2022-8-22 14:09:04
强烈不建议这么做,运行 RT-Thread 操作系统最好单独留一个串口作为控制台的串口,在控制台中可以方便的看出来线程、定时器、信号量、互斥锁、内存等关键信息的运行情况,更方便监控整个系统的运行。
控制台线程的执行代码在文件 rt-threadcomponentsfinshshell.c 里面,如下所示。从中可以看出改线程在一直获取控制台串口的输入数据,也就是说该串口一收到数据就会被该线程读出来(该线程的优先级是 20),收到 “rn” 之后开始解析命令并执行对应的操作。如果将控制台串口和其他通讯功能合为一个,想实现除了解析命令还解析其他协议的话,那么就需要修改该函数的实现,如果修改不好会影响到控制台命令的解析,建议硬件设计时单独留出来一个串口作为控制台串口使用。
void finsh_thread_entry(void *parameter)
int ch;
/* normal is echo mode */
#ifndef FINSH_ECHO_DISABLE_DEFAULT
shell->echo_mode = 1;
#else
shell->echo_mode = 0;
#endif
#if !defined(RT_USING_POSIX) && defined(RT_USING_DEVICE)
/* set console device as shell device */
if (shell->device == RT_NULL)
rt_device_t console = rt_console_get_device();
if (console)
finsh_set_device(console->parent.name);
#endif
#ifdef FINSH_USING_AUTH
/* set the default password when the password isn't setting */
if (rt_strlen(finsh_get_password()) == 0)
if (finsh_set_password(FINSH_DEFAULT_PASSWORD) != RT_EOK)
rt_kprintf("Finsh password set failed.n");
/* waiting authenticate success */
finsh_wait_auth();
#endif
rt_kprintf(FINSH_PROMPT);
while (1)
ch = (int)finsh_getchar();
if (ch < 0)
continue;
* handle control key
* up key : 0x1b 0x5b 0x41
* down key: 0x1b 0x5b 0x42
* right key:0x1b 0x5b 0x43
* left key: 0x1b 0x5b 0x44
if (ch == 0x1b)
shell->stat = WAIT_SPEC_KEY;
continue;
else if (shell->stat == WAIT_SPEC_KEY)
if (ch == 0x5b)
shell->stat = WAIT_FUNC_KEY;
continue;
shell->stat = WAIT_NORMAL;
else if (shell->stat == WAIT_FUNC_KEY)
if (ch == 0x41) /* up key */
#ifdef FINSH_USING_HISTORY
/* prev history */
if (shell->current_history > 0)
shell->current_history --;
else
shell->current_history = 0;
continue;
/* copy the history command */
memcpy(shell->line, &shell->cmd_history[shell->current_history][0],
FINSH_CMD_SIZE);
shell->line_curpos = shell->line_position = strlen(shell->line);
shell_handle_history(shell);
#endif
continue;
else if (ch == 0x42) /* down key */
/* next history */
if (shell->current_history < shell->history_count - 1)
shell->current_history ++;
else
/* set to the end of history */
if (shell->history_count != 0)
shell->current_history = shell->history_count - 1;
else
continue;
FINSH_CMD_SIZE);
#endif
continue;
else if (ch == 0x44) /* left key */
if (shell->line_curpos)
rt_kprintf("b");
shell->line_curpos --;
continue;
else if (ch == 0x43) /* right key */
if (shell->line_curpos < shell->line_position)
rt_kprintf("%c", shell->line[shell->line_curpos]);
shell->line_curpos ++;
continue;
/* received null or error */
if (ch == '
