Matlab论坛
直播中
王兰
13年用户 1678经验值
擅长:基础元器件
私信 关注
[经验]
matlab声音监控小程序
声音监控,有东西发出声音就进行报警:纯m文件编程实现……
以下是程序:
function sounddetection
%参数设置
secondsToRecord = 10;
soundThreshold = 0.05; % 0.0 ~ 1.0.
ai = analoginput('winsound');
addchannel(ai,[1 2]);
set(ai, 'LogToDiskMode', 'overwrite');
set(ai, 'TriggerType', 'manual');
set(ai, 'TriggerRepeat', Inf);
samplesToRecord = ceil(ai.SampleRate * secondsToRecord);
set(ai, 'SamplesPerTrigger', samplesToRecord );
set(ai,'StartFcn',@soundStartFcn);
set(ai, 'TimerPeriod', 0.1);
set(ai, 'TimerFcn', @soundTimerFcn);
%创建一个figure
fig = figure('DoubleBuffer','on', ...
'Name', 'Intruder Detection', ...
'NumberTitle', 'off', ...
'WindowStyle', 'docked', ...
'Toolbar', 'none', ...
'MenuBar', 'none', ...
'Color',[.5 .5 .5], ...
'CloseRequestFcn', @figureCloseFcn, ...
'DeleteFcn', @figureDeleteFcn);
timePrevious = [];
start(ai);
function soundStartFcn(vid, event)
timePrevious = now;
end
function soundTimerFcn(vid, event)
try
timeCurrent = now;
catch
return;
end
samplesRequested = ceil((timeCurrent - timePrevious) * (60*60*24) *...
ai.SampleRate);
warning('off','daq:peekdata:requestedSamplesNotAvailable');
try
sound = peekdata(ai, samplesRequested);
catch
sound = zeros(samplesRequested, length(ai.Channel));
end
warning('on','daq:peekdata:requestedSamplesNotAvailable');
sound = sound - mean(sound(:,1)); % Center about the mean.
soundMax = max(max(abs(sound))); % Calculate max deviation from mean.
timePrevious = timeCurrent;
% Make our figure current.
figOld = get(0,'CurrentFigure');
if fig ~= figOld
set(0, 'CurrentFigure', fig);
end
plot(sound);
% axis([0 size(sound,1) -1 1]);
ylim([-1 1]);
set(gca,'XTick',[]);
% Look for noise.
if soundMax > soundThreshold
noise = true;
else
noise = false;
end
if ~islogging(ai)
if noise
set(gcf, 'Color', [1 0 0]);
% trigger(ai);
% 发现高音量后的处理
customIntruderAction();
else
set(gcf, 'Color', [.5 .5 .5]);
end;
end
if fig ~= figOld
set(0, 'CurrentFigure', figOld);
end
end
% 发现高音量后的处理
function customIntruderAction()
% tts('please turn your volumn down'); % 语音报警
end
function figureCloseFcn(obj, event)
try
stop(ai);
catch
end
closereq;
end
function figureDeleteFcn(obj, event)
delete(ai);
end
end
哈哈……
程序的前提:不是有摄像头了,二是有采集装置。
运行程序后,周围不要发出声音,可以看到波动很小,
然后你可以咳嗽一声或者什么的……然后图像波动变大,
并且gui的背景变为红色……
调节相应的参数,可以调整监控的灵敏度……
顺便在此介绍一下matalb中利用声音采集装置进行采集的一些方法:
类似于matlab调用视频时的videoinput函数,采集声音时,也后相应的函数:
analoginput。查看自己电脑中支持采集声音的适配器方法:利用函数:daqhwinfo
返回值中有一个InstalledAdaptors的变量,查看此变量就可以发现自己电脑所带的相应的适配器,
如我的电脑:
>> out = daqhwinfo
out =
          ToolboxName: 'Data Acquisition Toolbox'
       ToolboxVersion: '2.17 (R2010b)'
        MATLABVersion: '7.11 (R2010b)'
    InstalledAdaptors: {2x1 cell}
>> out.InstalledAdaptors
ans =
    'parallel'
    'winsound'
显示有两个:'parallel'和'winsound'
查看后,就可以使用函数analoginput了……
利用函数analoginput返回的Object就可以进行相应的设置了:
如:'StartFcn'、 'TimerPeriod'和'TimerFcn'等函数了……
(和调用u***摄像头原理类似……)
然后就可以在相应的函数中进行自己的编程了……
无声音:
有声音:
回帖(17)
swallow_sw
2012-2-28 10:40:08
试一下
举报
逍遥jan
2012-5-17 07:43:21
这么厉害????
举报
光之翼
2012-5-18 23:10:52
学习一下子
举报
luomia
2012-6-29 15:34:38
不晓得采集到的声音能回放不?
举报
polarization
2012-11-3 23:44:40
这个可以与视频一起做成监控
举报
zhangran666
2013-1-18 08:52:41
看起来不错,学习下
举报
eric
2013-1-19 14:27:21
学习下···
举报
李小龙
2013-3-14 22:34:12
好好学习天天向上
举报
chuanqi
2013-3-15 16:36:07
举报
钟冠灏
2013-3-23 10:15:37
还没学这个
举报
庐山781
2013-4-9 18:05:47
不错不错,太有意思啦
举报
小椰℡吥乖➹
2013-7-30 13:08:45
   感觉好强大啊   自己弱爆了
举报
`、silence
2013-10-26 22:58:30
挺好玩的,支持楼主,学习学习啦!
举报
黑黑的娃
2014-9-18 16:06:42
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
沈强
2016-9-13 15:15:28
谢谢~~~~~~~~~~~~~~~~
举报
priceruxu
2017-1-23 17:57:49
学习
举报
朱琦
2018-3-10 12:47:22
好厉害的样子!!!
举报
更多回帖
