瑞芯微Rockchip开发者社区
直播中
孙成红
8年用户 1451经验值
私信 关注
[问答]
RK3399配置eDP后系统启动过程中崩溃请问应该如何排查
问题描述及复现步骤:
使用的core-rk3399-jd4核心板 + AIO载板,因为要使用eDP显示屏,修改了rk3399-firefly-aiojd4.dtsi。
但是修改后,系统在启动过程中会崩溃,请问应该如何排查????
使用硬件如图所示
rk3399-firefly-aiojd4.dtsi文件内容如下:
/dts-v1/;
#include "rk3399-firefly-port.dtsi"
#include <dt-bindings/sensor-dev.h>
#include <dt-bindings/display/media-bus-format.h>
test-power {
            status = "okay";
    rt5640-sound {
            simple-audio-card,cpu {
                    sound-dai = <&i2s1>;
            simple-audio-card,codec {
                    sound-dai = <&rt5640>;
    adc-keys {
            compatible = "adc-keys";
            io-channels = <&saradc 1>;
            io-channel-names = "buttons";
            poll-interval = <300>;
            keyup-threshold-microvolt = <1800000>;
            esc-key {
                    linux,code = <KEY_ESC>;
                    label = "esc";
                    press-threshold-microvolt = <0>;
    fan_ctl: fan-ctl-regulator {
            compatible = "regulator-fixed";
            enable-active-high;
            regulator-always-on;
            regulator-boot-on;
            gpio = <&gpio3 10 GPIO_ACTIVE_HIGH>;
            pinctrl-names = "default";
            regulator-name = "fan_ctl";
            pinctrl-0 = <&fan_drv>;
    NPU5801_PWR_EN: HUB20-PWR-EN {
            enable-active-high;
            regulator-boot-on;
            gpio = <&gpio0 2 GPIO_ACTIVE_HIGH>;
            pinctrl-0 = <&npu5801_pwr_en>;
            regulator-name = "vcc5v0_5801_en";
            status = "okay";
&gmac {
tx_delay = <0x2F>;
    rx_delay = <0x1E>;
&vcc_sd_h {
rockchip,pins = <1 22 RK_FUNC_GPIO &pcfg_pull_up>;
&vcc_sd {
gpio = <&gpio1 22 GPIO_ACTIVE_HIGH>;
&hdmi_dp_sound {
status = "okay";
&i2c2 {
status = "disabled";
    i2c-scl-rising-time-ns = <300>;
    i2c-scl-falling-time-ns = <15>;
    sensor@4c {
            compatible = "gs_mc3230";
            reg = <0x4c>;
            type = <SENSOR_TYPE_ACCEL>;
            irq_enable = <0>;
            poll_delay_ms = <30>;
            layout = <1>;
&rt5640 {
hp-det-adc-value = <900>;
aux-det-adc-value = <900>;
hp-con-gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>;
io-channels = <&saradc 3>,<&saradc 2>;
io-channel-names = "hp-det","aux-det";
&rt5640_hpcon{
rockchip,pins = <3 16 RK_FUNC_GPIO &pcfg_pull_none>;
&vcca1v8_codec {
regulator-min-microvolt = <900000>;
    regulator-max-microvolt = <900000>;
&spi1 {
dev-port = <0>;
    status = "okay";
&spi_wk2xxx {
status = "okay";
    reset-gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>;
    irq-gpio = <&gpio2 8 IRQ_TYPE_EDGE_FALLING>;
    cs-gpio = <&gpio1 10 GPIO_ACTIVE_HIGH>;
// &spi2 {
// status = "okay";
// max-freq = <48000000>;
// spidev@00 {
// compatible = "linux,spidev";
// reg = <0x00>;
// spi-max-frequency = <48000000>;
// status = "okay";
&vcc3v3_3g {
gpio = <&gpio2 28 GPIO_ACTIVE_HIGH>;
&vcc3v3_pcie {
/delete-property/ gpio;
&pcie0 {
ep-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>;
&uart4 {
&dp_in_vopb {
&hdmi_in_vopl {
&wdt {
status = "okay";//2022.7.25
&io_domains {
bt656-supply = <&vcc_3v0>;
&vcc2v8_dvp {
regulator-min-microvolt = <1800000>;
    regulator-max-microvolt = <1800000>;
&vcca1v8_codec {
&fusb0 {
&cdn_dp {
&tcphy0 {
/delete-property/ extcon;
status = "okay";
&u2phy0 {
status = "okay";
u2phy0_otg: otg-port {
    rockchip,vbus-always-on;
    vbus-5v-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>;
    status = "okay";
&usbdrd3_0 {
status = "okay";
&usbdrd_dwc3_0 {
dr_mode = "host";
&route_hdmi {
status = "okay";
    // status = "disabled";
// 20220802 edp
&hdmi_in_vopb {
&hdmi {
// status = "okay";
&edp_in_vopb {
status = "okay";
&edp_in_vopl {
&route_edp {
status = "okay";
    connect = <&edp_in_vopb>;
&backlight {
status = "okay";
&edp_panel {
status = "okay";
    compatible = "simple-panel";//20220812
    backlight = <&backlight>;//20220812
    // power-supply = <&vcc_lcd>;
    enable-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;
    // enable-delay-ms = <120>;
    // prepare-delay-ms = <120>;
    // disable-delay-ms = <120>;
    // unprepare-delay-ms = <120>;
    display-timings {
            native-mode = <&timing0>;
            timing0: timing0 {
                    clock-frequency = <157080000>;
                    hactive = <1920>;
                    vactive = <1200>;
                    hfront-porch = <120>;
                    hsync-len = <0>;
                    hback-porch = <120>;
                    vfront-porch = <4>;
                    vsync-len = <4>;
                    vback-porch = <4>;
                    hsync-active = <0>;
                    vsync-active = <0>;
                    de-active = <0>;
                    pixelclk-active = <0>;
&edp {
status = "okay";
// &uart0 {
// 20220802 edp
&rk808 {
/delete-property/ pmic,stby-gpio;
 /delete-property/ pmic,hold-gpio;
&vcc_mipi {
status = "okay";
&dvdd_1v2 {
status = "okay";
&ov13850 {
pwdn-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>;
