【HarmonyOS HiSpark IPC试用】用hpm获取源码方式环境--hpm安装 - HarmonyOS技术社区 - 电子技术论坛 - 广受欢迎的专业电子论坛
分享 收藏 返回
fannifu 关注 私信
[文章]
昨天编译出错,可能gitee下载源码有问题,今天试试用hpm获取源码
安装Node.js。
打开CMD,执行以下命令:
安装完成后执行如下命令,显示hpm版本,即安装成功。
如果升级hpm的版本,请执行如下命令:
查看node版本
v10.19.0
fan@FAN:~$ npm install -g n
npm ERR! code EACCES
npm ERR! path /usr/local/lib
npm ERR! Error: EACCES: permission denied, access '/usr/local/lib'
npm ERR!   stack:
npm ERR!   errno: -13,
npm ERR!   syscall: 'access',
npm ERR!
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! the command again as root/Administrator.
npm ERR! A complete log of this run can be found in:
看来权限不够,加sudo
[sudo] password for fan://输入密码
安装最近稳定版本,是v14.15.4,应该够本了吧
  installing : node-v14.15.4
mkdir: cannot create directory ‘/usr/local/n’: Permission denied
  Error: sudo required (or change ownership, or define N_PREFIX)
fan@FAN:~$ sudo n stable
       mkdir : /usr/local/n/versions/node/14.15.4
   installed : v14.15.4 (with npm 6.14.10)
Note: the node command changed location and the old location may be remembered in your current shell.
         new : /usr/local/bin/node        //新安装node目录
再查看node版本
v10.19.0
fan@FAN:~$ which node
已经指向新目录,我就不管它了
internal/modules/cjs/loader.js:883
Error: Cannot find module 'semver'        //报错没有semver
- /usr/share/npm/lib/utils/unsupported.js
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
    at Module.require (internal/modules/cjs/loader.js:952:19)
    at Object. (/usr/share/npm/lib/utils/unsupported.js:2:14)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
    at Function.Module._load (internal/modules/cjs/loader.js:769:14)
  code: 'MODULE_NOT_FOUND',
    '/usr/share/npm/lib/utils/unsupported.js',
报错没有semver  就安装
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN fan No description
npm WARN fan No README data
added 3 packages from 2 contributors in 8.69s
   │   Changelog: https://github.com/npm/cli/releases/tag/v6.14.11   │
提示升级npm
npm ERR! path /usr/local/lib/node_modules/.staging/npm-3e479054/node_modules/yargs-parser
npm ERR! errno -13
npm ERR!  [OperationalError: EACCES: permission denied, rename '/usr/local/lib/node_modules/.staging/npm-3e479054/node_modules/yargs-parser' -> '/usr/local/lib/node_modules/.staging/yargs-parser-2ae220e0'] {
npm ERR!     syscall: 'rename',
npm ERR!     dest: '/usr/local/lib/node_modules/.staging/yargs-parser-2ae220e0'
npm ERR!
升级也出错,尝试再安装semver
npm WARN saveError ENOENT: no such file or directory, open '/home/fan/package.json'
updated 1 package in 0.924s
fan@FAN:~$ sudo npm install -g @ohos/hpm-cli
npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
npm ERR! Unexpected end of JSON input while parsing near '...sj1FJcyP6mhwDIXJUbk3P'
再次安装hpm,提示……Unexpected end of JSON input……,清理缓存
npm WARN using --force I sure hope you know what you are doing.
npm WARN deprecated @babel/polyfill@7.12.1:
回帖(1)
fannifu
2021-2-7 12:45:00
尝试再次安装hpm
更多回帖
