我使用模板工程,创建工程之后,添加ETH组件,选择使用industry-io,配置好网口需要的驱动,编译,然后finsh控制台报错:
[W/drv.emac] eth transmit frame faild: 4
[I/sal.skt] Socket Abstraction Layer initialize success.
[W/drv.emac] eth transmit frame faild: 20
msh />[W/drv.emac] eth transmit frame faild: 20
[I/drv.emac] link down
我加入udpserver例程,也无法正常运行。是我的配置有问题吗?,下面是生成的rtconfig.h配置:
#ifndef RT_CONFIG_H__
#define RT_CONFIG_H__
/* Generated by Kconfiglib (https://github.com/ulfalizer/Kconfiglib) */
/* RT-Thread Kernel */
#define RT_NAME_MAX 8
#define RT_ALIGN_SIZE 4
#define RT_THREAD_PRIORITY_32
#define RT_THREAD_PRIORITY_MAX 32
#define RT_TICK_PER_SECOND 1000
#define RT_USING_OVERFLOW_CHECK
#define RT_USING_HOOK
#define RT_HOOK_USING_FUNC_PTR
#define RT_USING_IDLE_HOOK
#define RT_IDLE_HOOK_LIST_SIZE 4
#define IDLE_THREAD_STACK_SIZE 512
#define RT_USING_TIMER_SOFT
#define RT_TIMER_THREAD_PRIO 4
#define RT_TIMER_THREAD_STACK_SIZE 512
/* kservice optimization */
#define RT_KSERVICE_USING_STDLIB
/* end of kservice optimization */
#define RT_DEBUG
#define RT_DEBUG_COLOR
/* Inter-Thread communication */
#define RT_USING_SEMAPHORE
#define RT_USING_MUTEX
#define RT_USING_EVENT
#define RT_USING_MAILBOX
#define RT_USING_MESSAGEQUEUE
/* end of Inter-Thread communication */
/* Memory Management */
#define RT_USING_MEMHEAP
#define RT_MEMHEAP_FAST_MODE
#define RT_USING_MEMHEAP_AS_HEAP
#define RT_USING_MEMHEAP_AUTO_BINDING
#define RT_USING_HEAP
/* end of Memory Management */
/* Kernel Device Object */
#define RT_USING_DEVICE
#define RT_USING_CONSOLE
#define RT_CONSOLEBUF_SIZE 1024
#define RT_CONSOLE_DEVICE_NAME "uart4"
/* end of Kernel Device Object */
#define RT_VER_NUM 0x40100
/* end of RT-Thread Kernel */
#define ARCH_ARM
#define RT_USING_CPU_FFS
#define ARCH_ARM_CORTEX_M
#define ARCH_ARM_CORTEX_M7
/* RT-Thread Components */
#define RT_USING_COMPONENTS_INIT
#define RT_USING_USER_MAIN
#define RT_MAIN_THREAD_STACK_SIZE 4096
#define RT_MAIN_THREAD_PRIORITY 10
#define RT_USING_LEGACY
#define RT_USING_MSH
#define RT_USING_FINSH
#define FINSH_USING_MSH
#define FINSH_THREAD_NAME "tshell"
#define FINSH_THREAD_PRIORITY 20
#define FINSH_THREAD_STACK_SIZE 4096
#define FINSH_USING_HISTORY
#define FINSH_HISTORY_LINES 5
#define FINSH_USING_SYMTAB
#define FINSH_CMD_SIZE 80
#define MSH_USING_BUILT_IN_COMMANDS
#define FINSH_USING_DESCRIPTION
#define FINSH_ARG_MAX 10
#define RT_USING_DFS
#define DFS_USING_POSIX
#define DFS_USING_WORKDIR
#define DFS_FILESYSTEMS_MAX 5
#define DFS_FILESYSTEM_TYPES_MAX 4
#define DFS_FD_MAX 50
#define RT_USING_DFS_ELMFAT
/* elm-chan's FatFs, Generic FAT Filesystem Module */
#define RT_DFS_ELM_CODE_PAGE 437
#define RT_DFS_ELM_WORD_ACCESS
#define RT_DFS_ELM_USE_LFN_3
#define RT_DFS_ELM_USE_LFN 3
#define RT_DFS_ELM_LFN_UNICODE_0
#define RT_DFS_ELM_LFN_UNICODE 0
#define RT_DFS_ELM_MAX_LFN 255
#define RT_DFS_ELM_DRIVES 2
#define RT_DFS_ELM_MAX_SECTOR_SIZE 512
#define RT_DFS_ELM_REENTRANT
#define RT_DFS_ELM_MUTEX_TIMEOUT 3000
/* end of elm-chan's FatFs, Generic FAT Filesystem Module */
#define RT_USING_DFS_DEVFS
#define RT_USING_DFS_ROMFS
#define RT_USING_FAL
#define FAL_DEBUG_CONFIG
#define FAL_DEBUG 1
