添加编译包
添加quectel-CM app
OK3399-linux-source$ ls app/quectel-CM
build.sh ethtool-copy.h main.c MPQCTL.h MPQMUX.h QMIThread.c quectel-CM quectel-qmi-proxy udhcpc.c util.h
default.script GobiNetCM.c Makefile MPQMI.h NOTICE QMIThread.h quectel-mbim-proxy quectel-qmi-proxy.c udhcpc_netlink.c
device.c libmnl mbim-cm.c MPQMUX.c qmap_bridge_mode.c QmiWwanCM.c quectel-mbim-proxy.c ReleaseNote.txt util.c
在buildroot中添加配置文件
添加编译依赖
diff --git a/buildroot/package/forlinx/Config.in b/buildroot/package/forlinx/Config.in
index 59ad65d1d..0761d52e2 100644
--- a/buildroot/package/forlinx/Config.in
+++ b/buildroot/package/forlinx/Config.in
@@ -4,6 +4,7 @@ menuconfig BR2_PACKAGE_FORLINX
if BR2_PACKAGE_FORLINX
+source "package/forlinx/quectel-CM/Config.in"
source "package/forlinx/quectelCM/Config.in"
source "package/forlinx/matrix-browser/Config.in"
source "package/forlinx/forlinx-qt/Config.in"
添加配置文件和编译文件
buildroot/package/forlinx/quectel-CM/Config.in
config BR2_PACKAGE_QUECTEL_CM
bool "QUECTEL-CM"
help
EC20 tool quectel-CM
buildroot/package/forlinx/quectel-CM/quectel-CM.mk
QUECTEL_CM_VERSION = 1.0
QUECTEL_CM_SITE = $(TOPDIR)/../app/quectel-CM
QUECTEL_CM_SITE_METHOD = local
QUECTEL_CM_LICENSE = Apache V2.0
QUECTEL_CM_LICENSE_FILES = NOTICE
define QUECTEL_CM_BUILD_CMDS
$(TARGET_MAKE_ENV) $(MAKE) -C $(@D) CC=$(TARGET_CC)
endef
define QUECTEL_CM_INSTALL_TARGET_CMDS
$(INSTALL) -D -m 0755 $(@D)/quectel-CM $(TARGET_DIR)/usr/bin/quectel-CM
endef
$(eval $(generic-package))
需要注意的是配置文件中的config BR2_PACKAGE_QUECTEL_CM要和编译文件里的配置字段要匹配:
(*_QUECTEL_CM 对应 QUECTEL_CM_*)
在buildroot配置文件中添加app的编译选项
diff --git a/buildroot/configs/rockchip_rk3399_defconfig b/buildroot/configs/rockchip_rk3399_defconfig
index aebc92727..19c23513b 100644
--- a/buildroot/configs/rockchip_rk3399_defconfig
+++ b/buildroot/configs/rockchip_rk3399_defconfig
@@ -539,6 +539,7 @@ BR2_PACKAGE_LIBV4L_RKMPP=y
# BR2_PACKAGE_RK_WEBUI is not set
BR2_PACKAGE_CHROMIUM=y
BR2_PACKAGE_FORLINX=y
+BR2_PACKAGE_QUECTEL_CM=y
BR2_PACKAGE_QUECTELCM=y
BR2_PACKAGE_MATRIX_BROWSER=y
BR2_PACKAGE_FORLINX_QT=y
编译后查看编译结果:
OK3399-linux-source$ find buildroot/ -name "quectel-CM"
buildroot/output/rockchip_rk3399/build/quectel-CM-1.0/quectel-CM
buildroot/output/rockchip_rk3399/target/usr/bin/quectel-CM
OK3399-linux-source$ ls buildroot/output/rockchip_rk3399/build/quectel-CM-1.0/ -a
. device.c main.c MPQMI.h qmap_bridge_mode.c quectel-CM quectel-qmi-proxy .stamp_configured udhcpc_netlink.c
.. ethtool-copy.h Makefile MPQMUX.c QMIThread.c quectel-CM-1.0.tar quectel-qmi-proxy.c .stamp_rsynced util.c
build.sh GobiNetCM.c mbim-cm.c MPQMUX.h QMIThread.h quectel-mbim-proxy ReleaseNote.txt .stamp_target_installed util.h
default.script libmnl MPQCTL.h NOTICE QmiWwanCM.c quectel-mbim-proxy.c .stamp_built udhcpc.c
.stamp_built 表示该源码已经被编译过
.stamp_configured 表示该源码已经被配置过
.stamp_rsynced 目测表示该源码已经被同步
.stamp_target_installed 表示该源码编译结果已经被安装,安装目录一般是target目录
还有几个类似的文件
.stamp_downloaded 表示该源码已经被下载过,如果没有此文件会重新进行下载
.stamp_patched 表示此文件已经打过补丁
.stamp_extracted 表示此文件已经被压缩过,一般该目录下会有个压缩包
重新编译
修改了buildroot中的内容后需要重新编译,如果编译过的某个package目录下有上面的这几个文件,该包就不会进行重新编译。
如果需要重新编译这个package,可以删除这几个文件,或者某个文件,使得某几个编译步骤重新执行。
e.g.
rm buildroot/output/rockchip_rk3399/build/libnspr-4.17/.stamp_*
不过实际过程中可能会有编译不过的情况出现,这个时候可以从其他路径下面拷贝需要的.stamp文件,这样就可以编译通过了。
或者可以执行make clean命令,清除output路径下的全部内容,不过重新编译的耗时会很长。
添加编译包
添加quectel-CM app
在buildroot中添加配置文件
添加编译依赖
添加配置文件和编译文件
bool "QUECTEL-CM"
help
endef
endef
编译后查看编译结果:
还有几个类似的文件
重新编译
e.g.
举报
