RISC-V技术论坛
直播中
dianzi
5年用户 1967经验值
擅长:嵌入式技术
私信 关注
[资料]
[每日一芯] 全志Arm Cortex-A7和RISC-V E907 双CPU,内置1T 算力NPU 三核异构芯片 附完整固件及资料
全志V853芯片介绍
v853chip
【全志V853-高性能边缘AI视觉处理芯片】
V853 是一颗面向智能视觉领域推出的新一代高性能、低功耗的处理器SOC,可广泛用于智能门锁、智能考勤门禁、网络摄像头、行车记录仪、智能台灯等智能化升级相关行业。
V853 集成Arm Cortex-A7和RISC-V E907 双CPU,内置最大 1T 算力 NPU,使用全志自研 Smart 视频引擎,最大支持5M@25fps H.265编码和5M@25fps H.264编解码,同时集成高性能 ISP 图像处理器,可为客户提供专业级图像质量。V853 还支持 16-bit DDR3/DDR3L,满足各类产品高带宽需求;支持 4lane MIPI-CSI/DVP/MIPI-DSI/RGB 等丰富的专用视频输入输出接口,满足各类AI视觉产品需求;采用先进的22nm工艺,具有更优的功耗和更小的芯片面积。
同时,全志为 V853 配套提供了稳定、易用的 Linux SDK和软硬件参考设计,可以帮助客户快速实现产品量产。
V853芯片应用场景:
image-20220601152708483
芯片框图
D1-H芯片框图
参数规格
CPU
Arm Cortex-A7@1GHz
32 KB I-cache, 32 KB D-cache
128 KB L2 cache
RISC-V E907@600MHz
16 KB I-cache, 16 KB D-cache
NPU
Maximum perormance up to 1 Tops
Emdedded 128KB internal buffer
Supports deep learning frameworks: TensorFlow, Caffe, Tflite, Pytorch, Onnx NN, and so on
Memory
16-bit DDR3/DDR3L SDRAM, supporting maximum capacity of 1GB
SD3.0/eMMC 5.1 interface
Supports SPI Nor/SPI Nand Flash
Video Engine
Video encoder
    - H.264/H.265 up to 4K@15fps or 5M@25fps
    - JPEG up tp 1080p@60fps
Video decoder
    - Supports H.264 BP/MP/HP, JPEG
    - Real-time multiple streams H.264 encoding capability: 5M@25fps
    - JPEG snapshot performance of 1080P@60fps independently
Display Engine
Allwinner SmartColor post processing for an excellent display experience
Supports 2 video channels and 1 UI channel
Supports G2D hardware accelerator including rotate, mixer, scaler functionns
Video Input
ISP
    - Maxumum performance of 5M@30fps and maximum resolution of 3072 * 1772
    - Adjustable 3A functions (AE, AWB, AF), and 3A parameters are adjustable
    - Provides ISP tuning tools for the PC
VIPP
    - Four VIPP YUV422 or YUV420 outputs
    - Maximum performance of 5M@30fps, maximum resolution of 3072 * 1772
8-/10-/12-/16-bit parallel CSI interface
    - Supports digital camera (DC), BT.601, BT.656, BT.1120 protocol
    - Maximum video capture resolution up to 5M@30fps
4-lane MIPI CSI interface
    - Supports DOL WDR mode and splitting into 2*2-lane MIPI CSI
    - Supperts 4-ch VC de-interleaver function
    - Maximum video caputure resolution up to 5M@30fps
Video Out
RGB LCD output interface up to 1920 x 1080@60fps
4-lane MIPI DSI interface up to 1920 x 1080@60fps
Audio
1 DAC and 2 ADCs
Analog audio interfaces: MICIN1P/N, MICIN2P/N, LINEOUTRP/N
Digital audio interfaces: I2S/PCM *2 , DMIC
Security System
AES, DES, 3DES encryption and decryption algorithms
RSA/ECC signature verigication algorithm
MD5/SHA and HMAC tamper proofing
PRNG/TRRNG hardware random number generator
Integrated 2Kbits OTP storage space
Connectivity
USB2.0 DRD, SDIO 3.0, SPI *4, UART * 4, TWI * 5, WIEGAND
PWM (12-ch), GPADC (4-ch)
10/100/1000M EMAC with RMII and RGMII interfaces
Package
LFBGA 318, 12mm * 12 mm, 0.5mm ball pitch
Chip process
22nm
更多
一文带你看懂全志V853开发板原理图
带大家来一次全志V853开发板沉浸式开箱!
转自全志在线官网。
更多回帖
