瑞芯微Rockchip开发者社区
直播中
王银喜
8年用户 2558经验值
私信 关注
[问答]
请教一下RK3568是如何将EDP转成VGA-out的
请教一下RK3568是如何将EDP转成VGA-out的?
回帖(1)
孙喆
2022-3-2 17:49:55
原理图
经原理图可知由芯片将EDP转成VGA-out
第一步:万用表测量和设置电源位使芯片供电正常
第二步:添加DTS-EDP部分(将HDMI关闭)
路径: kernelarcharm64bootdtsrockchiprk3568-evb.dtsi
        edp_panel: edp-panel {
                compatible = "simple-panel";
                status = "okay";  //disabled or okay
//        power-supply = <&vcc3v3_lcd_edp>;
        enable-gpios = <&gpio0 RK_PC4 GPIO_ACTIVE_HIGH>;
                prepare-delay-ms = <201>;
                enable-delay-ms = <201>;
                backlight = <&backlight>;
        display-timings {
        native-mode = <&timing0>;
        timing0: timing0 {
                clock-frequency = <140000000>;
                hactive = <1920>;
                vactive = <1080>;
                hfront-porch = <80>;
                hsync-len = <20>;
                hback-porch = <80>;
                vfront-porch = <12>;
                vsync-len = <24>;
                vback-porch = <12>;
                hsync-active = <0>;
                vsync-active = <0>;
                de-active = <0>;
                pixelclk-active = <0>;
                ports {
                        panel_in_edp: endpoint {
                                remote-endpoint = <&edp_out_panel>;
&edp {
    hpd-gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>;
    force-hpd;
    ports {
        edp_out: port@1 {
            reg = <1>;
            #address-cells = <1>;
            #size-cells = <0>;
            edp_out_panel: endpoint@0 {
                reg = <0>;
                remote-endpoint = <&panel_in_edp>;
&route_edp {
        connect = <&vp0_out_edp>;
&edp_phy {
&edp_in_vp0 {
        status = "disabled"; //disabled or okay
&edp_in_vp1 {
    //这里并未用到
    vcc3v3_lcd_edp: vcc3v3-lcd-edp {
        compatible = "regulator-fixed";
        gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>;
        enable-active-high;
        regulator-name = "vcc3v3_lcd_edp";
        regulator-boot-on;
        regulator-state-mem {
        regulator-off-in-suspend;
[tr]NAMEGPIOGPIO_ACTIVE[/tr]
vcc3v3_lcd_edp (LCD_EN)GPIO1_B1GPIO_ACTIVE_HIGH
enable-gpios(BL_EN)GPIO0_C4GPIO_ACTIVE_HIGH
hpd-gpios(EDP_HPD)GPIO0_C0GPIO_ACTIVE_HIGH
举报
更多回帖
