone: 1024 pages used for memmap
- [ 0.000000] Normal zone: 0 pages reserved
- [ 0.000000] Normal zone: 129920 pages, LIFO batch:31
- [ 0.000000] psci: probing for conduit method from DT.
- [ 0.000000] psci: PSCIv1.0 detected in firmware.
- [ 0.000000] psci: Using standard PSCI v0.2 function IDs
- [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
- [ 0.000000] psci: SMC Calling Convention v1.0
- [ 0.000000] CPU: All CPU(s) started in SVC mode.
- [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
- [ 0.000000] pcpu-alloc: [0] 0
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 128896
- [ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:rootfs_data@mmcblk0p5:recovery@mmcblk0p6:UDISK@mmcblk0p7 cma= mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=32K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw21p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05(06/13/2022-17:38:36) mbr_offset=1032192 disp_reserve=4096000,0x5df1a000 bootreason=usb androidboot.dramsize=512
- [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
- [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
- [ 0.000000] Memory: 498684K/519680K available (6144K kernel code, 376K rwdata, 2268K rodata, 1024K init, 181K bss, 20996K reserved, 0K cma-reserved, 0K highmem)
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
- [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
- [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
- [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
- [ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
- [ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
- [ 0.000000] .data : 0xc0b00000 - 0xc0b5e3d0 ( 377 kB)
- [ 0.000000] .bss : 0xc0b5e3d0 - 0xc0b8bb64 ( 182 kB)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
- [ 0.000000] Preemptible hierarchical RCU implementation.
- [ 0.000000] Build-time adjustment of leaf fanout to 32.
- [ 0.000000] NR_IRQS:16 nr_irqs:16 16
- [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
- [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
- [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
- [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
- [ 0.000019] Switching to timer-based delay loop, resolution 41ns
- [ 0.000200] Console: colour dummy device 80x30
- [ 0.000226] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
- [ 0.000241] pid_max: default: 32768 minimum: 301
- [ 0.000432] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
- [ 0.000444] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
- [ 0.000988] CPU: Testing write buffer coherency: ok
- [ 0.001495] Setting up static identity map for 0x40100000 - 0x40100058
- [ 0.003031] devtmpfs: initialized
- [ 0.040716] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
- [ 0.041219] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
- [ 0.041241] futex hash table entries: 256 (order: -1, 3072 bytes)
- [ 0.041390] atomic64_test: passed
- [ 0.041402] pinctrl core: initialized pinctrl subsystem
- [ 0.042496] NET: Registered protocol family 16
- [ 0.043181] DMA: preallocated 32 KiB pool for atomic coherent allocations
- [ 0.044555] dump_class_init,857, success
- [ 0.069479] cpuidle: using governor menu
- [ 0.070700] platform 2010000.iommu: iova_base: 0x48400000
- [ 0.071166] sunxi iommu: irq = 22
- [ 0.091684] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
- [ 0.093422] sunxi hwspinlock vbase:0xe0824000
- [ 0.095252] iommu: Adding device npu to group 0
- [ 0.096924] iommu: Adding device 1c0e000.ve to group 0
- [ 0.111166] iommu: Adding device 5410000.g2d to group 0
- [ 0.111975] iommu: Adding device 5000000.disp to group 0
- [ 0.122656] iommu: Adding device 5908000.tdm to group 0
- [ 0.123315] iommu: Adding device 5900000.isp to group 0
- [ 0.124132] iommu: Adding device 58ffffc.isp to group 0
- [ 0.124771] iommu: Adding device 58ffff8.isp to group 0
- [ 0.125599] iommu: Adding device 58ffff4.isp to group 0
- [ 0.126122] iommu: Adding device 5800800.vind:isp@4 to group 0
- [ 0.126858] iommu: Adding device 5910000.scaler to group 0
- [ 0.127293] iommu: Adding device 590fffc.scaler to group 0
- [ 0.127849] iommu: Adding device 590fff8.scaler to group 0
- [ 0.128270] iommu: Adding device 590fff4.scaler to group 0
- [ 0.128909] iommu: Adding device 5910400.scaler to group 0
- [ 0.129883] iommu: Adding device 59103fc.scaler to group 0
- [ 0.130483] iommu: Adding device 59103f8.scaler to group 0
- [ 0.130888] iommu: Adding device 59103f4.scaler to group 0
- [ 0.131533] iommu: Adding device 5910800.scaler to group 0
- [ 0.132076] iommu: Adding device 59107fc.scaler to group 0
- [ 0.132488] iommu: Adding device 59107f8.scaler to group 0
- [ 0.133067] iommu: Adding device 59107f4.scaler to group 0
- [ 0.133841] iommu: Adding device 5910c00.scaler to group 0
- [ 0.134448] iommu: Adding device 5910bfc.scaler to group 0
- [ 0.134964] iommu: Adding device 5910bf8.scaler to group 0
- [ 0.135463] iommu: Adding device 5910bf4.scaler to group 0
- [ 0.136826] iommu: Adding device vinc0 to group 0
- [ 0.137616] iommu: Adding device vinc4 to group 0
- [ 0.138551] iommu: Adding device vinc8 to group 0
- [ 0.139326] iommu: Adding device vinc12 to group 0
- [ 0.145636] iommu: Adding device e907_rproc@0 to group 0
- [ 0.146010] iommu: Adding device rpbuf_controller@0 to group 0
- [ 0.184642] pwm module init!
- [ 0.189202] sunxi-pm debug v3.10
- [ 0.193622] SCSI subsystem initialized
- [ 0.194372] usbcore: registered new interface driver usbfs
- [ 0.194558] usbcore: registered new interface driver hub
- [ 0.194707] usbcore: registered new device driver usb
- [ 0.195008] sunxi_i2c_adap_init()2754 - init
- [ 0.195534] sunxi_i2c_probe()2449 - [i2c0] twi_drv_used = 0
- [ 0.195551] sunxi_i2c_probe()2456 - [i2c0] twi_pkt_interval = 0
- [ 0.195628] twi_regulator_request()653 - [i2c0] regulator not found(isn't configured in dts)!
- [ 0.195638] twi_request_gpio()469 - [i2c0] init name: (null)
- [ 0.196874] sunxi_i2c_probe()2449 - [i2c1] twi_drv_used = 0
- [ 0.196893] sunxi_i2c_probe()2456 - [i2c1] twi_pkt_interval = 0
- [ 0.196975] twi_regulator_request()653 - [i2c1] regulator not found(isn't configured in dts)!
- [ 0.196985] twi_request_gpio()469 - [i2c1] init name: (null)
- [ 0.198674] sunxi_i2c_probe()2449 - [i2c2] twi_drv_used = 0
- [ 0.198693] sunxi_i2c_probe()2456 - [i2c2] twi_pkt_interval = 0
- [ 0.198771] twi_regulator_request()653 - [i2c2] regulator not found(isn't configured in dts)!
- [ 0.198782] twi_request_gpio()469 - [i2c2] init name: (null)
- [ 0.200444] sunxi_i2c_probe()2449 - [i2c3] twi_drv_used = 0
- [ 0.200463] sunxi_i2c_probe()2456 - [i2c3] twi_pkt_interval = 0
- [ 0.200540] twi_regulator_request()653 - [i2c3] regulator not found(isn't configured in dts)!
