瑞芯微Rockchip开发者社区
直播中
五斤麻辣油
8年用户 1290经验值
擅长:电源/新能源
私信 关注
[问答]
pytorch模型Syntax error in input!是什么原因导致的
回帖(4)
贾桂林
2022-4-2 14:23:35
pytorch版本是多少?
rknn那边只能支持1.2的
举报
五斤麻辣油
2022-4-2 14:24:20
pytorch是1.2的
rknn 1.3
举报
juju宇哥
2022-4-2 14:25:01
  您好 我也遇到了相同的问题
  .load_pytorch时出错 提示Syntax error in input! LexToken(NAMED_IDENTIFIER,‘str’,
  后边build报 IndexError: list index out of range
举报
jjll652
2022-4-2 14:25:25
  你好,torch1.2也遇到相同的错误
  --》 config model
  done
  --》 Loading model
  /home/user/.local/lib/python3.6/site-packages/onnx_tf/common/__init__.py:87: UserWarning: FrontendHandler.get_outputs_names is deprecated. It will be removed in future release.。 Use node.outputs instead.
  warnings.warn(message)
  。/fire.pt ********************
  WARNING: Token ‘COMMENT’ defined, but not used
  WARNING: There is 1 unused token
  Syntax error in input! LexToken(《,‘《’,3,101)
  done
  --》 Building model
  W Genreate input meta fail, please check model.
  W External input meta file “/tmp/tmpzzzps_ss/fire_inputmeta.yml” is not exists.
  Traceback (most recent call last):
  File “/home/user/wuzhe/fire/model_trans.py”, line 51, in 《module》
  trans_model()
  File “/home/user/wuzhe/fire/model_trans.py”, line 36, in trans_model
  ret = rknn.build(do_quantization=True, dataset=‘。/dataset.txt’)
  File “/home/user/.local/lib/python3.6/site-packages/rknn/api/rknn.py”, line 238, in build
  ret = self.rknn_base.build(do_quantization=do_quantization, dataset=dataset, pack_vdata=pre_compile, batch_size=rknn_batch_size)
  File “rknn/api/rknn_base.py”, line 719, in rknn.api.rknn_base.RKNNBase.build
  File “rknn/api/rknn_base.py”, line 2249, in rknn.api.rknn_base.RKNNBase._generate_inputmeta
举报
更多回帖
