SEGGER Embedded Studio for RISC-V 对先楫
半导体免费许可,可以光明正大的用了。初学者建议用generate_project命令,主要是大部分配置内部的cmake工具等配置好了,这样对初次接触芯片的用户比较方便。
点击start_cmd.cmd启动:
help查看命令:
通过键入命令CD,将工作目录指向到样例目录。通过键入命令generate_project -b hpm6750evkmini,生成项目文件。
进入 SEGGER Embedded Studio
SEGGER再带打印:
跑分界面:
独立串口助手打印
- hpm6750evkmini clock summary
- cpu0: 816000000Hz
- cpu1: 816000000Hz
- axi0: 200000000Hz
- axi1: 200000000Hz
- axi2: 200000000Hz
- ahb: 200000000Hz
- mchtmr0: 24000000Hz
- mchtmr1: 1000000Hz
- xpi0: 133333333Hz
- xpi1: 400000000Hz
- dram: 166666666Hz
- display: 74250000Hz
- cam0: 59400000Hz
- cam1: 59400000Hz
- jpeg: 200000000Hz
- pdma: 200000000Hz
- $ | $ |$ __$ $$ $$ |__|
- $$$$ |$$$$ |$$$ $ |$ |$ _____|$ __$ $ __$
- $ __$ |$ ____/ $ $$ $ |$ |$ / $ | __|$ / $ |
- $ | $ |$ | $ | _/ $ |$ |$$$$ $ | $$$ |
- __| __|__| __| __|__| _______|__| ______/
- 2K performance run parameters for coremark.
- CoreMark Size : 666
- Total ticks : 315469154
- Total time (secs): 13.144549
- Iterations/Sec : 4564.629882
- Iterations : 60000
- Compiler version : GCC10.3.0
- Compiler flags : -Wall -Wno-format -fomit-frame-pointer -fno-builtin -ffunction-sections -fdata-sections -g -O3 -funroll-all-loops -finline-limit=600 -ftree-dominator-opts -fno-if-conversion2 -fselective-scheduling -fno-code-hoisting -mstrict-align
- Memory location : STACK
- seedcrc : 0xe9f5
- [0]crclist : 0xe714
- [0]crcmatrix : 0x1fd7
- [0]crcstate : 0x8e3a
- [0]crcfinal : 0xbd59
- Correct operation validated. See README.md for run and reporting rules.
- CoreMark 1.0 : 4564.629882 / GCC10.3.0 -Wall -Wno-format -fomit-frame-pointer -fno-builtin -ffunction-sections -fdata-sections -g -O3 -funroll-all-loops -finline-limit=600 -ftree-dominator-opts -fno-if-conversion2 -fselective-scheduling -fno-code-hoisting -mstrict-align / STACK
独立的下载工具:PMProgrammmer
测试OK