- [ 0.200550] twi_request_gpio()469 - [i2c3] init name: (null)
- [ 0.201789] sunxi_i2c_probe()2449 - [i2c4] twi_drv_used = 0
- [ 0.201807] sunxi_i2c_probe()2456 - [i2c4] twi_pkt_interval = 0
- [ 0.201886] twi_regulator_request()653 - [i2c4] regulator not found(isn't configured in dts)!
- [ 0.201897] twi_request_gpio()469 - [i2c4] init name: (null)
- [ 0.203233] axp20x-i2c 4-0034: AXP20x variant AXP2101 found
- [ 0.219387] random: fast init done
- [ 0.233265] axp20x-i2c 4-0034: AXP20X driver loaded
- [ 0.233687] media: Linux media interface: v0.10
- [ 0.233763] Linux video capture interface: v2.00
- [ 0.237941] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
- [ 0.238265] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
- [ 0.239478] Advanced Linux Sound Architecture Driver Initialized.
- [ 0.240650] Bluetooth: Core ver 2.22
- [ 0.240797] NET: Registered protocol family 31
- [ 0.240809] Bluetooth: HCI device and connection manager initialized
- [ 0.240831] Bluetooth: HCI socket layer initialized
- [ 0.240845] Bluetooth: L2CAP socket layer initialized
- [ 0.240885] Bluetooth: SCO socket layer initialized
- [ 0.244070] G2D: rcq version initialized.major:251
- [ 0.245850] clocksource: Switched to clocksource arch_sys_counter
- [ 0.274475] udc_init,0
- [ 0.275600] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
- [ 0.276310] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
- [ 0.276495] NET: Registered protocol family 2
- [ 0.296140] TCP established hash table entries: 16 (order: -6, 64 bytes)
- [ 0.296158] TCP bind hash table entries: 16 (order: -6, 64 bytes)
- [ 0.296168] TCP: Hash tables configured (established 16 bind 16)
- [ 0.296232] UDP hash table entries: 256 (order: 0, 4096 bytes)
- [ 0.296252] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
- [ 0.296473] NET: Registered protocol family 1
- [ 0.300495] workingset: timestamp_bits=29 max_order=17 bucket_order=0
- [ 0.316859] squashfs: version 4.0 (2009/01/31) Phillip Lougher
- [ 0.321060] io scheduler noop registered
- [ 0.321076] io scheduler deadline registered
- [ 0.321366] io scheduler cfq registered (default)
- [ 0.322601] [DISP]disp_module_init
- [ 0.323981] [DISP] disp_init,line:2340:
- [ 0.323995] smooth display screen:0 type:1 mode:4
- [ 0.361329] lcd 0, driver_name icn6202, panel_name default_lcd
- [ 0.361348] lcd 0, driver_name icn6202, panel_name he0801a068
- [ 0.361355] lcd 0, driver_name icn6202, panel_name inet_dsi_panel
- [ 0.361363] lcd 0, driver_name icn6202, panel_name lq101r1sx03
- [ 0.361371] lcd 0, driver_name icn6202, panel_name WilliamLcd
- [ 0.361379] lcd 0, driver_name icn6202, panel_name bp101wx1
- [ 0.361386] lcd 0, driver_name icn6202, panel_name k101im2qa04
- [ 0.361394] lcd 0, driver_name icn6202, panel_name t050k589
- [ 0.361402] lcd 0, driver_name icn6202, panel_name kd080d24
- [ 0.361409] lcd 0, driver_name icn6202, panel_name icn6202
- [ 0.361427] lcd 0, driver_name icn6202, panel_name super_lcd_driver
- [ 0.361569] display_fb_request,fb_id:0
- [ 0.372130] [DISP] de_fcm_set_para,line:491:
- [ 0.372144] fcm lut 0 not find, auto retry after init
- [ 0.373385] [DISP]disp_module_init finish
- [ 0.376138] [DISP] de_fcm_set_para,line:491:
- [ 0.376151] fcm lut 0 not find, auto retry after init
- [ 0.376176] [DISP] de_fcm_set_para,line:491:
- [ 0.376182] fcm lut 0 not find, auto retry after init
- [ 0.376250] [DISP] lcd_clk_config,line:669:
- [ 0.376265] disp 0, clk: pll(426000000),clk(426000000),dclk(71000000) dsi_rate(71000000)
- [ 0.376265] clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
- [ 0.382348] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
- [ 0.382381] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
- [ 0.473464] Freeing logo buffer memory: 4000K
- [ 1.648475] console [ttyS0] enabled
- [ 1.653933] uart3: ttyS3 at MMIO 0x2500c00 (irq = 290, base_baud = 1500000) is a SUNXI
- [ 1.664299] misc dump reg init
- [ 1.668718] npu[1][1] vipcore, platform driver device=0xdf5fa410
- [ 1.675537] npu[1][1] vipcore irq number is 291.
- [ 1.680924] gckvip_drv_adjust_param 232 SUCCESS
- [ 1.686183] Want set pclk rate(504000000) support(504000000) real(504000000)
- [ 1.694157] Want set mclk rate(504000000) support(504000000) real(504000000)
- [ 1.702209] npu[1][1] This device support 64bits DMA
- [ 1.708292] npu[1][1] core_0, request irqline=291, name=vipcore_0
- [ 1.715211] npu[1][1] =======vipcore parameter=====
- [ 1.720937] npu[1][1] registerMemBase 0x03050000,
- [ 1.726766] npu[1][1] registerMemSize 0x00020000,
- [ 1.732576] npu[1][1] irqLine 0x00000123,
- [ 1.738385] npu[1][1] contiguousSize 0x02000000
- [ 1.743961] npu[1][1] contiguousBase 0x30000000
- [ 1.749623] npu[1][1] vipContiguousBase 0x0
- [ 1.754516] npu[1][1] drvType 0x00000000
- [ 1.760125] npu[1][1] AXISramSize 0x00000000
- [ 1.765723] npu[1][1] AXISramBaseAddress 0x00000000
- [ 1.771329] npu[1][1] VIPSramSize 0x00020000
- [ 1.776919] npu[1][1] VIPSramBaseAddress 0x00400000
- [ 1.782504] npu[1][1] sysHeapSize 0x00200000
- [ 1.788091] npu[1][1] ===============================
- [ 1.793859] npu[1][1] VIPLite driver version 1.8.0.0-AW-2022-04-21
- [ 1.802121] sun8iw21p1-pinctrl pio: expect_func as:fanout0, but muxsel(3) is func:clk
- [ 1.811242] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
- [ 1.817611] sunxi-wlan soc@03000000:wlan@0: wlan power voltage (3300000)
- [ 1.825144] sunxi-wlan soc@03000000:wlan@0: wlan io voltage (3300000)
- [ 1.832442] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (1)
- [ 1.839082] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp2101-dcdc1)
- [ 1.846941] sunxi-wlan soc@03000000:wlan@0: io_regulator_name (axp2101-dcdc1)
- [ 1.855015] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=239 mul-sel=1 pull=1 drv_level=2 data=0
- [ 1.865659] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
- [ 1.872745] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=199 mul-sel=14 pull=1 drv_level=2 data=0
- [ 1.883837] sunxi-wlan soc@03000000:wlan@0: clk_name ()
- [ 1.891201] libphy: Fixed MDIO Bus: probed
- [ 1.896680] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- [ 1.904429] get ehci0-controller, regulator_io is no nocare
- [ 1.910878] get ehci0-controller wakeup-source is fail.
