瑞芯微Rockchip开发者社区
直播中
李春梅
8年用户 1981经验值
私信 关注
[问答]
在编译的rk3288中怎样加入edp dts配置呢
在编译的rk3288中怎样加入edp dts配置呢?
在rk3288.dtsi中的edp地址是什么呢?
回帖(1)
刘娟
2022-3-4 11:27:09
1 找到 在要编译的rk3288-evb-android-rk808-edp.dts
加入以下edp dts配置:
/dts-v1/;
#include "rk3288-evb.dtsi"
#include "rk3288-android.dtsi"
#include
#include
#include
// added  for edp start <<<
&edp {
        status = "okay";
&edp_phy {
        status = "okay";
&route_edp {
        status = "okay";
&edp_in_vopb {
        status = "okay";
&edp_in_vopl {
        status = "disabled";
&edp_panel {
//        compatible = "simple-panel";
    backlight = <&backlight>;
        power-supply = <&vcc_lcd>;
        status = "okay";
        disp_timings: display-timings {
                native-mode = <&edp_panel_name>;
                edp_panel_name: timing0 {
                        clock-frequency = <158000000>;
                        hactive = <1920>;
                        vactive = <1080>;
                        hfront-porch = <48>;
                        hsync-len = <4>;
                        hback-porch = <310>;
                        vfront-porch = <3>;
                        vsync-len = <4>;
                        vback-porch = <60>;
                        hsync-active = <0>;
                        vsync-active = <0>;
                        de-active = <0>;
                        pixelclk-active = <0>;
// added edp end >>>
2.编译kernel,烧写固件,绑定edp成功会有以下log出现
[    1.535994] rockchip-drm display-subsystem: bound ff970000.dp (ops rockchip_dp_component_ops)
[    1.536006] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
在rk3288.dtsi中可以知道edp地址是ff970000
edp: dp@ff970000 {
                compatible = "rockchip,rk3288-dp";
                reg = <0x0 0xff970000 0x0 0x4000>;
                interrupts = ;
                clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>;
                clock-names = "dp", "pclk";
                power-domains = <&power RK3288_PD_VIO>;
                phys = <&edp_phy>;
                phy-names = "dp";
                resets = <&cru SRST_EDP>;
                reset-names = "dp";
                rockchip,grf = <&grf>;
                ports {
                        #address-cells = <1>;
                        #size-cells = <0>;
                        edp_in: port@0 {
                                reg = <0>;
                                #size-cells = <0>;
                                edp_in_vopb: endpoint@0 {
                                        reg = <0>;
                                        remote-endpoint = <&vopb_out_edp>;
                                edp_in_vopl: endpoint@1 {
                                        reg = <1>;
                                        remote-endpoint = <&vopl_out_edp>;
举报
更多回帖
