音视频技术
直播中
jf_82250995
3年用户 85经验值
擅长:嵌入式技术 分配器 连接器 视频转接
私信 关注
[讨论]
LT86104SXE-HDMI / DVI 1 to 4,适用于HDMI / DVI信号分离,多显示器
1.说明
LT86104SXELontium的第四代4端口HDMI / DVI分配器,可以将一个HDMI / DVI信号转发到4HDMI / DVI信号集,最多支持4个不同的HDMI / DVI接收/显示端子。它基于ClearedEdge™技术,支持每通道高达3.4Gbps的数据速率,符合HDMI 1.4 / DVI 1.0规范。
2.功能
兼容HDMI 1.4 / 2.0DVI 1.0规范
支持高达3.4Gbps数据速率的3D视频格式和4Kx2K扩展分辨率格式,以及60Hz YCbCr 420格式的4Kx2K
自适应均衡和去加重以补偿长时间电缆损耗
•ODT和校准
符合HDCP 1.4规范的集成HDCP转发器引擎
完全由硬件控制或可选的软件控制的HDCP操作
预编程的HDCP密钥集或外部EEPROM存储的密钥集
集成CEC控制器
集成EDID影子RAM和嵌入式EDID
5VDDC接口
•1HDMI / DVI输入端口,最多4HDMI / DVI输出端口
无限级联,用于更多输出端口或信号转发
•128LQFP封装
3.应用
多显示器/电视支持
•HDMI / DVI信号分离/重复
TheLT86104SXEis Lontium's fourth-generation 4-port HDMI/DVI splitter that can forward one HDMI/DVI signal to four HDMI/DVI signal sets, supporting up to four different HDMI/DVI receiving/display terminals.  It is based on ClearedEdge technology and supports data rates up to 3.4Gbps per channel, conforming to the HDMI 1.4 / DVI 1.0 specificationFunction of
2.
Compatible with HDMI 1.4/2.0 and DVI 1.0 specifications
Supports 3D video formats up to 3.4Gbps data rates and 4Kx2K extended resolution formats, as well as 4Kx2K in 60Hz YCbCr 4:2:0 format
Adaptive equalization and de-weighting to compensate for long time cable losses
the ODT and calibration
Integrated HDCP transponder engine that complies with HDCP 1.4 specification
Full hardware controlled or optional software controlled HDCP operation
Pre-programmed HDCP key set or external EEPROM stored key set
Integrated CEC controller
Integrated EDID shadow RAM and embedded EDID
5V DDC interface
1 HDMI/DVI input port, up to 4 HDMI/DVI output ports
Unlimited cascade for more output ports or signal forwarding
回帖(1)
杨杰
2022-4-6 11:27:20
帮楼主顶
1 举报
  • jf_82250995: 感谢支持!如需获取开发资料和技术支持欢迎随时与我取得联系0755-26980129
更多回帖