- [ 1.917002] sunxi ehci0-controller don't init wakeup source
- [ 1.923273] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b7eb00, 0x:e0848000, irq_no:137
- [ 1.935552] [sunxi-ehci0]: Not init ehci0
- [ 1.940592] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- [ 1.948149] get ohci0-controller, regulator_io is no nocare
- [ 1.954414] get ohci0-controller wakeup-source is fail.
- [ 1.960498] sunxi ohci0-controller don't init wakeup source
- [ 1.966939] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0b7ed24
- [ 1.976690] [sunxi-ohci0]: Not init ohci0
- [ 1.981875] usbcore: registered new interface driver uas
- [ 1.988285] usbcore: registered new interface driver usb-storage
- [ 1.995296] usbcore: registered new interface driver ums-alauda
- [ 2.002227] usbcore: registered new interface driver ums-cypress
- [ 2.009265] usbcore: registered new interface driver ums-datafab
- [ 2.016400] usbcore: registered new interface driver ums_eneub6250
- [ 2.023591] usbcore: registered new interface driver ums-freecom
- [ 2.030586] usbcore: registered new interface driver ums-isd200
- [ 2.037562] usbcore: registered new interface driver ums-jumpshot
- [ 2.044657] usbcore: registered new interface driver ums-karma
- [ 2.051514] usbcore: registered new interface driver ums-onetouch
- [ 2.058727] usbcore: registered new interface driver ums-realtek
- [ 2.065753] usbcore: registered new interface driver ums-sddr09
- [ 2.072621] usbcore: registered new interface driver ums-sddr55
- [ 2.079559] usbcore: registered new interface driver ums-usbat
- [ 2.086431] usb_serial_number:20080411
- [ 2.091038] reset the tp !!!!!!
- [ 2.196043] sunxi_i2c_do_xfer()1974 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x5d)
- [ 2.205455] Goodix-TS 2-005d: read version failed: -70
- [ 2.211245] Goodix-TS 2-005d: Read version failed.
- [ 2.216695] Goodix-TS: probe of 2-005d failed with error -70
- [ 2.223388] ERROR! get ctp_para failed, func:sunxi_ctp_startup, line:46
- [ 2.231004] =========script_get_item_err============
- [ 2.243393] input: axp2101-pek as /devices/platform/soc/twi4/i2c-4/4-0034/axp2101-pek.0/input/input0
- [ 2.255702] input: sunxi-wiegand0 as /devices/virtual/input/input1
- [ 2.264103] sunxi_gpadc_init,1949, success
- [ 2.269393] sunxi_gpadc_setup: get channel scan data failed
- [ 2.276907] input: sunxi-gpadc0 as /devices/virtual/input/input2
- [ 2.285827] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
- [ 2.293096] sunxi-rtc rtc: RTC enabled
- [ 2.297488] fix to cold boot, save boot reason
- [ 2.302888] i2c /dev entries driver
- [ 2.308593] sunxi cedar version 0.1
- [ 2.312857] VE: install start!!!
- [ 2.312857]
- [ 2.318715] VE: cedar-ve the get irq is 292
- [ 2.323517] VE: regs_csi = e0883000
- [ 2.328092] VE: ve_debug_proc_info:c0b83578, data:df6c0000, lock:c0b83600, flag: 1
- [ 2.328092]
- [ 2.338520] VE: install end!!!
- [ 2.338520]
- [ 2.344088] google_vp9: sunxi google vp9 version 0.1
- [ 2.354269] axp2101_charger: read chipid = 4a
- [ 2.354269]
- [ 2.368518] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
- [ 2.400374] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
- [ 2.410156] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
- [ 2.417948] Bluetooth: HCI UART protocol H4 registered
- [ 2.423721] Bluetooth: HCI H4 protocol initialized
- [ 2.430312] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
- [ 2.439441] axp2101_charger: the gauge have been reset, need to reload param
- [ 2.439441]
- [ 2.449322] bt_fdi debugfs_init
- [ 2.453166] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 900000 KHz
- [ 2.495909] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 912000 KHz
- [ 2.536465] cpuidle: enable-method property 'psci' found operations
- [ 2.545806] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
- [ 2.554969] sunxi-mmc sdc2: ***ctl-spec-caps*** 308
- [ 2.561340] sunxi-mmc sdc2: No vdmmc regulator found
- [ 2.567037] sunxi-mmc sdc2: No vd33sw regulator found
- [ 2.572698] sunxi-mmc sdc2: No vd18sw regulator found
- [ 2.578416] sunxi-mmc sdc2: No vq33sw regulator found
- [ 2.584076] sunxi-mmc sdc2: No vq18sw regulator found
- [ 2.590183] sunxi-mmc sdc2: set host busy
- [ 2.594762] mmc:failed to get gpios
- [ 2.599039] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.635901] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.675880] sunxi-mmc sdc2: detmode:alway in(non removable)
- [ 2.675905] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.684279] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.685350] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.696188] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.696254] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.709082] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.753741] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
- [ 2.762704] sunxi-mmc sdc0: ***ctl-spec-caps*** 408
- [ 2.769989] sunxi-mmc sdc0: No vqmmc regulator found
- [ 2.775559] sunxi-mmc sdc0: No vdmmc regulator found
- [ 2.781675] sunxi-mmc sdc0: set host busy
- [ 2.786282] sunxi-mmc sdc0: Got CD GPIO
- [ 2.790981] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.837097] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 2.860978] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing MMC-HS(SDR20) dt B
- [ 2.872166] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 1 timing MMC-HS(SDR20) dt B
- [ 2.883336] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
- [ 2.894524] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-DDR52 dt B
- [ 2.905446] mmc0: new DDR MMC card at address 0001
- [ 2.912373] mmcblk0: mmc0:0001 AT2S38 7.23 GiB
- [ 2.918171] mmcblk0boot0: mmc0:0001 AT2S38 partition 1 4.00 MiB
- [ 2.925056] mmcblk0boot1: mmc0:0001 AT2S38 partition 2 4.00 MiB
- [ 2.932062] mmcblk0rpmb: mmc0:0001 AT2S38 partition 3 4.00 MiB
- [ 2.940591] mmcblk0: p1 p2 p3 p4 p5 p6 p7
- [ 3.045940] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
- [ 3.075869] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
- [ 3.116045] sunxi-mmc sdc0: detmode:gpio irq
- [ 3.121303] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
- [ 3.130278] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
- [ 3.135619] sunxi-mmc sdc1: No vmmc regulator found
- [ 3.141118] sunxi-mmc sdc1: No vqmmc regulator found
- [ 3.146709] sunxi-mmc sdc1: No vdmmc regulator found
- [ 3.152272] sunxi-mmc sdc1: No vd33sw regulator found
- [ 3.157942] sunxi-mmc sdc1: No vd18sw regulator found
- [ 3.163609] sunxi-mmc sdc1: No vq33sw regulator found
- [ 3.169279] sunxi-mmc sdc1: No vq18sw regulator found
- [ 3.175339] sunxi-mmc sdc1: set host busy
- [ 3.179933] mmc:failed to get gpios
- [ 3.184145] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.215904] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.255880] sunxi-mmc sdc1: detmode:manually by software
- [ 3.261874] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.267877] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.267898] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.275956] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.287770] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.298524] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.304412] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.310294] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.310320] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
- [ 3.311394] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.333463] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
- [ 3.343806] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.366340] usbcore: registered new interface driver usbhid
- [ 3.372608] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.378837] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.378892] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.387047] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.398886] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.409735] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.415638] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.421522] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.421548] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
- [ 3.422626] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.455153] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.466467] usbhid: USB HID core driver
- [ 3.474646] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
- [ 3.485228] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.491656] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
- [ 3.502524] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.502589] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.510784] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.522732] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.533553] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.539458] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.545345] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.545364] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
- [ 3.546449] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.579789] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.592908] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
- [ 3.605657] Netfilter messages via NETLINK v0.30.
