瑞芯微Rockchip开发者社区
直播中
万物死
9年用户 1389经验值
擅长:MEMS/传感技术
私信 关注
[问答]
去掉SD_MMC驱动的方法是什么?
我的系统不需要SD卡和MMC卡支持,这部分电路去掉了,但启动会报告以下信息:[    9.130137] *mmc1 detect cd change*
[    9.133958] *mmc1 lock*
[    9.136644] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[    9.160078] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    9.190991] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 52, RTO !!
[    9.198731] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 52, RTO !!
[    9.205523] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    9.219862] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    9.233512] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 8, RTO !!
[    9.241165] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 5, RTO !!
[    9.248830] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 5, RTO !!
[    9.256460] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 5, RTO !!
[    9.264083] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 5, RTO !!
[    9.271677] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
[    9.279405] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
[    9.287114] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
[    9.294828] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
[    9.301562] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    9.314237] sunxi-mmc 1c0f000.sdmmc: smc 1 p0 err, cmd 1, RTO !!
[    9.320874] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.320379] gpu cooling callback set freq limit 384
[   10.980052] *mmc3 detect cd change*
[   10.983890] *mmc3 lock*
[   10.986587] sunxi-mmc 1c12000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[   11.010074] sunxi-mmc 1c12000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[   11.041052] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 52, RTO !!
[   11.048821] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 52, RTO !!
[   11.055586] sunxi-mmc 1c12000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[   11.069959] sunxi-mmc 1c12000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[   11.083549] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 8, RTO !!
[   11.091136] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 5, RTO !!
[   11.098763] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 5, RTO !!
[   11.106398] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 5, RTO !!
[   11.113983] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 5, RTO !!
[   11.121627] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 55, RTO !!
[   11.129354] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 55, RTO !!
[   11.137066] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 55, RTO !!
[   11.144795] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 55, RTO !!
[   11.151477] sunxi-mmc 1c12000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[   11.164135] sunxi-mmc 1c12000.sdmmc: smc 3 p3 err, cmd 1, RTO !!
[   11.170785] sunxi-mmc 1c12000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
想把这些去掉,我注释了CONFIG_MMC,但编译出现以下错误:
drivers/built-in.o: In function `scan_device_store':
sunxi_dramfreq.c:(.text+0xb2d18): undefined reference to `sunxi_mmc_rescan_card'
make: *** [vmlinux] Error 1
搜索代码发现只要定义了CONFIG_ARCH_SUNXI=y,就会有好几个地方调用sunxi_mmc_rescan_card函数,难道要把
CONFIG_ARCH_SUNXI=y去掉吗?
回帖(1)
肖青
2022-1-5 10:14:13
在配置文件中“disable”掉SD卡的选项。
[emac0]
emac0_used         = 1
emac_rxd3          = port:PA00<2><3>
emac_rxd2          = port:PA01<2><3>
emac_rxd1          = port:PA02<2><3>
emac_rxd0          = port:PA03<2><3>
emac_txd3          = port:PA04<2><3>
emac_txd2          = port:PA05<2><3>
emac_txd1          = port:PA06<2><3>
把上面的“emac0_used         = 1”改成“emac0_used         = 0”
国内这些做MPU的挺恶心的,有时间不说干点正事,把核心技术好好提高一下,非要把个配置文件另起一套,玩鸡贼,真是闲的蛋疼!远没有原系统的好用。
举报
更多回帖