    status = "okay";
&ov13850_1 {
pwdn-gpios = <&gpio2 0 GPIO_ACTIVE_HIGH>;
    status = "okay";
&rkisp1_0 {
status = "okay";
&mipi_dphy_rx0 {
status = "okay";
&isp0_mmu {
status = "okay";
&rkisp1_1 {
status = "okay";
&mipi_dphy_tx1rx1 {
status = "okay";
&isp1_mmu {
status = "okay";
&pinctrl {
    pinctrl-0 = <&host_hub_vcc>;
    npu_pwr_en {
            // control VCC5V0_HOST3
            npu5801_pwr_en: npu5801-pwr-en {
                    rockchip,pins =
                            <0 2 RK_FUNC_GPIO &pcfg_pull_up>;
    host-hub-vcc {
            host_hub_vcc: host-hub-vcc {
                    rockchip,pins =
                            <2 4 RK_FUNC_GPIO &pcfg_output_high>,
                            <4 29 RK_FUNC_GPIO &pcfg_output_high>;
    pcie {
            pcie_3g_drv: pcie-3g-drv {
                    rockchip,pins =
                            <2 6 RK_FUNC_GPIO &pcfg_pull_up>;
    vcc_sd {
            vcc_sd_h: vcc-sd-h {
                    rockchip,pins =
    fan-ctl {
            fan_drv: fan-drv {
                    rockchip,pins = <3 10 RK_FUNC_GPIO &pcfg_pull_none>;
回帖(2)
张亮
2022-8-18 16:30:37
panel dts配置有问题,SDK中应该有edp相关dts配置,可以参考配置
举报
孙成红
2022-8-18 16:30:53
谢谢回复。确实是panel的问题,panel部分注释掉,系统就可以正常启动。
但是参照SDK中的rk3399-firefly-edp.dts修改,还有同样的问题。
rk3399-firefly-edp.dts是这样的
* Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
* This file is dual-licensed: you can use it either under the terms
* of the GPL or the X11 license, at your option. Note that this dual
* licensing only applies to this file, and not this project as a
* whole.
*  a) This file is free software; you can redistribute it and/or
*     modify it under the terms of the GNU General Public License as
*     published by the Free Software Foundation; either version 2 of the
*     License, or (at your option) any later version.
*     This file is distributed in the hope that it will be useful,
*     but WITHOUT ANY WARRANTY; without even the implied warranty of
*     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*     GNU General Public License for more details.
* Or, alternatively,
*  b) Permission is hereby granted, free of charge, to any person
*     obtaining a copy of this software and associated documentation
*     files (the "Software"), to deal in the Software without
*     restriction, including without limitation the rights to use,
*     copy, modify, merge, publish, distribute, sublicense, and/or
*     sell copies of the Software, and to permit persons to whom the
*     Software is furnished to do so, subject to the following
*     conditions:
*     The above copyright notice and this permission notice shall be
*     included in all copies or substantial portions of the Software.
*     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
*     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
*     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
*     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
*     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
*     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
*     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
*     OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
        model = "Firefly-RK3399 Board EDP LP079QX1 (Linux Opensource)";
        compatible = "rockchip,rk3399-firefly", "rockchip,rk3399";
        test-power {
                status = "okay";
        vcc_lcd: vcc-lcd {
                enable-active-high;
                gpio = <&gpio1 1 GPIO_ACTIVE_HIGH>;
                regulator-boot-on;
                regulator-name = "vcc_lcd";
                regulator-min-microvolt = <3300000>;
                regulator-max-microvolt = <3300000>;
                startup-delay-us = <20000>;
                vin-supply = <&vcc_3v0>;
&backlight {
    status = "okay";
&edp_panel {
        compatible = "sharp,lcd-f402", "panel-simple";
        reset-gpios = <&gpio4 29 GPIO_ACTIVE_LOW>;
        status = "okay";
&edp {
        status = "okay";
&route_edp {
        status = "okay";
        logo,mode = "center";
&edp_in_vopl {
&hdmi_dp_sound {
        status = "okay";
&i2c4 {
        status = "okay";
        gsl3680: gsl3680@41 {
                compatible = "gslX680";
                reg = <0x41>;
                screen_max_x = <1536>;
                screen_max_y = <2048>;
                touch-gpio = <&gpio1 20 IRQ_TYPE_LEVEL_LOW>;
                reset-gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>;
        mpu6050: mpu@68 {
                compatible = "invensense,mpu6050";
                reg = <0x68>;
                irq-gpio = <&gpio1 4 IRQ_TYPE_LEVEL_LOW>;
                mpu-debug = <1>;
                mpu-int_config = <0x10>;
                mpu-level_shifter = <0>;
                mpu-orientation = <0 1 0 1 0 0 0 0 1>;
                orientation-x= <1>;
                orientation-y= <1>;
                orientation-z= <1>;
&uart4 {
        status = "okay";
&dp_in_vopb {
&hdmi_in_vopb {
&wdt {
举报
更多回帖