- [ 3.611631] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
- [ 3.618419] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.624527] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
- [ 3.624569] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.632789] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 3.644778] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.655592] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.661510] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.667403] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
- [ 3.667422] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
- [ 3.690679] ctnetlink v0.93: registering with nfnetlink.
- [ 3.696985] ip_tables: (C) 2000-2006 Netfilter Core Team
- [ 3.703984] NET: Registered protocol family 10
- [ 3.710448] NET: Registered protocol family 17
- [ 3.715476] NET: Registered protocol family 15
- [ 3.720735] Bluetooth: RFCOMM TTY layer initialized
- [ 3.726365] Bluetooth: RFCOMM socket layer initialized
- [ 3.732142] Bluetooth: RFCOMM ver 1.11
- [ 3.737533] Registering SWP/SWPB emulation handler
- [ 3.750759] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
- [ 3.759848] clk: Not disabling unused clocks
- [ 3.764758] usb-vbus: disabling
- [ 3.768714] axp2101-dcdc2: disabling
- [ 3.773428] axp2101-rtcldo1: disabling
- [ 3.777962] axp2101-aldo2: disabling
- [ 3.782640] axp2101-aldo3: disabling
- [ 3.787354] axp2101-aldo4: disabling
- [ 3.792042] axp2101-bldo2: disabling
- [ 3.796759] axp2101-dldo2: disabling
- [ 3.801444] axp2101-cpusldo: disabling
- [ 3.806099] ALSA device list:
- [ 3.809421] #0: audiocodec
- [ 3.812642] #1: snddaudio0
- [ 3.831707] VFS: Mounted root (squashfs filesystem) readonly on device 179:4.
- [ 3.841121] devtmpfs: mounted
- [ 3.846241] Freeing unused kernel memory: 1024K
- [ 3.851439] will run init ...
- mount: mounting none on /dev failed: Resource busy
- [ 4.048468] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
- [ 4.061366] EXT4-fs (mmcblk0p5): mounted filesystem with journalled data mode. Opts: data=journal
- starting pid 836, tty '': '/etc/preinit'
- can't run '/etc/preinit': No such file or directory
- starting pid 837, tty '': '/bin/mount -t proc proc /proc'
- mount: mounting proc on /proc failed: Resource busy
- starting pid 838, tty '': '/bin/mount -t tmpfs tmpfs /run'
- starting pid 839, tty '': '/bin/mount -o remount,rw /'
- starting pid 840, tty '': '/bin/mkdir -p /dev/pts'
- starting pid 841, tty '': '/bin/mkdir -p /dev/shm'
- starting pid 842, tty '': '/bin/mount -a'
- starting pid 843, tty '': '/bin/hostname -F /etc/hostname'
- hostname: can't open '/etc/hostname': No such file or directory
- starting pid 844, tty '': '/etc/init.d/rcS boot'
- ------run rc.preboot file-----
- [ 4.218326] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
- ------run rc.modules file-----
- [ 4.277482] ======== XRADIO WIFI OPEN ========
- [ 4.282473] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33 Jun 13 2022 08:42:37
- [ 4.291002] [XRADIO] Allocated hw_priv @ dec24c80
- [ 4.296553] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
- [ 4.305490] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
- [ 4.312918] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
- [ 4.322826] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
- [ 4.441670] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 4.451946] [XRADIO] Detect SDIO card 1
- [ 4.495896] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 4.536506] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 4.549705] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
- [ 4.570752] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
- [ 4.581472] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
- [ 4.592481] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
- [ 4.604288] mmc2: new high speed SDIO card at address 0001
- [ 4.611087] [SBUS] XRadio Device:sdio clk=50000000
- [ 4.617303] [XRADIO] XRADIO_HW_REV 1.0 detected.
- [ 4.696293] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
- [ 4.736739] [XRADIO] Bootloader complete
- [ 4.825712] [XRADIO] Firmware completed.
- [ 4.831546] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
- [ 4.848971] [XRADIO] Firmware Startup Done.
- [ 4.853944] [XRADIO_WRN] enable Multi-Rx!
- [ 4.872448] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
- ------run rc.final file-----
- Load mpp modules
- [ 4.949098] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
- [ 4.959910] [VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
- [ 4.970404] [VIN_WARN]sensor_helper_probe: cannot get sensor1_avdd supply, setting it to NULL!
- [ 4.980323] [VIN_WARN]sensor_helper_probe: cannot get sensor1_dvdd supply, setting it to NULL!
- [ 5.301753] [VIN_ERR]registering tp9953, No such device!
- insmod: can't insert '/lib/modules/4.9.191/sunxi_aio.ko': No such file or directory
- insmod: can't insert '/lib/modules/4.9.191/sunxi_eise.ko': No such file or directory
- Starting logging: start-stop-daemon: unrecognized option: exec
- start-stop-daemon: unrecognized option: exec
- OK
- Starting audio: Successfully play boot music
- Populating /dev using udev: playing '/home/res/audio/startup.wav': 2 ch, 48000 hz, 16 bit
- [ 5.411919] udevd[964]: could not create /tmp/run/udev: No such file or directory
- done
- mkdir: can't create directory '/dev/pts': File exists
- mkdir: can't create directory '/dev/shm': File exists
- Initializing random number generator... [ 5.575010] random: dd: uninitialized urandom read (512 bytes read)
- done.
