[文章]【HarmonyOS HiSpark IPC试用】踩坑失败记录--获取源码编译烧录启动
阅读量0
<span]hpm初始化
<span]Your bundle will be created in the directory /home/fan/HarmonyOS_Code.
<span]Initialization error: rm: permission denied: /home/fan/HarmonyOS_Code/bundle.json
<span]
<span]
<span]过程不详述,与虚拟机一样搞一遍
<span]
<span]按上回书 写的代码
烧录
<span]
<span]后面还是要烧录的
setenv bootcmd "sf probe 0;sf read 0x40000000 0x100000 0x400000;go 0x40000000";
[size=6M";
<span]<span]saveenv
<span]
<span]内核启动成功
<span]OHOS #
<span]文件系统启动失败
<span][Init] SigHandler, SIGCHLD received.
<span]Error loading shared library libzlib_shared.so: No such file or directory (needed by foundation)
<span]Error relocating /usr/lib/libbundlems.so: inflateInit2_: symbol not found
<span]Error relocating /usr/lib/libbundlems.so: inflateEnd: symbol not found
<span][Init] stop service shell pid 3 failed! err 1.
<span][ERR]OsSdSync 912, mutex lock fail!
<span]文件系统启动失败,动态链接库丢失了
<span]重新烧录,问题依然
<span]求助怎么解决?
<span]
回帖
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
链接复制成功,分享给好友
