W5500 RT-Thread TCP
在applica
tions文件下新建my_tcp.c文件
#include
#include /* 使用BSD socket,需要包含socket.h头文件 */
#include
#include
#include
#define BUFSZ 1024
static const char send_data[] = "This is TCP Client from RT-Thread."; /* 发送用到的数据 */
void tcpclient(int argc, char **argv)
int ret;
char *recv_data;
struct hostent *host;
int sock, bytes_received;
struct sockaddr_in server_addr;
const char *url;
int port;
if (argc < 3)
rt_kprintf("Usage: tcpclient URL PORTn");
rt_kprintf("Like: tcpclient 192.168.12.44 5000n");
return ;
url = argv[1];
port = strtoul(argv[2], 0, 10);
/* 通过函数入口参数url获得host地址(如果是域名,会做域名解析) */
host = gethostbyname(url);
/* 分配用于存放接收数据的缓冲 */
recv_data = rt_malloc(BUFSZ);
if (recv_data == RT_NULL)
rt_kprintf("No memoryn");
return;
/* 创建一个socket,类型是SOCKET_STREAM,TCP类型 */
if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1)
/* 创建socket失败 */
rt_kprintf("Socket errorn");
/* 释放接收缓冲 */
rt_free(recv_data);
return;
/* 初始化预连接的服务端地址 */
server_addr.sin_family = AF_INET;
server_addr.sin_port = htons(port);
server_addr.sin_addr = *((struct in_addr *)host->h_addr);
rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero));
/* 连接到服务端 */
if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1)
/* 连接失败 */
rt_kprintf("Connect fail!n");
closesocket(sock);
/*释放接收缓冲 */
rt_free(recv_data);
return;
while (1)
/* 从sock连接中接收最大BUFSZ - 1字节数据 */
bytes_received = recv(sock, recv_data, BUFSZ - 1, 0);
if (bytes_received < 0)
/* 接收失败,关闭这个连接 */
closesocket(sock);
rt_kprintf("nreceived error,close the socket.rn");
/* 释放接收缓冲 */
rt_free(recv_data);
break;
else if (bytes_received == 0)
/* 默认 recv 为阻塞模式,此时收到0认为连接出错,关闭这个连接 */
closesocket(sock);
/* 释放接收缓冲 */
rt_free(recv_data);
break;
/* 有接收到数据,把末端清零 */
recv_data[bytes_received] = '