#define FAL_PART_HAS_TABLE_CFG
#define FAL_USING_SFUD_PORT
#define FAL_USING_NOR_FLASH_DEV_NAME "norflash0"
/* Device Drivers */
#define RT_USING_DEVICE_IPC
#define RT_USING_SYSTEM_WORKQUEUE
#define RT_SYSTEM_WORKQUEUE_STACKSIZE 2048
#define RT_SYSTEM_WORKQUEUE_PRIORITY 23
#define RT_USING_SERIAL
#define RT_USING_SERIAL_V1
#define RT_SERIAL_USING_DMA
#define RT_SERIAL_RB_BUFSZ 64
#define RT_USING_PIN
#define RT_USING_MTD_NOR
#define RT_USING_RTC
#define RT_USING_SOFT_RTC
#define RT_USING_SDIO
#define RT_SDIO_STACK_SIZE 512
#define RT_SDIO_THREAD_PRIORITY 15
#define RT_MMCSD_STACK_SIZE 1024
#define RT_MMCSD_THREAD_PREORITY 22
#define RT_MMCSD_MAX_PARTITION 16
#define RT_USING_SPI
#define RT_USING_SFUD
#define RT_SFUD_USING_SFDP
#define RT_SFUD_USING_FLASH_INFO_TABLE
#define RT_SFUD_SPI_MAX_HZ 50000000
/* Using USB */
/* end of Using USB */
/* end of Device Drivers */
/* C/C++ and POSIX layer */
#define RT_LIBC_DEFAULT_TIMEZONE 8
/* POSIX (Portable Operating System Interface) layer */
#define RT_USING_POSIX_FS
#define RT_USING_POSIX_DEVIO
#define RT_USING_POSIX_STDIO
#define RT_USING_POSIX_POLL
#define RT_USING_POSIX_SELECT
#define RT_USING_POSIX_SOCKET
#define RT_USING_POSIX_TERMIOS
#define RT_USING_MODULE
/* Interprocess Communication (IPC) */
/* Socket is in the 'Network' category */
/* end of Interprocess Communication (IPC) */
/* end of POSIX (Portable Operating System Interface) layer */
/* end of C/C++ and POSIX layer */
/* Network */
#define RT_USING_SAL
#define SAL_INTERNET_CHECK
/* protocol stack implement */
#define SAL_USING_LWIP
/* end of protocol stack implement */
#define SAL_USING_POSIX
#define RT_USING_NETDEV
#define NETDEV_USING_IFCONFIG
#define NETDEV_USING_PING
#define NETDEV_USING_NETSTAT
#define NETDEV_USING_AUTO_DEFAULT
#define NETDEV_IPV4 1
#define NETDEV_IPV6 0
#define RT_USING_LWIP
#define RT_USING_LWIP203
#define RT_USING_LWIP_VER_NUM 0x20003
#define RT_LWIP_MEM_ALIGNMENT 4
#define RT_LWIP_IGMP
#define RT_LWIP_ICMP
#define RT_LWIP_DNS
#define RT_LWIP_DHCP
#define IP_SOF_BROADCAST 1
#define IP_SOF_BROADCAST_RECV 1
/* Static IPv4 Address */
#define RT_LWIP_IPADDR "192.168.1.30"
#define RT_LWIP_GWADDR "192.168.1.1"
#define RT_LWIP_MSKADDR "255.255.255.0"
/* end of Static IPv4 Address */
#define RT_LWIP_UDP
#define RT_LWIP_TCP
#define RT_LWIP_RAW
#define RT_MEMP_NUM_NETCONN 34
#define RT_LWIP_PBUF_NUM 38
#define RT_LWIP_RAW_PCB_NUM 4
#define RT_LWIP_UDP_PCB_NUM 4
#define RT_LWIP_TCP_PCB_NUM 30
#define RT_LWIP_TCP_SEG_NUM 40
#define RT_LWIP_TCP_SND_BUF 8196
#define RT_LWIP_TCP_WND 8196
#define RT_LWIP_TCPTHREAD_PRIORITY 10
#define RT_LWIP_TCPTHREAD_MBOX_SIZE 8
#define RT_LWIP_TCPTHREAD_STACKSIZE 4096
#define RT_LWIP_ETHTHREAD_PRIORITY 12
#define RT_LWIP_ETHTHREAD_STACKSIZE 1024
#define RT_LWIP_ETHTHREAD_MBOX_SIZE 8
#define LWIP_NETIF_STATUS_CALLBACK 1
#define LWIP_NETIF_LINK_CALLBACK 1
#define SO_REUSE 1
#define LWIP_SO_RCVTIMEO 1
#define LWIP_SO_SNDTIMEO 1
#define LWIP_SO_RCVBUF 1
#define LWIP_SO_LINGER 0
#define LWIP_NETIF_LOOPBACK 0
#define RT_LWIP_USING_PING
/* end of Network */
/* Utilities */
/* end of Utilities */
