单片机学习小组
直播中
靓仔峰
10年用户 1229经验值
擅长:可编程逻辑
私信 关注
在STM32F103上怎样去实现LCD12864屛的设计呢
STM32F103上怎样去实现LCD12864屛的设计呢?其代码该怎样去实现呢?
回帖(1)
陈小鸥
2022-1-21 13:36:30
最近在项目上用到LCD屏,屏幕大小为128*64,芯片为ST7565不带字库的
STM32F103代码实现,用的是ST的LL库
#define CS_Pin LL_GPIO_PIN_5
#define CS_GPIO_Port GPIOB
#define RST_Pin LL_GPIO_PIN_6
#define RST_GPIO_Port GPIOB
#define A0_Pin LL_GPIO_PIN_8
#define A0_GPIO_Port GPIOB
#define  OLED_CS_HIGH()                LL_GPIO_SetOutputPin(CS_GPIO_Port,CS_Pin)
#define  OLED_CS_LOW()                LL_GPIO_ResetOutputPin(CS_GPIO_Port,CS_Pin)
#define  OLED_WDATA()                LL_GPIO_SetOutputPin(A1_GPIO_Port,A1_Pin)
#define  OLED_WCMD()                LL_GPIO_ResetOutputPin(A1_GPIO_Port,A1_Pin)
//IO口初始化
static void MX_GPIO_Init(void)
  LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_GPIOC);
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_GPIOD);
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_GPIOB);
  LL_GPIO_ResetOutputPin(GPIOB, CS_Pin|RST_Pin|A0_Pin);
  GPIO_InitStruct.Pin = CS_Pin|RST_Pin|A0_Pin;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_OUTPUT;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
  GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
  LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
//spi2初始化
static void MX_SPI2_Init(void)
  /* USER CODE BEGIN SPI2_Init 0 */
  /* USER CODE END SPI2_Init 0 */
  LL_SPI_InitTypeDef SPI_InitStruct = {0};
  /* Peripheral clock enable */
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_SPI2);
  /**SPI2 GPIO Configuration
  PB13   ------> SPI2_SCK
  PB15   ------> SPI2_MOSI
  GPIO_InitStruct.Pin = LL_GPIO_PIN_13|LL_GPIO_PIN_15;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_HIGH;
  /* SPI2 interrupt Init */
  NVIC_SetPriority(SPI2_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
  NVIC_DisableIRQ(SPI2_IRQn);
  /* USER CODE BEGIN SPI2_Init 1 */
  /* USER CODE END SPI2_Init 1 */
  /* SPI2 parameter configuration*/
  SPI_InitStruct.TransferDirection = LL_SPI_FULL_DUPLEX;
  SPI_InitStruct.Mode = LL_SPI_MODE_MASTER;
  SPI_InitStruct.DataWidth = LL_SPI_DATAWIDTH_8BIT;
  SPI_InitStruct.ClockPolarity = LL_SPI_POLARITY_LOW;
  SPI_InitStruct.ClockPhase = LL_SPI_PHASE_1EDGE;
  SPI_InitStruct.NSS = LL_SPI_NSS_SOFT;
  SPI_InitStruct.BaudRate = LL_SPI_BAUDRATEPRESCALER_DIV64;
  SPI_InitStruct.BitOrder = LL_SPI_MSB_FIRST;
  SPI_InitStruct.CRCCalculation = LL_SPI_CRCCALCULATION_DISABLE;
  SPI_InitStruct.CRCPoly = 10;
  LL_SPI_Init(SPI2, &SPI_InitStruct);
  /* USER CODE BEGIN SPI2_Init 2 */
  LL_SPI_EnableIT_TXE(SPI2);
  LL_SPI_Enable(SPI2);
  /* USER CODE END SPI2_Init 2 */
//写命令
void SpiWriteComd(uint8_t val)
        OLED_WCMD();
    OLED_CS_LOW();
    LL_SPI_TransmitData8(SPI2, val);
    while(LL_SPI_IsActiveFlag_TXE(SPI2) == 0);
    while(LL_SPI_IsActiveFlag_BSY(SPI2) == 1);  //等待发送完成后,置高CS,不能早不能晚
    OLED_CS_HIGH();
//写数据
void SpiWriteData(uint8_t val)
        OLED_WDATA();
    OLED_CS_LOW();
    OLED_CS_HIGH();
//延时
void Lcd_DelayUs(uint32_t us)
        uint8_t i;
        while(--us>0){
                for(i=0; i<10; ++i){
                        //asm("NOP");
                        LL_IWDG_ReloadCounter(IWDG);
//复位
void Lcd_Reset(void)
        LL_GPIO_ResetOutputPin(RST_GPIO_Port, RST_Pin);
        Lcd_DelayUs(1000);
        LL_GPIO_SetOutputPin(RST_GPIO_Port, RST_Pin);
//清屏
void Clear(void)
        uint8_t i,j;
        for(i=0;i<8;i++)
                SpiWriteComd(0xb0 + i);
                SpiWriteComd(0x10);
                SpiWriteComd(0);
                for(j=0;j<128;j++)
                        SpiWriteData(0x00);
//设置行
void SetLine(uint8_t line)
        line = line & 0x07;
        line = line | 0xB0;
        SpiWriteComd(line);
//设置列
void SetColumn(uint8_t col)
        uint8_t col_h,col_l;
        col = col & 0x7F;
        col_h = col & 0xF0;
        col_h >>= 4;
        col_h |= 0x10;
        col_l = col & 0x0F;
        col_l |= 0x00;
        SpiWriteComd(col_h);
        SpiWriteComd(col_l);
//写汉字
void PutChinese(uint8_t line,uint8_t column,const uint8_t * data)
        uint32_t j;
        SetLine(line);
        SetColumn(column);
        for(j=0;j<16;j++)
                SpiWriteData(*data++);
        SetLine(line + 1);
        SetColumn(column);
        for(j=0;j<16;j++)
//写字符
void PutAscii(uint8_t line,uint8_t column,const uint8_t * data)
        uint32_t j;
        SetLine(line);
        SetColumn(column);
        for(j=0;j<8;j++)
        SetLine(line + 1);
        SetColumn(column);
        for(j=0;j<8;j++)
//初始化
void InitDisplay(void)
        uint32_t i;
        Lcd_Reset();
        Clear();
        SpiWriteComd(0xAE);
        SpiWriteComd(0xA2);
        SpiWriteComd(0xA0);
        SpiWriteComd(0xC8);
        SpiWriteComd(0xF8);
        SpiWriteComd(0x00);
        SpiWriteComd(0x25);
        SpiWriteComd(0x81);
        SpiWriteComd(0x28);
        SpiWriteComd(0x2C);
        SpiWriteComd(0x2E);
        SpiWriteComd(0x2F);
        SpiWriteComd(0xAF); //Set Display ON
        PutChinese(0,0,&CH_DOT[0][0]);
        PutChinese(0,16,&CH_DOT[1][0]);
        PutAscii(4,32,&ASCII_DOT['1' - 0x20][0]);
        PutAscii(4,32+8,&ASCII_DOT['2' - 0x20][0]);
        PutAscii(4,32+16,&ASCII_DOT['3' - 0x20][0]);
        PutAscii(4,32+24,&ASCII_DOT['A' - 0x20][0]);
        PutAscii(4,32+32,&ASCII_DOT['B' - 0x20][0]);
        PutAscii(4,32+40,&ASCII_DOT['C' - 0x20][0]);
举报
更多回帖