- Starting network: Failed to connect to ubus
- /sbin/ifup: line 51: /sbin/wifi: not found
- FAIL
- ifconfig: invalid hw-addr 00:
- udhcpc: SIOCGIFINDEX: No such device
- Starting telnetd: OK
- enable android usb
- insmod: can't insert '/lib/modules/4.9.191/sunxi_usb_udc.ko': No such file or directory
- insmod: can't insert '/lib/modules/4.9.191/sunxi_usbc.ko': No such file or directory
- [ 5.724255] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
- [ 5.745140] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
- Unknown group "lp" in message bus configuration file
- [ 5.870979] file system registered
- [ 5.886736] configfs-gadget 4100000.udc-controller: failed to start g1: -19
- sh: write error: No such device
- Starting wifi_deamon....: [ 5.906124] read descriptors
- [ 5.909372] read strings
- [1;32m1970-01-01 00:00:08:693: WMG_INFO [wifi_deamon.c:main:817]: debug log level is: 3
- [0m[1;32m1970-01-01 00:00:08:694: WMG_INFO [wifi_deamon.c:main:819]: now set to debug level: 6
- [0m[ACT D][ring_buff_init,27]enter
- [ACT D][ring_buff_start,173]ring buffer start enter
- [ACT D][ring_buff_start,187]ring buffer start quit
- [ 7.325872]
- [ 7.325872] insmod_device_driver
- [ 7.325872]
- [ 7.574851] android_work: sent uevent USB_STATE=CONNECTED
- [ 7.670528] configfs-gadget gadget: high-speed config #1: c
- [ 7.676880] android_work: sent uevent USB_STATE=CONFIGURED
- 1970-01-01 00:00:10:705: WMG_DEBUG [wifi_deamon.c:cmd_handle_thread:702]: get cmd: o sta
- 1970-01-01 00:00:10:705: WMG_DEBUG [wifi_deamon.c:cmd_handle_o:49]: cmd handle o: sta
- [1;32m1970-01-01 00:00:10:705: WMG_INFO [wifi_deamon.c:cmd_handle_o:51]: open sta mode
- [0m[1;32m1970-01-01 00:00:10:705: WMG_INFO [src/wmg_sta.c:sta_mode_init:363]: sta mode init now
- [0m[1;32m1970-01-01 00:00:10:705: WMG_INFO [src/os/linux/linux_wpa.c:linux_supplicant_init:1355]: linux supplicant init now
- [0m[1;32m1970-01-01 00:00:10:705: WMG_INFO [src/wmg_ap.c:ap_mode_init:216]: [ 8.004633] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
- ap mode init now
- [0m[1;32m1970-01-01 00:00:10:705: WMG_INFO [src/os/linux/linux_hapd.c:linux_ap_hapd_init:754]: linux hostapd init now
- [0m[1;32m1970-01-01 00:00:10:705: WMG_INFO [src/wmg_monitor.c:monitor_mode_init:206]: monitor mode init now
- [0m[1;32m1970-01-01 00:00:10:705: WMG_INFO [src/os/linux/linux_nl.c:linux_monitor_nl_init:250]: linux monitor nl init now
- [0m1970-01-01 00:00:10:706: WMG_DEBUG [src/os/linux/linux_nl.c:linux_monitor_nl_init:255]: nl80211 init success
- 1970-01-01 00:00:10:706: WMG_DEBUG [src/wmg_common.c:wifimg_init:143]: wifi_manager initialize, version: 2.0.1
- Copyright (c) 2019-2025 Allwinner Technology Co., Ltd. ALL rights reserved
- 1970-01-01 00:00:10:706: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:256]: switch wifi mode from current_mode 'unknown' to new_mode 'station'
- 1970-01-01 00:00:10:706: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:260]: switch_mode_bitmap:0x1
- 1970-01-01 00:00:10:706: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:261]: current_mode_bitmap:0x0
- 1970-01-01 00:00:10:706: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:264]: disable_mode_bitmap:0x0
- 1970-01-01 00:00:10:706: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:294]: enable_mode_bitmap:0x1
- 1970-01-01 00:00:10:706: WMG_DUMP [sr[ 8.126630] urandom_read: 2 callbacks suppressed
- c/wmg_sta.c:sta_mode_enable:412][ 8.126636] random: wpa_supplicant: uninitialized urandom read (3 bytes read)
- : wifi station enabling...
- /etc[ 8.144194] random: wpa_supplicant: uninitialized urandom read (1024 bytes read)
- /init.d/rcS: /etc/init.d/rc.final: line 36: powerkey_daemon: not found
- 1970-01-01 00:00:10:743: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: hostapd not exist
- Trying to connect to SWUpdate...
- ------ Scanning Wifi -----
- 1970-01-01 00:00:10:800: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
- 1970-01-01 00:00:10:801: WMG_DEBUG [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1429]: wpa_supplicant is not running, need to start it
- 1970-01-01 00:00:10:810: WMG_DEBUG [wifi_deamon.c:cmd_handle_thread:702]: get cmd: o sta
- 1970-01-01 00:00:10:810: WMG_DEBUG [wifi_deamo[ 8.208558] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=e4:3a:c9:41:f8:ad
- n.c:cmd_handle_o:49]: cmd handl[ 8.218995] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=e4:3a:c9:41:f8:ad
- e o: sta
- [1;32m1970-01-01 00:00:10:810: WMG_INFO [wifi_deamon.c:cmd_handle_o:51]: open sta mo[ 8.237111] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
- de
- ------ Light up LED -----
- [0m1970-01-01 00:00:10:838: WMG_DEBUG [wifi_deamon.c:cmd_handle_thread:702]: get cmd: s
- 1970-01-01 00:00:10:838: WMG_DEBUG [wifi_deamon.c:cmd_handle_s:196]: [ 8.260801] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
- cmd handle s:
- swu_param: ####
- swu_software: ####
- swu_mode: ####
- no swupdate_cmd to run, wait for next swupdate
- Successfully initialized wpa_supplicant
- [ 8.315752] random: wpa_supplicant: uninitialized urandom read (3 bytes read)
- 1970-01-01 00:00:11:826: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:29]: wpa_supplicant exist
- 1970-01-01 00:00:11:826: WMG_DEBUG [src/os/linux/linux_wpa.c:start_supplicant:359]: start wpa_supplicant times 1 success
- 1970-01-01 00:00:11:826: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1436]: start wpa_supplicant success
- 1970-01-01 00:00:11:827: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_connect_on_socket_path:160]: connect to wpa_supplicant ok!
- 1970-01-01 00:00:11:827: WMG_DUMP [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1471]: create linux sta event handle thread success
- 1970-01-01 00:00:11:827: WMG_DUMP [src/wmg_sta.c:sta_mode_enable:420]: start wpa_supplicant success
- 1970-01-01 00:00:11:827: WMG_DUMP [src/wmg_sta.c:sta_mode_enable:424]: wifi station enable success
- 1970-01-01 00:00:11:827: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:300]: wifi sta mode enable success
- 1970-01-01 00:00:11:827: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:320]: switch after current_mode_bitmap:0x1
- 1970-01-01 00:00:11:827: WMG_DEBUG [src/wifimg.c:__wifi_on:31]: switch wifi mode success
- [1;32m1970-01-01 00:00:11:828: WMG_INFO [wifi_deamon.c:cmd_handle_o:55]: wifi on sta mode success
- [0m1970-01-01 00:00:11:828: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:250]: switch_mode 'station' equals to current_mode 'station'do not need switch wifi mode
- 1970-01-01 00:00:11:828: WMG_DEBUG [src/wifimg.c:__wifi_on:31]: switch wifi mode success
- [0m1970-01-01 00:00:11:828: WMG_DEBUG [src/wmg_sta.c:sta_mode_ctl:463]: =====sta_mode_ctl cmd: 8=====
- 1970-01-01 00:00:11:828: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SCAN
- 1970-01-01 00:00:11:829: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SCAN, reply: OK
- 1970-01-01 00:00:11:836: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-SCAN-STARTED
- 1970-01-01 00:00:11:836: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-SCAN-STARTED
- 1970-01-01 00:00:11:836: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:SCAN-STARTED
- 1970-01-01 00:00:11:836: WMG_EXCESSIVE [src/os/linux/event.c:evt_read:128]: Excessive: read event 1
- 1970-01-01 00:00:11:836: WMG_DUMP [src/os/linux/linux_wpa.c:wpa_get_scan_results:1176]: receive wpas event 'SCAN_STARTED'
- 1970-01-01 00:00:13:347: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 0 74:50:4e:34:fd:10
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 0 74:50:4e:34:fd:10
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
- 1970-01-01 00:00:13:348: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 1 74:50:4e:34:fd:11
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 1 74:50:4e:34:fd:11
- 1970-01-01 00:00:13:348: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 2 74:50:4e:35:03:f1
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 2 74:50:4e:35:03:f1
- 1970-01-01 00:00:13:348: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 3 74:50:4e:35:03:f0
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 3 74:50:4e:35:03:f0