/* end of RT-Thread Components */
/* RT-Thread online packages */
/* IoT - internet of things */
/* Wi-Fi */
/* Marvell WiFi */
/* end of Marvell WiFi */
/* Wiced WiFi */
/* end of Wiced WiFi */
/* end of Wi-Fi */
/* IoT Cloud */
/* end of IoT Cloud */
/* end of IoT - internet of things */
/* security packages */
/* end of security packages */
/* language packages */
/* JSON: JavaScript Object Notation, a lightweight data-interchange format */
/* end of JSON: JavaScript Object Notation, a lightweight data-interchange format */
/* XML: Extensible Markup Language */
/* end of XML: Extensible Markup Language */
/* end of language packages */
/* multimedia packages */
/* LVGL: powerful and easy-to-use embedded GUI library */
/* end of LVGL: powerful and easy-to-use embedded GUI library */
/* u8g2: a monochrome graphic library */
/* end of u8g2: a monochrome graphic library */
/* PainterEngine: A cross-platform graphics application framework written in C language */
/* end of PainterEngine: A cross-platform graphics application framework written in C language */
/* end of multimedia packages */
/* tools packages */
/* end of tools packages */
/* system packages */
/* enhanced kernel services */
/* end of enhanced kernel services */
/* acceleration: Assembly language or algorithmic acceleration packages */
/* end of acceleration: Assembly language or algorithmic acceleration packages */
/* CMSIS: ARM Cortex-M Microcontroller Software Interface Standard */
/* end of CMSIS: ARM Cortex-M Microcontroller Software Interface Standard */
/* Micrium: Micrium software products porting for RT-Thread */
/* end of Micrium: Micrium software products porting for RT-Thread */
/* end of system packages */
/* peripheral libraries and drivers */
/* Kendryte SDK */
/* end of Kendryte SDK */
/* end of peripheral libraries and drivers */
/* AI packages */
/* end of AI packages */
/* miscellaneous packages */
/* project laboratory */
/* end of project laboratory */
/* samples: kernel and components samples */
/* end of samples: kernel and components samples */
/* entertainment: terminal games and other interesting software packages */
/* end of entertainment: terminal games and other interesting software packages */
/* end of miscellaneous packages */
/* end of RT-Thread online packages */
/* Hardware Drivers Config */
#define SOC_STM32H750XB
#define SOC_SERIES_STM32H7
/* Board extended module */
#define ART_PI_USING_INDUSTRY_IO
#define INDUSTRY_IO_USING_ETH
/* end of Board extended module */
/* Onboard Peripheral */
#define BSP_USING_USB_TO_USART
/* end of Onboard Peripheral */
/* On-chip Peripheral */
#define BSP_USING_GPIO
#define BSP_USING_UART
#define BSP_USING_UART4
#define BSP_USING_UART6
#define BSP_USING_SPI
#define BSP_USING_SPI1
#define BSP_USING_SDIO
#define BSP_USING_SDIO1
#define BSP_USING_ETH
#define ETH_RESET_PIN "PA.3"
#define PHY_USING_LAN8720A
/* end of On-chip Peripheral */
/* end of Hardware Drivers Config */
/* External Libraries */
/* end of External Libraries */
#define FIRMWARE_EXEC_USING_QSPI_FLASH
#define RT_STUDIO_BUILT_IN
#endif
举报
举报
更多回帖
