STM32F1xx以及其他CortexM3 M4内核的中断都差不多,都采用中断向量表的方式进行,中断产生时可以直接跳转到中断向量表中找到相应的中断。而且根据需要这个表可以放到非0的地方,一般都是放在程序最开始的地方。
代码如下
__Vectors DCD __initial_sp ; Top of Stack
DCD Reset_Handler ; Reset Handler
DCD NMI_Handler ; NMI Handler
DCD HardFault_Handler ; Hard Fault Handler
DCD MemManage_Handler ; MPU Fault Handler
DCD BusFault_Handler ; Bus Fault Handler
DCD UsageFault_Handler ; Usage Fault Handler
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD SVC_Handler ; SVCall Handler
DCD DebugMon_Handler ; Debug Monitor Handler
DCD 0 ; Reserved
DCD PendSV_Handler ; PendSV Handler
DCD SysTick_Handler ; SysTick Handler
; External Interrupts
DCD WWDG_IRQHandler ; Window Watchdog
DCD PVD_IRQHandler ; PVD through EXTI Line detect
DCD TAMPER_IRQHandler ; Tamper
DCD RTC_IRQHandler ; RTC
DCD FLASH_IRQHandler ; Flash
DCD RCC_IRQHandler ; RCC
DCD EXTI0_IRQHandler ; EXTI Line 0
DCD EXTI1_IRQHandler ; EXTI Line 1
DCD EXTI2_IRQHandler ; EXTI Line 2
DCD EXTI3_IRQHandler ; EXTI Line 3
DCD EXTI4_IRQHandler ; EXTI Line 4
DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1
DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2
DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3
DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4
DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5
DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6
DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7
DCD ADC1_2_IRQHandler ; ADC1_2
DCD USB_HP_CAN1_TX_IRQHandler ; USB High Priority or CAN1 TX
DCD USB_LP_CAN1_RX0_IRQHandler ; USB Low Priority or CAN1 RX0
DCD CAN1_RX1_IRQHandler ; CAN1 RX1
DCD CAN1_SCE_IRQHandler ; CAN1 SCE
DCD EXTI9_5_IRQHandler ; EXTI Line 9..5
DCD TIM1_BRK_IRQHandler ; TIM1 Break
DCD TIM1_UP_IRQHandler ; TIM1 Update
DCD TIM1_TRG_COM_IRQHandler ; TIM1 Trigger and Commutation
DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare
DCD TIM2_IRQHandler ; TIM2
DCD TIM3_IRQHandler ; TIM3
DCD TIM4_IRQHandler ; TIM4
DCD I2C1_EV_IRQHandler ; I2C1 Event
DCD I2C1_ER_IRQHandler ; I2C1 Error
DCD I2C2_EV_IRQHandler ; I2C2 Event
DCD I2C2_ER_IRQHandler ; I2C2 Error
DCD SPI1_IRQHandler ; SPI1
DCD SPI2_IRQHandler ; SPI2
DCD USART1_IRQHandler ; USART1
DCD USART2_IRQHandler ; USART2
DCD USART3_IRQHandler ; USART3
DCD EXTI15_10_IRQHandler ; EXTI Line 15..10
DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line
DCD USBWakeUp_IRQHandler ; USB Wakeup from suspend
__Vectors_End
AMR9的中断与其不同,ARM9只有一个中断入口,也就是中断来了以后都从这个入口进来,然后判断是什么中断,再进行相应的处理。代码如下(代码为RTT驱动里的)
IRQ_Handler PROC
STMFD SP!, {R0-R12,LR}
BL rt_interrupt_enter
BL rt_hw_trap_irq
BL rt_interrupt_leave
LDR R0, =rt_thread_switch_interrupt_flag
LDR R1, [R0]
CMP R1, #1
BEQ rt_hw_context_switch_interrupt_do
LDMFD SP!, {R0-R12,LR}
SUBS PC, LR, #4
ENDP
其中rt_hw_trap_irq(其他的为上下文切换的汇编,详情见RTT)就是中断处理函数的入口
void rt_hw_trap_irq()
rt_isr_handler_t isr_func;
rt_uint32_t irq;
void *param;
/* get irq number */
irq = rt_hw_interrupt_get_active(INT_IRQ);
/* get interrupt service routine */
isr_func = irq_desc[irq].handler;
param = irq_desc[irq].param;
/* turn to interrupt service routine */
isr_func(irq, param);
rt_hw_interrupt_ack(INT_IRQ, irq);
#ifdef RT_USING_INTERRUPT_INFO
irq_desc[irq].counter ++;
#endif
在这里再进行相应的处理。
代码如下
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
__Vectors_End
IRQ_Handler PROC
BL rt_hw_trap_irq
LDR R1, [R0]
CMP R1, #1
SUBS PC, LR, #4
ENDP
rt_uint32_t irq;
void *param;
#endif
在这里再进行相应的处理。
举报