- 1970-01-01 00:00:13:348: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 4 74:50:4e:34:d8:b1
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 4 74:50:4e:34:d8:b1
- 1970-01-01 00:00:13:348: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 5 74:50:4e:34:fc:90
- 1970-01-01 00:00:13:348: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 5 74:50:4e:34:fc:90
- 1970-01-01 00:00:13:349: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
- 1970-01-01 00:00:13:349: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 6 74:50:4e:34:d8:b0
- 1970-01-01 00:00:13:349: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 6 74:50:4e:34:d8:b0
- 1970-01-01 00:00:13:349: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 7 74:50:4e:34:c4:71
- 1970-01-01 00:00:13:349: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 7 74:50:4e:34:c4:71
- 1970-01-01 00:00:13:349: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 8 74:50:4e:34:c4:70
- 1970-01-01 00:00:13:349: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 8 74:50:4e:34:c4:70
- 1970-01-01 00:00:13:349: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 9 74:50:4e:34:f8:30
- 1970-01-01 00:00:13:349: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 9 74:50:4e:34:f8:30
- 1970-01-01 00:00:13:349: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 10 74:50:4e:34:f8:d0
- 1970-01-01 00:00:13:680: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 10 74:50:4e:34:f8:d0
- 1970-01-01 00:00:13:680: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
- 1970-01-01 00:00:13:681: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 11 74:50:4e:34:f8:d1
- 1970-01-01 00:00:13:681: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 11 74:50:4e:34:f8:d1
- 1970-01-01 00:00:13:681: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
- 1970-01-01 00:00:13:681: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 12 74:50:4e:34:f8:31
- 1970-01-01 00:00:13:681: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 12 74:50:4e:34:f8:31
- 1970-01-01 00:00:13:681: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 13 74:50:4e:35:01:b0
- 1970-01-01 00:00:13:681: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 13 74:50:4e:35:01:b0
- 1970-01-01 00:00:13:681: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 14 74:50:4e:35:01:b1
- 1970-01-01 00:00:13:681: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 14 74:50:4e:35:01:b1
- 1970-01-01 00:00:13:681: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 15 74:50:4e:35:03:11
- 1970-01-01 00:00:13:681: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 15 74:50:4e:35:03:11
- 1970-01-01 00:00:13:681: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 16 74:50:4e:35:03:10
- 1970-01-01 00:00:13:682: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 16 74:50:4e:35:03:10
- 1970-01-01 00:00:13:682: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
- 1970-01-01 00:00:13:682: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 17 74:50:4e:34:fc:f0
- 1970-01-01 00:00:13:682: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 17 74:50:4e:34:fc:f0
- 1970-01-01 00:00:13:682: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-SCAN-RESULTS 50:4e:34:fc:f0
- 1970-01-01 00:00:13:682: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-SCAN-RESULTS
- 1970-01-01 00:00:13:682: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:SCAN-RESULTS
- 1970-01-01 00:00:13:682: WMG_EXCESSIVE [src/os/linux/event.c:evt_read:128]: Excessive: read event 3
- 1970-01-01 00:00:13:682: WMG_DUMP [src/os/linux/linux_wpa.c:wpa_get_scan_results:1176]: receive wpas event 'SCAN_RESULTS'
- 1970-01-01 00:00:14:013: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SCAN_RESULTS
- 1970-01-01 00:00:13:682: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-NETWORK-NOT-FOUND :34:fc:f0
- 1970-01-01 00:00:14:013: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-NETWORK-NOT-FOUND
- 1970-01-01 00:00:14:013: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:NETWORK-NOT-FOUND
- 1970-01-01 00:00:14:014: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SCAN_RESULTS, reply: bssid / frequency / signal level / flags / ssid
- 74:50:4e:34:fd:10 2412 -53 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:fd:11 2412 -53 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:35:03:f1 2437 -59 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:35:03:f0 2437 -60 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:d8:b1 2437 -63 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:34:fc:90 2437 -63 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:d8:b0 2437 -63 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:c4:71 2462 -67 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:34:c4:70 2462 -67 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:f8:30 2462 -75 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:f8:d0 2462 -75 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:f8:d1 2462 -76 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:34:f8:31 2462 -76 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:35:01:b0 2462 -79 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:35:01:b1 2462 -79 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:35:03:11 2412 -82 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]
- 74:50:4e:35:03:10 2412 -82 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 74:50:4e:34:fc:f0 2412 -86 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] wanshuo
- 1970-01-01 00:00:14:015: WMG_DEBUG [src/os/linux/scan.c:parse_scan_results:43]: scan arr size buff len: 60
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:47]: scan results length is 1431
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:fd:10
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2412
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-53
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:95]: key_mgmt=2
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:fd:11
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid= len=0
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:35:03:f1
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2437
- 1970-01-01 00:00:14:015: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-59
- 1970-01-01 00:00:14:016: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:35:03:f0
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2437
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-60
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:95]: key_mgmt=2
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:d8:b1
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-63
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid= len=0
- 1970-01-01 00:00:14:346: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:fc:90
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2437
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-63
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:95]: key_mgmt=2
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:d8:b0
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:c4:71
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2462
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-67
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid= len=0
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:c4:70
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:f8:30
- 1970-01-01 00:00:14:347: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-75
- 1970-01-01 00:00:14:348: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:348: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:f8:d0
- 1970-01-01 00:00:14:348: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2462
- 1970-01-01 00:00:14:348: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-75
- 1970-01-01 00:00:14:348: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:95]: key_mgmt=2
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:f8:d1
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2462
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-76
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:95]: key_mgmt=2
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid= len=0
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:f8:31
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:35:01:b0
- 1970-01-01 00:00:14:679: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-79
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:35:01:b1
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2462
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-79
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:95]: key_mgmt=2
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:127]: ssid= len=0
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:35:03:11
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:72]: freq=2412
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-82
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:35:03:10
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:62]: bssid=74:50:4e:34:fc:f0
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:83]: rssi=-86
- 1970-01-01 00:00:14:680: WMG_EXCESSIVE [src/os/linux/scan.c:parse_scan_results:114]: ssid=wanshuo len=7
- 1970-01-01 00:00:14:680: WMG_DEBUG [src/wifimg.c:__wifi_get_scan_results:467]: get scan results success
- [1;32m1970-01-01 00:00:14:681: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[00]: bssid=74:50:4e:34:fd:10 ssid=wanshuo channel=1(freq=2412) rssi=-53 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[01]: bssid=74:50:4e:34:fd:11 ssid= channel=1(freq=2412) rssi=-53 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[02]: bssid=74:50:4e:35:03:f1 ssid= channel=6(freq=2437) rssi=-59 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[03]: bssid=74:50:4e:35:03:f0 ssid=wanshuo channel=6(freq=2437) rssi=-60 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[04]: bssid=74:50:4e:34:d8:b1 ssid= channel=6(freq=2437) rssi=-63 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[05]: bssid=74:50:4e:34:fc:90 ssid=wanshuo channel=6(freq=2437) rssi=-63 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[06]: bssid=74:50:4e:34:d8:b0 ssid=wanshuo channel=6(freq=2437) rssi=-63 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[07]: bssid=74:50:4e:34:c4:71 ssid= channel=11(freq=2462) rssi=-67 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[08]: bssid=74:50:4e:34:c4:70 ssid=wanshuo channel=11(freq=2462) rssi=-67 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[09]: bssid=74:50:4e:34:f8:30 ssid=wanshuo channel=11(freq=2462) rssi=-75 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[10]: bssid=74:50:4e:34:f8:d0 ssid=wanshuo channel=11(freq=2462) rssi=-75 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[11]: bssid=74:50:4e:34:f8:d1 ssid= channel=11(freq=2462) rssi=-76 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[12]: bssid=74:50:4e:34:f8:31 ssid= channel=11(freq=2462) rssi=-76 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[13]: bssid=74:50:4e:35:01:b0 ssid=wanshuo channel=11(freq=2462) rssi=-79 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[14]: bssid=74:50:4e:35:01:b1 ssid= channel=11(freq=2462) rssi=-79 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[15]: bssid=74:50:4e:35:03:11 ssid= channel=1(freq=2412) rssi=-82 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:012: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[16]: bssid=74:50:4e:35:03:10 ssid=wanshuo channel=1(freq=2412) rssi=-82 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:013: WMG_INFO [wifi_deamon.c:cmd_handle_s:220]: bss[17]: bssid=74:50:4e:34:fc:f0 ssid=wanshuo channel=1(freq=2412) rssi=-86 sec=WPA_PSK
- [0m[1;32m1970-01-01 00:00:15:013: WMG_INFO [wifi_deamon.c:cmd_handle_s:222]: ===Wi-Fi scan successful, total 18 ap(buff size: 60) time 3840.000000 ms===
- ------ Setting amixer -----
- amixer: Cannot find the given element from control hw:audiocodec
- numid=12,iface=MIXER,name='MIC1 gain volume'
- ; type=INTEGER,access=rw---R--,values=1,min=0,max=31,step=0
- : values=0
- | dBscale-min=0.00dB,step=1.00dB,mute=0
- numid=13,iface=MIXER,name='MIC2 gain volume'
- : values=0
- amixer: Control hw:sndac10710036 open error: No such device
- ------ Start OV Sample -----
- WARNING: Logging before InitGoogleLogging() is written to STDERR
- I0101 00:00:15.370439 1138 dup2SeldomUsedFd.c:20] [60D[60C gFdLock init
- I0101 00:00:15.393575 1138 sample_virvi2vo.c:1017] [60D[60C sample_virvi2vo running!
- I0101 00:00:15.394020 1138 sample_virvi2vo.c:108] [60D[60C sample_virvi2vo path:[sample_virvi2vo], arg number is [1]
- I0101 00:00:15.394148 [ 12.668330] VE: before freq=300000000
- 1138 sample_virvi2vo.c:208] [6[ 12.673255] VE: real freq=300000000
- 0D[60C user not set config file. use default test parameter!
- I0101 00:00:15.394306 1138 mpi_sys.c:840] [60D[60C kfctmpdir is [/tmp]
- >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
- modName : MPP-Platform
- tag : V1.0 Release
- branch: v5-dev
- commit: 4eed413532ad87725895a8cb1ba75e22fc328233
- date : 20170725
- author: jenkins
- I0101 00:00:15.416862 1138 mpi_sys.c:1280] [60D[60C ISP init
- [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
- IPCORE: ISP600
- branch: libisp-dev
- commit: c154641862e08383b2fe850864fd334ead24d538
- date : Tue May 31 15:09:49 2022 +0800
- author:
- I0101 00:00:15.417308 1138 mpi_sys.c:1282] [60D[60C ISP init done
- INFO : cedarc : *** ic_version = 0x1302000023010,
- I0101 00:00:15.440459 1138 hwdisplay.c:84] [60D[60C
- I0101 00:00:15.440700 1138 hwdisplay.c:993] [60D[60C (hwd_init 993)
- I0101 00:00:15.440894 1138 hwdisplay.c:1048] [60D[60C ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
- I0101 00:00:15.441103 1138 alsa_interface.c:679] [60D[60C open mixer:hw:0
- I0101 00:00:15.460830 1138 alsa_interface.c:714] [60D[60C alsa_elem:ADC1 ADC2 swap
- I0101 00:00:15.461044 1138 alsa_interface.c:714] [60D[60C alsa_elem:ADC1 volume
- I0101 00:00:15.461164 1138 alsa_interface.c:714] [60D[60C alsa_elem:ADC2 volume
- I0101 00:00:15.461259 1138 alsa_interface.c:714] [60D[60C alsa_elem:ADCDRC
- I0101 00:00:15.461354 1138 alsa_interface.c:714] [60D[60C alsa_elem:ADCHPF
- I0101 00:00:15.461437 1138 alsa_interface.c:714] [60D[60C alsa_elem:DAC volume
- I0101 00:00:15.461517 1138 alsa_interface.c:714] [60D[60C alsa_elem:DACDRC
- I0101 00:00:15.461594 1138 alsa_interface.c:714] [60D[60C alsa_elem:DACHPF
- I0101 00:00:15.461672 1138 alsa_interface.c:714] [60D[60C alsa_elem:LINEIN
- I0101 00:00:15.461748 1138 alsa_interface.c:714] [60D[60C alsa_elem:LINEINL gain volume
- I0101 00:00:15.461826 1138 alsa_interface.c:714] [60D[60C alsa_elem:LINEINR gain volume
- I0101 00:00:15.461905 1138 alsa_interface.c:714] [60D[60C alsa_elem:LINEOUT
- I0101 00:00:15.461983 1138 alsa_interface.c:714] [60D[60C alsa_elem:LINEOUT Output Select
- I0101 00:00:15.462336 1138 alsa_interface.c:714] [60D[60C alsa_elem:LINEOUT volume
- I0101 00:00:15.462525 1138 alsa_interface.c:734] [60D[60C set playback vol_val to value: 27
- I0101 00:00:15.462660 1138 alsa_interface.c:714] [60D[60C alsa_elem:MIC1
- I0101 00:00:15.462885 1138 alsa_interface.c:714] [60D[60C alsa_elem:MIC1 Input Select
- I0101 00:00:15.463009 1138 alsa_interface.c:714] [60D[60C alsa_elem:MIC1 gain volume
- I0101 00:00:15.463104 1138 alsa_interface.c:714] [60D[60C alsa_elem:MIC2
- I0101 00:00:15.463186 1138 alsa_interface.c:714] [60D[60C alsa_elem:MIC2 Input Select
- I0101 00:00:15.463267 1138 alsa_interface.c:714] [60D[60C alsa_elem:MIC2 gain volume
- I0101 00:00:15.463344 1138 alsa_interface.c:714] [60D[60C alsa_elem:SPK
- I0101 0[ 12.986430] [VIN]ve_online close
- 0:00:15.463422 1138 alsa_interface.c:714] [60D[60C alsa_elem:digital volume
- I0101 00:00:15.463499 1138 alsa_interface.c:714] [60D[60C alsa_elem:rx sync mode
- I0101 00:00:15.463580 1138 alsa_interface.c:714] [60D[60C alsa_elem:tx hub mode
- I0101 00:00:15.463747 1138 hwdisplay.c:1248] [60D[60C Current the disp_type:0x1 tv_mode:0x0
- I0101 00:00:15.484080 1138 sample_virvi2vo.c:394] [60D[60C Vipp dev[0] vir_chn[0]
- [ISP]video device name is vin_video0
- [ISP]open video device[0], detect isp0 success!
- I0101 00:00:15.484717 1138 videoInputHw.c:942] [60D[60C ViCh[0] update width:1920(1920), height:1080(1088)
- [ISP]video0 fd[10] ve_online_en=0, dma_buf_num=0
- [ISP]open isp device[0] success!
- [ISP_WARN]open /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin failed, err:No such file or directory.
- [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0, 0
- [ISP]find gc2053_mipi_1920_1088_20_0 [gc2053_mipi_isp600_20220511_164617_vlc4_day] isp config
- [ISP]create isp0 server thread!
- I0101 00:00:15.766721 1138 mpi_vi.c:1018] [60D[60C we allow to create virChn[0] in disable status of vipp[0]
- I0101 00:00:15.767121 1138 VideoVirVi_Component.c:1141] [60D[60C VideoVirvi component Init! thread_id[0xb6b59d50]
- I0101 00:00:15.816542 1145 videoInputHw.c:4785] [60D[60C loop VideoInputHw_CapThread vipp_id = 0, buf_num=5.
- I0101 00:00:16.015485 1138 hwdisplay.c:1121] [60D[60C hlay:0, zorder=0, cnt:2
- I0101 00:00:16.015771 1138 mpi_vo.c:1038] [60D[60C ch[0]lyl[0]:dispRect changed, [0, 0, 320x240]->[0, 0, 1280x720]
- I0101 00:00:16.015930 1138 hwdisplay.c:409] [60D[60C ch[0]lyl[0]: screen_win[0,0, 1280x720]
- I0101 00:00:16.016358 1138 sample_virvi2vo.c:511] [60D[60C create vo channel[0] success!
- I0101 00:00:16.032641 1138 sample_virvi2vo.c:388] [60D[60C do not need create link for idx[1]
- [ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
- [ISP_WARN]gc2053_mipi get sensor_temp failed: Invalid argument (22).
- I0101 00:00:16.231557 1146 vide[ 13.483595] [DISP] de_fcm_set_para,line:491:o_render_linux.cpp:224] [60D[6
- 0C mDisplayFormat[0x1[ 13.490102] fcm lut 0 not find, auto retry after init
- 1], new CedarXNativeRenderer
- I0101 00:00:16.231822 1146 CedarXNativeRenderer.cpp:176] [60D[60C hwc disp fmt[0x63], color space:260
- I0101 00:00:16.231972 1146 hwdisplay.c:240] [60D[60C x: 0, y: 0, width: 0x780, height: 0x440
- I0101 00:00:16.232086 1146 hwdisplay.c:247] [60D[60C width: 0x78000000000, height: 0x44000000000
- I0101 00:00:16.232193 1146 hwdisplay.c:367] [60D[60C set fb.format 99 77, color_space 260 end, size0[1920x1088], size1[960x544]
- I0101 00:00:16.232333 1146 sample_virvi2vo.c:63] [60D[60C VO callback: VO Layer[0] chn[0] event:257
- I0101 00:00:16.232454 1146 sample_virvi2vo.c:75] [60D[60C vo layer[0] report video display size[1920x1088]
- I0101 00:00:16.232564 1146 VideoRender_Component.c:2318] [60D[60C init video_render, param: displayRect[0,0][1920x1088], bufSize[1920x1088], vdecColorFormat[0x5]
- I0101 00:00:16.232665 1146 mpi_vo.c:508] [60D[60C KeyFrameDecoded, pts[13476079]us
- I0101 00:00:16.250737 1146 sample_virvi2vo.c:63] [60D[60C VO callback: VO Layer[0] chn[0] event:258
- I0101 00:00:16.250951 1146 sample_virvi2vo.c:80] [60D[60C vo layer[0] report rendering start
- [ISP]video device name is vin_video12
- [ISP]open video device[12], detect isp0 success!
- [ISP]--------- LDCI Video12 Init OK ---------
- [ISP]--------- LDCI Video12 Streamon OK ---------
- [ 16.353548] random: crng init done
- [ 16.357369] random: 2 urandom warning(s) missed due to ratelimiting
- [0m1970-01-01 00:03:21:006: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 0 74:50:4e:34:fd:10
- 1970-01-01 00:03:21:006: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 0 74:50:4e:34:fd:10
- 1970-01-01 00:03:21:006: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-REMOVED
- 1970-01-01 00:03:21:006: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 1 74:50:4e:34:fd:11
- 1970-01-01 00:03:21:006: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 1 74:50:4e:34:fd:11
- 1970-01-01 00:03:21:006: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 2 74:50:4e:35:03:f1
- 1970-01-01 00:03:21:006: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 2 74:50:4e:35:03:f1
- 1970-01-01 00:03:21:006: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 3 74:50:4e:35:03:f0
- 1970-01-01 00:03:21:006: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 3 74:50:4e:35:03:f0
- 1970-01-01 00:03:21:006: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 4 74:50:4e:34:d8:b1
- 1970-01-01 00:03:21:006: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 4 74:50:4e:34:d8:b1
- 1970-01-01 00:03:21:006: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 5 74:50:4e:34:fc:90
- 1970-01-01 00:03:21:007: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 5 74:50:4e:34:fc:90
- 1970-01-01 00:03:21:007: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-REMOVED
- 1970-01-01 00:03:21:007: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 6 74:50:4e:34:d8:b0
- 1970-01-01 00:03:21:007: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 6 74:50:4e:34:d8:b0
- 1970-01-01 00:03:21:007: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 7 74:50:4e:34:c4:71
- 1970-01-01 00:03:21:007: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 7 74:50:4e:34:c4:71
- 1970-01-01 00:03:21:007: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 8 74:50:4e:34:c4:70
- 1970-01-01 00:03:21:007: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 8 74:50:4e:34:c4:70
- 1970-01-01 00:03:21:007: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 9 74:50:4e:34:f8:30
- 1970-01-01 00:03:21:007: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 9 74:50:4e:34:f8:30
- 1970-01-01 00:03:21:338: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 10 74:50:4e:34:f8:d0
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 10 74:50:4e:34:f8:d0
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-REMOVED
- 1970-01-01 00:03:21:339: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 11 74:50:4e:34:f8:d1
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 11 74:50:4e:34:f8:d1
- 1970-01-01 00:03:21:339: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 12 74:50:4e:34:f8:31
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 12 74:50:4e:34:f8:31
- 1970-01-01 00:03:21:339: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 13 74:50:4e:35:01:b0
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 13 74:50:4e:35:01:b0
- 1970-01-01 00:03:21:339: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 14 74:50:4e:35:01:b1
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 14 74:50:4e:35:01:b1
- 1970-01-01 00:03:21:339: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 15 74:50:4e:35:03:11
- 1970-01-01 00:03:21:339: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 15 74:50:4e:35:03:11
- 1970-01-01 00:03:21:340: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 16 74:50:4e:35:03:10
- 1970-01-01 00:03:21:340: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 16 74:50:4e:35:03:10
- 1970-01-01 00:03:21:340: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-REMOVED
- 1970-01-01 00:03:21:340: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-REMOVED 17 74:50:4e:34:fc:f0
- 1970-01-01 00:03:21:340: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-REMOVED 17 74:50:4e:34:fc:f0
